[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-5-g3768f5e
git at osgeo.org
git at osgeo.org
Fri Nov 27 16:12:34 PST 2020
the project "PostGIS".
via 3768f5ece1fc6f57611b74e988fde2f3eba5cd67 (commit)
from d8fb00c553417d04860256ca5e2be2390248f7e2 (commit)
revisions in full, below.
commit 3768f5ece1fc6f57611b74e988fde2f3eba5cd67
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Nov 27 16:04:26 2020 -0800
Clean up doc Processing purpose lines
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index c71dc0d..63e8add 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -6,9 +6,8 @@
<refname>ST_Buffer</refname>
<refpurpose>
-(T)
Returns a geometry covering all points within a given distance
-from the input geometry.
+from a geometry.
</refpurpose>
</refnamediv>
@@ -633,8 +632,7 @@ SELECT ST_ClipByBox2D(the_geom, ST_MakeEnvelope(0,0,10,10)) FROM mytab;
<refentry id="ST_ConcaveHull">
<refnamediv>
<refname>ST_ConcaveHull</refname>
- <refpurpose>The concave hull of a geometry represents a possibly concave
- geometry that encloses all geometries within the set. You can think of it as shrink wrapping.</refpurpose>
+ <refpurpose>Computes a possibly concave geometry that encloses all geometries within the input.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -922,7 +920,7 @@ SELECT d.disease_type,
<refnamediv>
<refname>ST_CurveToLine</refname>
- <refpurpose>Converts a CIRCULARSTRING/CURVEPOLYGON/MULTISURFACE to a LINESTRING/POLYGON/MULTIPOLYGON</refpurpose>
+ <refpurpose>Converts a geometry containing curves to a linear geometry.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -1075,7 +1073,7 @@ st_astext
<refname>ST_DelaunayTriangles</refname>
<refpurpose>
-Return a Delaunay triangulation around the given input points.
+Returns a Delaunay triangulation around the given input points.
</refpurpose>
</refnamediv>
@@ -1327,13 +1325,64 @@ MULTIPOINT(-118.6 38.329 6,-118.58 38.38 5)</programlisting>
</refsection>
</refentry>
+ <refentry id="ST_FilterByM">
+ <refnamediv>
+ <refname>ST_FilterByM</refname>
+ <refpurpose>Filters vertex points based on their m-value</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>geometry <function>ST_FilterByM</function></funcdef>
+ <paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
+ <paramdef><type>double precision</type> <parameter>min</parameter></paramdef>
+ <paramdef><type>double precision</type> <parameter>max = null</parameter></paramdef>
+ <paramdef><type>boolean</type> <parameter>returnM = false</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Filters away vertex points based on their m-value. Returns a geometry with only
+ vertex points that have a m-value larger or equal to the min value and smaller or equal to
+ the max value. If max-value argument is left out only min value is considered. If fourth argument is left out the m-value
+ will not be in the resulting geometry. If resulting geometry have too few vertex points left for its geometry type an empty
+ geometry will be returned. In a geometry collection
+ geometries without enough points will just be left out silently.</para>
+ <para>This function is mainly intended to be used in conjunction with ST_SetEffectiveArea. ST_EffectiveArea sets the effective area
+ of a vertex in its m-value. With ST_FilterByM it then is possible to get a simplified version of the geometry without any calculations, just by filtering</para>
+ <note><para>There is a difference in what ST_SimplifyVW returns when not enough points meet the criteria compared to ST_FilterByM.
+ ST_SimplifyVW returns the geometry with enough points while ST_FilterByM returns an empty geometry</para></note>
+ <note><para>Note that the returned geometry might be invalid</para></note>
+ <note><para>This function returns all dimensions, also the z and m-value</para></note>
+ <para>Availability: 2.5.0</para>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+ <para>A linestring is filtered</para>
+ <programlisting>
+SELECT ST_AsText(ST_FilterByM(geom,30)) simplified
+FROM (SELECT ST_SetEffectiveArea('LINESTRING(5 2, 3 8, 6 20, 7 25, 10 10)'::geometry) geom) As foo;
+-result
+ simplified
+ LINESTRING(5 2,7 25,10 10)
+ </programlisting>
+ </refsection>
+ <refsection>
+ <title>See Also</title>
+ <para><xref linkend="ST_SetEffectiveArea" />, <xref linkend="ST_SimplifyVW" /></para>
+ </refsection>
+ </refentry>
<refentry id="ST_FlipCoordinates">
<refnamediv>
<refname>ST_FlipCoordinates</refname>
- <refpurpose>Returns a version of the given geometry with
- X and Y axis flipped. Useful for people
- who have built latitude/longitude features
- and need to fix them.</refpurpose>
+ <refpurpose>Returns a version of a geometry with X and Y axis flipped. </refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -1347,7 +1396,8 @@ MULTIPOINT(-118.6 38.329 6,-118.58 38.38 5)</programlisting>
<refsection>
- <para>Returns a version of the given geometry with X and Y axis flipped.</para>
+ <para>Returns a version of the given geometry with X and Y axis flipped.
+ Useful for fixing geometries which contain coordinates expressed as latitude/longitude (Y,X).</para>
<para>Availability: 2.0.0</para>
<para>&curve_support;</para>
<para>&Z_support;</para>
@@ -1601,7 +1651,6 @@ FROM test;
<refname>ST_Intersection</refname>
<refpurpose>
-(T)
Returns a geometry that represents the shared portion of geomA and geomB.
