[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-36-g8eecc74
Wed Mar 4 18:22:19 PST 2020
the project "PostGIS".
       via  8eecc746627f200f0df834ca19a3aea92db3782f (commit)
      from  10f91f070e04ffa7866560b682694b584de54b4e (commit)
revisions in full, below.
commit 8eecc746627f200f0df834ca19a3aea92db3782f
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Mar 4 21:22:12 2020 -0500
    add See also section for ST_BandPath and add more examples of GIC setting for outdb
diff --git a/doc/reference_guc.xml b/doc/reference_guc.xml
index 17009f1..6c07829 100644
--- a/doc/reference_guc.xml
+++ b/doc/reference_guc.xml
@@ -225,7 +225,7 @@ SET postgis.gdal_enabled_drivers = 'DISABLE_ALL';
 			<refsection>
 				<title>Examples</title>
-				<para>Set and reset <varname>postgis.enable_outdb_rasters</varname></para>
+				<para>Set and reset <varname>postgis.enable_outdb_rasters</varname> for current session</para>
 				<programlisting>
 SET postgis.enable_outdb_rasters TO True;
@@ -233,6 +233,20 @@ SET postgis.enable_outdb_rasters = default;
 SET postgis.enable_outdb_rasters = True;
 SET postgis.enable_outdb_rasters = False;
 				</programlisting>
+				<para>Set for specific database</para>
+				<programlisting>
+ALTER DATABASE gisdb SET postgis.enable_outdb_rasters = true;
+				</programlisting>
+				<para>Setting for whole database cluster. You need to reconnect to the database for changes to take effect.</para>
+				<programlisting>
+ --writes to postgres.auto.conf
+ALTER SYSTEM postgis.enable_outdb_rasters = true;
+ --Reloads postgres conf
+SELECT pg_reload_conf();
+				</programlisting>
 			</refsection>
 			<refsection>
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index 69e37a2..db0ced7 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -4012,9 +4012,9 @@ select st_bandisnodata(rast, 2) from dummy_rast where rid = 1; -- Expected false
 				<title>Description</title>
 				<para>Returns system file path to a band.  Returns null for in db raster bands.</para>
-				</refsection>
+			</refsection>
-				<refsection>
+			<refsection>
 					<programlisting>SELECT rid, ST_BandPath(rast,1) AS file_path
@@ -4024,7 +4024,7 @@ LIMIT 1;</programlisting>
 			<refsection>
 				<title>See Also</title>
-				<para></para>
+				<para><xref linkend="RT_ST_BandFileSize" />, <xref linkend="RT_ST_BandFileTimestamp" />, <xref linkend="RT_ST_BandMetaData" />, <xref linkend="postgis_enable_outdb_rasters" />, <xref linkend="outdb" /></para>
 			</refsection>
 		</refentry>
Summary of changes:
 doc/reference_guc.xml    | 16 +++++++++++++++-
 doc/reference_raster.xml |  6 +++---
 2 files changed, 18 insertions(+), 4 deletions(-)
hooks/post-receive
