[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-46-g93bb425
git at osgeo.org
git at osgeo.org
Mon Mar 23 14:05:41 PDT 2020
the project "PostGIS".
via 93bb425c61fbfcef9d830a10b61aa74305114efc (commit)
from 079e807123b8086f05416bba82305151df8a0ff0 (commit)
revisions in full, below.
commit 93bb425c61fbfcef9d830a10b61aa74305114efc
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Mar 23 22:04:37 2020 +0100
Do not test upgrades with of postgis backed views on PG<12
See #4386
diff --git a/regress/run_test.pl b/regress/run_test.pl
index c3412e3..dd7cdb0 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -244,6 +244,7 @@ else
+my $pgvernum = sql("SELECT current_setting('server_version_num')");
my $libver = sql("select postgis_lib_version()");
my $defextver = sql("select default_version from pg_available_extensions where name = 'postgis'");
@@ -313,13 +314,23 @@ sub create_upgrade_test_objects
- my $query = "create view upgrade_view_test as ";
- $query .= "select st_union(g1) from upgrade_test;";
- my $ret = sql($query);
- unless ( $ret =~ /^CREATE/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong creating upgrade_view_test view: $ret.\n";
- exit(1);
+ if ( $pgvernum >= 120000 ) {
+ # We know upgrading with an st_union() based view
+ # fails unless you're on PostgreSQL 12, so we don't
+ # even try that.
+ # We could re-enable this test IF we fix the upgrade
+ # in pre-12 versions. Refer to
+ # https://trac.osgeo.org/postgis/ticket/4386
+ $query = "create view upgrade_view_test as ";
+ $query .= "select st_union(g1) from upgrade_test;";
+ my $ret = sql($query);
+ unless ( $ret =~ /^CREATE/ ) {
+ `dropdb $DB`;
+ print "\nSomething went wrong creating upgrade_view_test view: $ret.\n";
+ exit(1);
if ( $OPT_WITH_RASTER )
@@ -358,7 +369,7 @@ sub drop_upgrade_test_objects
# TODO: allow passing the "upgrade-cleanup" script via commandline
- my $ret = sql("drop view upgrade_view_test;");
+ my $ret = sql("drop view if exists upgrade_view_test;");
unless ( $ret =~ /^DROP/ ) {
`dropdb $DB`;
print "\nSomething went wrong dropping spatial view: $ret.\n";
Summary of changes:
regress/run_test.pl | 27 +++++++++++++++++++--------
1 file changed, 19 insertions(+), 8 deletions(-)
hooks/post-receive
