[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-4-gd8fb00c
git at osgeo.org
git at osgeo.org
Thu Nov 26 16:10:15 PST 2020
the project "PostGIS".
via d8fb00c553417d04860256ca5e2be2390248f7e2 (commit)
from 1ba9345694db6de6e648c10fe7dba2028e67a201 (commit)
revisions in full, below.
commit d8fb00c553417d04860256ca5e2be2390248f7e2
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Nov 26 16:09:15 2020 -0800
Add ST_ReducePrecision for GEOS 3.9+.
Uses GEOS setPrecision CAPI routine to round coordinates
to grid while retaining a fully valid output.
diff --git a/NEWS b/NEWS
index 2c0318d..866b944 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,7 @@ Only tickets not included in 3.1.0alpha3
* New features*
- #4801, ST_ClusterKMeans supports weights in POINT[Z]M geometries (Darafei Praliaskouski)
+ - #4804, ST_ReducePrecision (GEOS 3.9+) allows valid precision reduction (Paul Ramsey)
PostGIS 3.1.0alpha3
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index dbd34e7..c71dc0d 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -2652,6 +2652,64 @@ SELECT ST_AsEWKT(ST_PointOnSurface(ST_GeomFromEWKT('LINESTRING(0 5 1, 0 0 1, 0 1
</refsection>
</refentry>
+ <refentry id="ST_ReducePrecision">
+ <refnamediv>
+ <refname>ST_ReducePrecision</refname>
+ <refpurpose>Returns a valid geometry with all points rounded to the provided grid tolerance, and features below the tolerance removed.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>geometry <function>ST_ReducePrecision</function></funcdef>
+ <paramdef><type>geometry </type>
+ <parameter>g</parameter></paramdef>
+ <paramdef><type>float8 </type>
+ <parameter>gridsize</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Returns a valid geometry with all points rounded to the provided grid tolerance, and features below the tolerance removed.</para>
+ <para>Unlike <xref linkend="ST_SnapToGrid" /> the returned geometry will be valid, with no ring self-intersections or collapsed components.</para>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+ <programlisting>SELECT ST_AsText(ST_ReducePrecision('POINT(1.412 19.323)', 0.1));
+ st_astext
+ POINT(1.4 19.3)
+SELECT ST_AsText(ST_ReducePrecision('POINT(1.412 19.323)', 1.0));
+ st_astext
+ POINT(1 19)
+ SELECT ST_AsText(ST_ReducePrecision('POINT(1.412 19.323)', 10));
+ st_astext
+ POINT(0 20)
+</programlisting>
+ </refsection>
+ <refsection>
+ <title>See Also</title>
+ <para><xref linkend="ST_SnapToGrid" />, <xref linkend="ST_Simplify" />, <xref linkend="ST_SimplifyVW" /></para>
+ </refsection>
+ </refentry>
<refentry id="ST_RemoveRepeatedPoints">
<refnamediv>
<refname>ST_RemoveRepeatedPoints</refname>
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 57d7f32..a5ea431 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -2367,6 +2367,7 @@ LWGEOM *lwgeom_difference_prec(const LWGEOM *geom1, const LWGEOM *geom2, double
LWGEOM *lwgeom_symdifference(const LWGEOM* geom1, const LWGEOM* geom2);
LWGEOM *lwgeom_symdifference_prec(const LWGEOM* geom1, const LWGEOM* geom2, double gridSize);
LWGEOM *lwgeom_pointonsurface(const LWGEOM* geom);
+LWGEOM *lwgeom_reduceprecision(const LWGEOM* geom, double gridSize);
LWGEOM *lwgeom_centroid(const LWGEOM* geom);
LWGEOM *lwgeom_union(const LWGEOM *geom1, const LWGEOM *geom2);
LWGEOM *lwgeom_union_prec(const LWGEOM *geom1, const LWGEOM *geom2, double gridSize);
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index 1ca3f4f..c2a41ee 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -939,6 +939,42 @@ lwgeom_centroid(const LWGEOM* geom)
return result;
+LWGEOM*
+lwgeom_reduceprecision(const LWGEOM* geom, double gridSize)
+#if POSTGIS_GEOS_VERSION < 39
+ lwerror("Precision reduction requires GEOS-3.9 or higher");
+ return NULL;
+#else
+ LWGEOM* result;
+ int32_t srid = RESULT_SRID(geom);
