[postgis-tickets] [PostGIS] #4654: Analyze regress tests with valgrind
trac at osgeo.org
Mon Mar 30 14:14:09 PDT 2020
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: new
Priority: high | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Resolution: | Keywords:
Description changed by Algunenano:
Old description:
> After https://trac.osgeo.org/postgis/ticket/4652 it seems obvious to me
> there is a need to run the regression tests, either once or ideally as
> part of the CI, under valgrind to detect issues.
> I've done a test and got multiple worrisome errors
> There are some around computing stats:
> mar 27 20:25:24 Mordor postgres[396099]: ==396099== Conditional jump or
> move depends on uninitialised value(s)
> mar 27 20:25:24 Mordor postgres[396099]: ==396099== at 0x813D16B:
> gbox_is_valid (gbox.c:221)
> mar 27 20:25:24 Mordor postgres[396099]: ==396099== by 0x80C864B:
> compute_gserialized_stats_mode (gserialized_estimate.c:1469)
> mar 27 20:25:24 Mordor postgres[396099]: ==396099== by 0x3FCD5A:
> do_analyze_rel (analyze.c:529)
> mar 27 20:25:24 Mordor postgres[396099]: ==396099== by 0x3FBC9C:
> analyze_rel (analyze.c:260)
> mar 27 20:25:24 Mordor postgres[396099]: ==396099== by 0x4BF51E:
> vacuum (vacuum.c:413)
> mar 27 20:25:24 Mordor postgres[396099]: ==396099== by 0x4BEDA6:
> ExecVacuum (vacuum.c:199)
> mar 27 20:25:24 Mordor postgres[396099]: ==396099== by 0x745296:
> standard_ProcessUtility (utility.c:670)
> mar 27 20:25:24 Mordor postgres[396099]: ==396099== by 0x744933:
> ProcessUtility (utility.c:360)
> mar 27 20:25:24 Mordor postgres[396099]: ==396099== by 0x74426A:
> PortalRunUtility (pquery.c:1175)
> mar 27 20:25:24 Mordor postgres[396099]: ==396099== by 0x7434A1:
> PortalRunMulti (pquery.c:1321)
> mar 27 20:25:24 Mordor postgres[396099]: ==396099== by 0x742ADD:
> PortalRun (pquery.c:796)
> mar 27 20:25:24 Mordor postgres[396099]: ==396099== by 0x73DFD2:
> exec_simple_query (postgres.c:1215)
> mar 27 20:21:18 Mordor postgres[395155]: ==395155== Conditional jump or
> mar 27 20:21:18 Mordor postgres[395155]: ==395155== at 0x81184B1:
> next_float_down (lwgeom_api.c:63)
> mar 27 20:21:18 Mordor postgres[395155]: ==395155== by 0x813E720:
> gbox_float_round (gbox.c:784)
> mar 27 20:21:18 Mordor postgres[395155]: ==395155== by 0x8141584:
> gserialized2_get_gbox_p (gserialized2.c:601)
> mar 27 20:21:18 Mordor postgres[395155]: ==395155== by 0x80C861B:
> compute_gserialized_stats_mode (gserialized_estimate.c:1457)
> mar 27 20:21:18 Mordor postgres[395155]: ==395155== by 0x80C6351:
> compute_gserialized_stats (gserialized_estimate.c:1871)
> mar 27 20:21:18 Mordor postgres[395155]: ==395155== by 0x3FCD5A:
> mar 27 20:21:18 Mordor postgres[395155]: ==395155== by 0x3FBC9C:
> mar 27 20:21:18 Mordor postgres[395155]: ==395155== by 0x4BF51E:
> mar 27 20:21:18 Mordor postgres[395155]: ==395155== by 0x4BEDA6:
> mar 27 20:21:18 Mordor postgres[395155]: ==395155== by 0x745296:
> mar 27 20:21:18 Mordor postgres[395155]: ==395155== by 0x744933:
> mar 27 20:21:18 Mordor postgres[395155]: ==395155== by 0x74426A:
> This one seem like a cast:
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== Conditional jump or
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== at 0x813D39B:
> gbox_merge (gbox.c:276)
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== by 0x81470E9:
> lwcollection_calculate_gbox_geodetic (lwgeodetic.c:3020)
> lwgeom_calculate_gbox_geodetic (lwgeodetic.c:3056)
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== by 0x81418E0:
> gserialized2_from_lwgeom (gserialized2.c:1179)
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== by 0x8109068:
> geography_serialize (lwgeom_pg.c:305)
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== by 0x80CAA3E:
> gserialized_geography_from_lwgeom (geography_inout.c:115)
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== by 0x80CAB91:
> geography_in (geography_inout.c:177)
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== by 0x9240F5:
> InputFunctionCall (fmgr.c:1548)
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== by 0x9244C7:
> OidInputFunctionCall (fmgr.c:1651)
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== by 0x3E867A:
> stringTypeDatum (parse_type.c:659)
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== by 0x3C2459:
> coerce_type (parse_coerce.c:304)
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== by 0x3C1E25:
> coerce_to_target_type (parse_coerce.c:103)
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== by 0x3E4770:
> transformAssignedExpr (parse_target.c:577)
> mar 27 20:23:26 Mordor postgres[395843]: ==395843== at 0x813D3AC:
> gbox_merge (gbox.c:277)
> Right now I get quite a bit of warnings from Postgresql syscalls (mostly
> the same one repeated over and over), so I first need to filter those
> out, and then find errors and match them with the queries that triggered
> them.
> The tests become really slow under valgrind, so I'm not sure how to best
> approach them (probably test each file independently).
New description:
mar 27 20:25:24 Mordor postgres[396099]: ==396099== by 0x4BF51E: vacuum
(vacuum.c:413)
mar 27 20:21:18 Mordor postgres[395155]: ==395155== by 0x4BF51E: vacuum
(vacuum.c:413)
the same one repeated over and over), so I first need to filter those out,
and then find errors and match them with the queries that triggered them.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4654#comment:2>
