[postgis-tickets] [PostGIS] #4792: ST_Transform crashes server (windows)
trac at osgeo.org
Mon Nov 16 18:53:18 PST 2020
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by robe):
sadly crashes with proj 7.1.1 too if I misstate PROJ_LIB.
Thread 1 received signal SIGSEGV, Segmentation fault.
[Switching to Thread 8320.0x1d04]
0x000000000819ec70 in
libproj-19!_ZNK5osgeo4proj2io16AuthorityFactory15databaseContextEv ()
from C:\ming64gcc81\projects\proj\rel-7.1.1w64gcc81\bin\libproj-19.dll
(gdb) bt
#0 0x000000000819ec70 in
#1 0x000000000815be0e in
libproj-19!_ZN5osgeo4proj9operation26CoordinateOperationFactory7Private34createOperationsCompoundToCompoundERKN7dropbox6oxygen2nnISt10shared_ptrINS0_3crs3CRSEEEESD_RNS3_7ContextEPKNS8_11CompoundCRSESI_RSt6vectorINS6_IS7_INS1_19CoordinateOperationEEEESaISM_EE
#2 0x0000000008154648 in
libproj-19!_ZN5osgeo4proj9operation26CoordinateOperationFactory7Private16createOperationsERKN7dropbox6oxygen2nnISt10shared_ptrINS0_3crs3CRSEEEESD_RNS3_7ContextE
#3 0x000000000815d399 in
libproj-19!_ZNK5osgeo4proj9operation26CoordinateOperationFactory16createOperationsERKN7dropbox6oxygen2nnISt10shared_ptrINS0_3crs3CRSEEEESC_RKNS5_ISt10unique_ptrINS1_26CoordinateOperationContextESt14default_deleteISE_EEEE
#4 0x00000000081cbc98 in proj_create_operations ()
#5 0x000000000824033b in proj_create_crs_to_crs_from_pj ()
#6 0x00000000082407ed in proj_create_crs_to_crs ()
#7 0x000000006f009b6b in AddToPROJSRSCache (srid_to=5500, srid_from=7406,
PROJCache=0x7fcfaf8, fcinfo=0x7fcf448) at lwgeom_transform.c:397
#8 GetPJUsingFCInfo (fcinfo=fcinfo at entry=0x7fcf448, srid_from=7406,
srid_to=srid_to at entry=5500, pj=pj at entry=0x4d7e6a8)
at lwgeom_transform.c:505
#9 0x000000006efe43f9 in transform (fcinfo=0x7fcf448)
at lwgeom_transform.c:76
#10 0x00000000005ed01e in ExecInterpExpr (state=0x7fcf358,
econtext=0x7fcf598, isnull=<optimized out>) at execExprInterp.c:699
#11 0x00000000006bf1e1 in ExecEvalExprSwitchContext (isNull=0x4d7e7dc,
econtext=<optimized out>, state=0x7fcf358)
at ../../../../src/include/executor/executor.h:313
#12 evaluate_expr (expr=<optimized out>,
result_type=result_type at entry=798902,
result_typmod=result_typmod at entry=-1,
result_collation=result_collation at entry=0) at clauses.c:4792
#13 0x00000000006c0a98 in evaluate_function (context=0x4d7eec0,
func_tuple=0x7f4f3b0, funcvariadic=false, args=0x7fea5b0,
input_collid=0,
result_collid=0, result_typmod=-1, result_type=798902, funcid=799233)
at clauses.c:4323
#14 simplify_function (funcid=799233, result_type=798902,
result_typmod=-1,
result_collid=result_collid at entry=0,
input_collid=input_collid at entry=0,
args_p=args_p at entry=0x4d7e9c0, funcvariadic=funcvariadic at entry=false,
process_args=process_args at entry=true,
allow_non_const=allow_non_const at entry=true,
context=context at entry=0x4d7eec0) at clauses.c:3953
#15 0x00000000006bf5f2 in eval_const_expressions_mutator (node=0x7fe9ab8,
context=0x4d7eec0) at clauses.c:2507
