[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-45-g079e807
Mon Mar 23 02:58:14 PDT 2020
the project "PostGIS".
       via  079e807123b8086f05416bba82305151df8a0ff0 (commit)
      from  33cd9fba44bc5b204b22a4b4eb6d56006b38637a (commit)
revisions in full, below.
commit 079e807123b8086f05416bba82305151df8a0ff0
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Mar 20 20:33:42 2020 +0100
    Use offsetof instead of pointer arithmetics
    I introduced this montrosity in #4451 because I didn't know any better
    Closes https://github.com/postgis/postgis/pull/549
diff --git a/liblwgeom/gserialized1.c b/liblwgeom/gserialized1.c
index 4b16aaa..728c005 100644
--- a/liblwgeom/gserialized1.c
+++ b/liblwgeom/gserialized1.c
@@ -29,6 +29,8 @@
 #include "lwgeodetic.h"
 #include "gserialized1.h"
+#include <stddef.h>
 * GSERIALIZED metadata utility functions.
@@ -113,9 +115,8 @@ int gserialized1_is_geodetic(const GSERIALIZED *gser)
 uint32_t gserialized1_max_header_size(void)
-	static const intptr_t size_of_gserialized_up_to_data = (intptr_t) & ((GSERIALIZED *)NULL)->data;
 	/* GSERIALIZED size + max bbox according gbox_serialized_size (XYZM*2) + extended flags + type */
-	return size_of_gserialized_up_to_data + 8 * sizeof(float) + sizeof(uint32_t);
+	return offsetof(GSERIALIZED, data) + 8 * sizeof(float) + sizeof(uint32_t);
 static uint32_t gserialized1_header_size(const GSERIALIZED *gser)
diff --git a/liblwgeom/gserialized2.c b/liblwgeom/gserialized2.c
index da6adb8..7967704 100644
--- a/liblwgeom/gserialized2.c
+++ b/liblwgeom/gserialized2.c
@@ -47,6 +47,8 @@
 #include "gserialized2.h"
@@ -175,9 +177,8 @@ int gserialized2_is_geodetic(const GSERIALIZED *g)
 uint32_t gserialized2_max_header_size(void)
-	return size_of_gserialized_up_to_data + 8 * sizeof(float) + sizeof(uint64_t) + sizeof(uint32_t);
+	return offsetof(GSERIALIZED, data) + 8 * sizeof(float) + sizeof(uint64_t) + sizeof(uint32_t);
Summary of changes:
 liblwgeom/gserialized1.c | 5 +++--
 liblwgeom/gserialized2.c | 5 +++--
 2 files changed, 6 insertions(+), 4 deletions(-)
hooks/post-receive
