[postgis-tickets] [PostGIS] #4793: ST_IsSolid returns false after using ST_MakeSolid with a closed polyhedral surface
PostGIS trac at osgeo.org
Tue Nov 17 02:52:24 PST 2020
surface
 Reporter:  basilrabi  |      Owner:  colivier
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS SFCGAL
Component:  sfcgal     |    Version:  3.0.x
 Keywords:             |
 # POSTGIS="3.0.2 2fb2a18" [EXTENSION] PGSQL="130" GEOS="3.7.1-CAPI-1.11.1
 27a5e771" SFCGAL="1.3.6" PROJ="Rel. 5.2.0, September 15th, 2018"
 GDAL="GDAL 2.4.0, released 2018/12/14" LIBXML="2.9.4" LIBJSON="0.12.1"
 LIBPROTOBUF="1.3.1" WAGYU="0.4.3 (Internal)" TOPOLOGY RASTER
 WITH cte AS (
     SELECT ST_MakeSolid(
         ST_Extrude(
             ST_Translate(
                 ST_Force3D(
                     ST_GeomFromText('POLYGON ((-1 1,1 1,1 -1,-1 -1,-1
 1))')
                 0, 0, -1
             0, 0, 2
     ) geom
 SELECT
     ST_IsSolid(geom),
     ST_IsClosed(geom),
     ST_Volume(geom)
 FROM cte
 The code above returns false, true, 8. I could be wrong but based on my
 understanding in the manual, this should return true, true, 8.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4793>