#16 0x000000000065f8e5 in expression_tree_mutator (node=0x7fe9b10,
mutator=mutator at entry=0x6bf280 <eval_const_expressions_mutator>,
context=context at entry=0x4d7eec0) at nodeFuncs.c:3059
#17 0x00000000006c10f9 in simplify_function (funcid=799486,
result_type=25,
result_typmod=-1, result_collid=result_collid at entry=100,
input_collid=input_collid at entry=0, args_p=args_p at entry=0x4d7ec00,
context=context at entry=0x4d7eec0) at clauses.c:3944
#18 0x00000000006bf5f2 in eval_const_expressions_mutator (node=0x7fe9cc8,
#19 0x000000000065ef04 in expression_tree_mutator
(node=node at entry=0x7fe9d20,
context=context at entry=0x4d7eec0) at nodeFuncs.c:3180
#20 0x00000000006bf2d2 in eval_const_expressions_mutator (node=0x7fe9d20,
context=0x4d7eec0) at clauses.c:3572
#21 0x000000000065f8e5 in expression_tree_mutator
(node=node at entry=0x7fe9d78,
#22 0x00000000006bf2d2 in eval_const_expressions_mutator (node=0x7fe9d78,
context=context at entry=0x4d7eec0) at clauses.c:3572
#23 0x00000000006c0904 in eval_const_expressions
(root=root at entry=0x7fe9e80,
node=<optimized out>) at clauses.c:2299
#24 0x00000000006a4208 in preprocess_expression
expr=<optimized out>, kind=kind at entry=1) at planner.c:1094
#25 0x00000000006abe14 in subquery_planner (glob=glob at entry=0x7675570,
parse=<optimized out>, parse at entry=0x7675688,
parent_root=parent_root at entry=0x0,
hasRecursion=hasRecursion at entry=false,
tuple_fraction=tuple_fraction at entry=0) at planner.c:771
#26 0x00000000006ad7ef in standard_planner (parse=0x7675688,
query_string=<optimized out>, cursorOptions=256,
boundParams=<optimized out>) at planner.c:405
#27 0x00000000007825ea in pg_plan_query (querytree=0x7675688,
query_string=0x7674200 "SELECT ST_Astext(\n ST_Transform(\n",
' ' <repeats 11 times>, "ST_SetSRID(geometry('POINT(-100 40 100)'),7406),
\n", ' ' <repeats 11 times>, "5500));\n", ' ' <repeats 21 times>,
cursorOptions=256,
boundParams=0x0) at postgres.c:875
#28 0x00000000007826f1 in pg_plan_queries (querytrees=0x7fe9e28,
query_string=query_string at entry=0x7674200 "SELECT ST_Astext(\n
ST_Transform(\n", ' ' <repeats 11 times>, "ST_SetSRID(geometry('POINT(-100
40 100)'),7406), \n", ' ' <repeats 11 times>, "5500));\n", ' ' <repeats 21
times>,
cursorOptions=cursorOptions at entry=256,
boundParams=boundParams at entry=0x0)
at postgres.c:966
#29 0x0000000000782a80 in exec_simple_query (
\n", ' ' <repeats 11 times>, "5500));\n", ' ' <repeats 21 times>) at
postgres.c:1158
#30 0x00000000007844b9 in PostgresMain (argc=<optimized out>,
argv=argv at entry=0x76003e8, dbname=<optimized out>,
username=<optimized out>) at postgres.c:4315
#31 0x00000000006f9cde in BackendRun (port=0x4d7f7c0, port=0x4d7f7c0)
at postmaster.c:4536
#32 SubPostmasterMain (argc=argc at entry=3, argv=argv at entry=0x5af6ba0)
at postmaster.c:5059
#33 0x00000000009123cf in main (argc=3, argv=0x5af6ba0) at main.c:187
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4792#comment:5>
