[postgis-tickets] [PostGIS] #4655: TIGER 'addrfeat' table definition vs. current 2019 shapefiles
trac at osgeo.org
Sun Mar 29 10:03:00 PDT 2020
Reporter: jlrobins | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 3.0.x
Keywords: |
I'm bootstrapping a PostGIS 3.0.1, PostgreSQL 12.2, TIGER 2019 database
from scratch against all possible layers for the southeast US. I've met an
ounce of resistance when trying to load the 'addrfeat' layer for FL, which
happened to be my first state. The following section of the results of
SELECT loader_generate_script(ARRAY['FL','NC', 'SC', 'GA'],'sh');`
${PSQL} -c "CREATE TABLE tiger_data.FL_addrfeat(CONSTRAINT pk_FL_addrfeat
PRIMARY KEY (gid)) INHERITS(tiger.addrfeat);ALTER TABLE
tiger_data.FL_addrfeat ALTER COLUMN statefp SET DEFAULT '12';"
for z in *addrfeat*.dbf; do
${SHP2PGSQL} -D -S -D -s 4269 -g the_geom -W "latin1" $z
tiger_staging.FL_addrfeat | ${PSQL}
${PSQL} -c "SELECT loader_load_staged_data(lower('FL_addrfeat'),
lower('FL_addrfeat'));"
done
ends up croaking within the `loader_load_staged_data()` call due to a
mismatch in columns from the shapefile vs. columns in base table
`addrfeat`:
ALTER TABLE
Shapefile type: Arc
Postgis type: LINESTRING[2]
SET
SET
BEGIN
CREATE TABLE
ALTER TABLE
addgeometrycolumn
tiger_staging.fl_addrfeat.the_geom SRID:4269 TYPE:LINESTRING DIMS:2
(1 row)
COPY 32505
COMMIT
ANALYZE
NOTICE: INSERT INTO
tiger_data.fl_addrfeat(aridl,aridr,edge_mtfcc,fullname,lfromhn,lfromtyp,linearid,ltohn,ltotyp,offsetl,offsetr,parityl,parityr,plus4l,plus4r,rfromhn,rfromtyp,rtohn,rtotyp,the_geom,tlid,zipl,zipr)
SELECT
aridl,aridr,edge_mtfcc,fullname,lfromhn,lfromtyp,linearid,ltohn,ltotyp,offsetl,offsetr,parityl,parityr,plus4l,plus4r,rfromhn,rfromtyp,road_mtfcc,rtohn,rtotyp,tfidl,tfidr,the_geom,tlid,zipl,zipr
FROM tiger_staging.fl_addrfeat;
ERROR: INSERT has more expressions than target columns
LINE 1: ...mtyp,road_mtfcc,rtohn,rtotyp,tfidl,tfidr,the_geom,tlid,zipl,...
QUERY: INSERT INTO
SELECT
CONTEXT: PL/pgSQL function loader_load_staged_data(text,text,text[]) line
26 at EXECUTE
SQL function "loader_load_staged_data" statement 1
shp2pgsql from the shapefile within
`https://www2.census.gov/geo/tiger/TIGER2019/ADDRFEAT/tl_2019_13001_addrfeat.zip`
has 3 columns not present in base table `addrfeat`:
CREATE TABLE "tl_2019_12001_addrfeat" (
"tfidl" int8,
"tfidr" int8,
"road_mtfcc" varchar(5),
When I adjust tiger_geocoder.sql.in's definition of `addrfeat` with how I
see `tfidl`, `tfidr`, and similar concept `edge_mtfcc` modeled:
CREATE TABLE addrfeat
tfidl numeric(10),
tfidr numeric(10),
road_mtfcc character varying(5),
Then initial population proceeds past this point.
I've not yet explored what an 'mftcc' is, but there are at least some
differences in road_ vs. edge_ values in FL:
tiger=# select (edge_mtfcc = road_mtfcc) as same_mtfcc_value, count(*)
from tiger_data.fl_addrfeat group by 1 order by 2 desc;
same_mtfcc_value | count
t | 1268547
f | 2615
(2 rows)
tiger=# select gid, edge_mtfcc, road_mtfcc from tiger_data.fl_addrfeat
where edge_mtfcc != road_mtfcc order by 1, 2, 3 limit 5;
gid | edge_mtfcc | road_mtfcc
1180 | P0001 | S1400
16533 | P0001 | S1200
16534 | P0001 | S1200
36457 | P0001 | S1200
36500 | P0001 | S1400
(5 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4655>