+ uint8_t is3d = FLAGS_GET_Z(geom->flags);
+ GEOSGeometry *g1, *g3;
+ if (srid == SRID_INVALID) return NULL;
+ if (lwgeom_is_empty(geom))
+ return lwgeom_clone_deep(geom);
+ initGEOS(lwnotice, lwgeom_geos_error);
+ if (!(g1 = LWGEOM2GEOS(geom, AUTOFIX))) GEOS_FAIL();
+ g3 = GEOSGeom_setPrecision(g1, gridSize, 0);
+ if (!g3) GEOS_FREE_AND_FAIL(g1);
+ GEOSSetSRID(g3, srid);
+ if (!(result = GEOS2LWGEOM(g3, is3d)))
+ GEOS_FREE_AND_FAIL(g1);
+ GEOS_FREE(g1, g3);
+ return result;
+#endif
LWGEOM *
lwgeom_pointonsurface(const LWGEOM *geom)
diff --git a/liblwgeom/lwkmeans.c b/liblwgeom/lwkmeans.c
index c5c6a4e..aaac0d0 100644
--- a/liblwgeom/lwkmeans.c
+++ b/liblwgeom/lwkmeans.c
@@ -43,7 +43,7 @@ update_r(POINT4D *objs, int *clusters, uint32_t n, POINT4D *centers, uint32_t k)
int curr_cluster = 0;
/* Check all other cluster centers and find the nearest */
- for (int cluster = 1; cluster < k; cluster++)
+ for (int cluster = 1; cluster < (int)k; cluster++)
double distance = distance3d_sqr_pt4d_pt4d(&obj, ¢ers[cluster]);
if (distance < curr_distance)
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index ed5d27e..ae5aa75 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -1513,6 +1513,27 @@ Datum centroid(PG_FUNCTION_ARGS)
PG_RETURN_POINTER(result);
+Datum ST_ReducePrecision(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(ST_ReducePrecision);
+ GSERIALIZED *geom, *result;
+ LWGEOM *lwgeom, *lwresult;
+ double gridSize = PG_GETARG_FLOAT8(1);
+ geom = PG_GETARG_GSERIALIZED_P(0);
+ lwgeom = lwgeom_from_gserialized(geom);
+ lwresult = lwgeom_reduceprecision(lwgeom, gridSize);
+ lwgeom_free(lwgeom);
+ PG_FREE_IF_COPY(geom, 0);
+ if (!lwresult) PG_RETURN_NULL();
+ result = geometry_serialize(lwresult);
+ lwgeom_free(lwresult);
+ PG_RETURN_POINTER(result);
Datum ST_ClipByBox2d(PG_FUNCTION_ARGS);
PG_FUNCTION_INFO_V1(ST_ClipByBox2d);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 45b053a..5310d48 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3667,6 +3667,12 @@ CREATE OR REPLACE FUNCTION ST_Subdivide(geom geometry, maxvertices integer DEFAU
LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
_COST_HIGH;
+CREATE OR REPLACE FUNCTION ST_ReducePrecision(geom geometry, gridsize float8)
+ RETURNS geometry
+ AS 'MODULE_PATHNAME', 'ST_ReducePrecision'
+ LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+ _COST_MEDIUM;
-- ST_CleanGeometry / ST_MakeValid
diff --git a/regress/core/geos39.sql b/regress/core/geos39.sql
index 2d3dab4..8885fdd 100644
--- a/regress/core/geos39.sql
+++ b/regress/core/geos39.sql
@@ -37,3 +37,8 @@ WITH p AS (
SELECT 'mic-cte' AS name, ST_AsText(st_snaptogrid((ST_MaximumInscribedCircle(ply)).center,0.001))
FROM p;
+-- ST_ReducePrecision
+SELECT 'rp-1', ST_AsText(ST_ReducePrecision('POINT(1.412 19.323)', 0.1));
+SELECT 'rp-2', ST_AsText(ST_ReducePrecision('POINT(1.412 19.323)', 1.0));
+SELECT 'rp-3', ST_AsText(ST_ReducePrecision('POINT(1.412 19.323)', 10));
diff --git a/regress/core/geos39_expected b/regress/core/geos39_expected
index f538159..06ebbd4 100644
--- a/regress/core/geos39_expected
+++ b/regress/core/geos39_expected
@@ -5,3 +5,6 @@ mic-line|POINT(49.5117 49.5117)|POINT(50.5111 98.9796)|49.4779
mic-mpoint|POINT(48.584 49.9512)|POINT(99 98)|69.6453
mic-point|POINT(0 0)|POINT(0 0)|0.0000
mic-cte|POINT(49.512 49.512)
+rp-1|POINT(1.4 19.3)
+rp-2|POINT(1 19)
+rp-3|POINT(0 20)
Summary of changes:
NEWS | 1 +
doc/reference_processing.xml | 58 ++++++++++++++++++++++++++++++++++++++++++++
liblwgeom/liblwgeom.h.in | 1 +
liblwgeom/lwgeom_geos.c | 36 +++++++++++++++++++++++++++
liblwgeom/lwkmeans.c | 2 +-
postgis/lwgeom_geos.c | 21 ++++++++++++++++
postgis/postgis.sql.in | 6 +++++
regress/core/geos39.sql | 5 ++++
regress/core/geos39_expected | 3 +++
9 files changed, 132 insertions(+), 1 deletion(-)
hooks/post-receive
