[postgis-tickets] [PostGIS] #4766: GDAL_DATA not found for windows with GDAL 3.0.4 and iconv failures and missing curl
trac at osgeo.org
Tue Nov 17 11:15:22 PST 2020
missing curl
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS Packaging
Component: build/upgrade/install | Version: 3.0.x
Resolution: | Keywords: windows
Changes (by robe):
* milestone: PostGIS 3.0.3 => PostGIS Packaging
Comment:
Flipping this to a packaging problem. FWIW I will be shipping PostGIS
3.0.3 with GDAL 3.2.0 and Proj 7.1.1 and adding in an env to register the
PROJ_LIB path.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4766#comment:3>
