[postgis-tickets] [PostGIS] #4785: Proj master branch (7.2.0) rergess failuers
trac at osgeo.org
Thu Nov 5 02:29:46 PST 2020
Reporter: Taro Matsuzawa | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Algunenano):
I've just built PROJ 7.2 branch (with proj-data-1.3) and I can't reproduce
the behaviour change:
Version:
# Select postgis_full_version();
POSTGIS="3.1.0dev 968b3478f" [EXTENSION] PGSQL="120" GEOS="3.9.0dev-
CAPI-1.14.0" PROJ="7.2.0" GDAL="GDAL 3.0.4, released 202
0/01/28" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)" (core procs from "3.1.0dev 740dab0bc" ne
ed upgrade) TOPOLOGY (topology procs from "3.1.0dev a313c9e22" need
upgrade) RASTER (raster procs from "3.1.0dev 740dab0bc" n
eed upgrade)
(1 row)
Query:
# select '#1580.2', ST_Transform('SRID=4326;POINT(180 90)'::geometry,
3395);
ERROR: transform: tolerance condition error (-20)
Rebuilding with master/HEAD (8.0.0) does show the new behaviour:
CAPI-1.14.0" PROJ="8.0.0" GDAL="GDAL 3.0.4, released 202
eed upgrade)
(1 row)
3395);
?column? | st_transform
#1580.2 | 0101000020430D000093107C45F81B7341B97937FF14E8AC41
Before doing any change, since 8.0 is unreleased (and 7.2 was released a
few days ago), we should confirm with upstream whether this is intended or
not.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4785#comment:1>
