[postgis-tickets] [PostGIS] #4795: Fix tests on PostGIS 3.0 so they pass for GEOS 3.9 and GDAL 3.2.0 (was: Fix tests on PostGIS 3.0 so they pass for GEOS 3.9)
trac at osgeo.org
Fri Nov 20 13:14:31 PST 2020
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.3
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by robe):
Also saw failure on rt_gdal_warp postgres test when testing against GDAL
3.2.0 released. backporting change from 3.1.0 to 3.0.3 to fix.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4795#comment:2>