</refpurpose>
</refnamediv>
@@ -1731,7 +1780,7 @@ from ST_GeomFromText('LINESTRING Z (2 2 6,1.5 1.5 7,1 1 8,0.5 0.5 8,0 0 10)') A
<refnamediv>
<refname>ST_LineToCurve</refname>
- <refpurpose>Converts a LINESTRING/POLYGON to a CIRCULARSTRING, CURVEPOLYGON</refpurpose>
+ <refpurpose>Converts a linear geometry to a curved geometry.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -1966,7 +2015,7 @@ FROM (SELECT 'MULTIPOLYGON(((186 194,187 194,188 195,189 195,190 195,
<refentry id="ST_MaximumInscribedCircle">
<refnamediv>
<refname>ST_MaximumInscribedCircle</refname>
- <refpurpose>Finds the largest circle that can by fully contained within a geometry. Returns a record with the center point of that circle, the point on the geometry that is nearest to the center, and the radius of the circle.</refpurpose>
+ <refpurpose>Finds the largest circle that can by fully contained within a geometry. </refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -2027,8 +2076,7 @@ FROM (SELECT 'MULTIPOLYGON(((186 194,187 194,188 195,189 195,190 195,
<refentry id="ST_MinimumBoundingCircle">
<refnamediv>
<refname>ST_MinimumBoundingCircle</refname>
- <refpurpose>Returns the smallest circle polygon that can fully contain a geometry. Default
- uses 48 segments per quarter circle.</refpurpose>
+ <refpurpose>Returns the smallest circle polygon that fully contains a geometry.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -2099,7 +2147,7 @@ POLYGON((135.59714732062 115,134.384753327498 102.690357210921,130.79416296937 9
<refentry id="ST_MinimumBoundingRadius">
<refnamediv>
<refname>ST_MinimumBoundingRadius</refname>
- <refpurpose>Returns the center point and radius of the smallest circle that can fully contain a geometry.</refpurpose>
+ <refpurpose>Returns the center point and radius of the smallest circle that fullys contain a geometry.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -2209,9 +2257,8 @@ POLYGON((19.9999999999997 79.9999999999999,33.0769230769229 60.3846153846152,138
<refnamediv>
<refname>ST_Polygonize</refname>
- <refpurpose>Aggregate. Creates a GeometryCollection containing possible
- polygons formed from the constituent linework of a set of
- geometries.</refpurpose>
+ <refpurpose>Computes a collection of polygons formed from the linework of a set of geometries.
+ </refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -2292,7 +2339,7 @@ geomtextrep
<refname>ST_Node</refname>
<refpurpose>
-Node a set of linestrings.
+Nodes a set of linestrings.
</refpurpose>
</refnamediv>
@@ -2350,7 +2397,7 @@ MULTILINESTRING Z ((0 0 0,5 5 4.5),(5 5 4.5,10 10 10,0 10 5,5 5 4.5),(5 5 4.5,10
<refname>ST_OffsetCurve</refname>
<refpurpose>
-Return an offset line at a given distance and side from an input line. Useful for computing parallel lines about a center line
+Returns an offset line at a given distance and side from an input line.
</refpurpose>
</refnamediv>
@@ -2374,11 +2421,12 @@ Return an offset line at a given distance and side from an input line. Useful fo
All points of the returned geometries are not further than the given
distance from the input geometry.
+Useful for computing parallel lines about a center line.
</para>
<para>
-For positive distance the offset will be at the left side of the input line
-and retain the same direction. For a negative distance it'll be at the right
+For positive distance the offset is on the left side of the input line
+and retains the same direction. For a negative distance it is on the right
side and in the opposite direction.
</para>
<para>
@@ -2590,7 +2638,7 @@ MULTILINESTRING((164 1,11.7867965644036 1,1 11.7867965644036,1 195),
<refnamediv>
<refname>ST_PointOnSurface</refname>
- <refpurpose>Returns a <varname>POINT</varname> guaranteed to lie on the surface.</refpurpose>
+ <refpurpose>Returns a point guaranteed to lie in a polygon or on a geometry.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -2657,7 +2705,7 @@ SELECT ST_AsEWKT(ST_PointOnSurface(ST_GeomFromEWKT('LINESTRING(0 5 1, 0 0 1, 0 1
<refnamediv>
<refname>ST_ReducePrecision</refname>
- <refpurpose>Returns a valid geometry with all points rounded to the provided grid tolerance, and features below the tolerance removed.</refpurpose>
+ <refpurpose>Returns a valid geometry with all points rounded to the provided grid tolerance.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -2854,7 +2902,7 @@ MULTILINESTRING((76 175,90 161),(90 161,101 150),(126 125,126 156.25)))
<refnamediv>
<refname>ST_ShiftLongitude</refname>
- <refpurpose>Toggle geometry coordinates between -180..180 and 0..360 ranges.</refpurpose>
+ <refpurpose>Shifts a geometry with geographic coordinates between -180..180 and 0..360.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -2869,11 +2917,11 @@ MULTILINESTRING((76 175,90 161),(90 161,101 150),(126 125,126 156.25)))
<refsection>
- <para>Reads every point/vertex in every component of every feature
- in a geometry, and if the longitude coordinate is <0, adds 360
- to it. The result would be a 0-360 version of the data to be
+ <para>Reads every point/vertex in a geometry, and if the longitude coordinate is <0, adds 360
+ to it. The result is a 0-360 version of the data to be
plotted in a 180 centric map</para>
- <note><para>This is only useful for data in long lat e.g. 4326 (WGS 84 long lat)</para></note>
+ <note><para>This is only useful for data with coordinates in
+ longitude/latitude; e.g. SRID 4326 (WGS 84 geographic)</para></note>
<warning>
<para>Pre-1.3.4 bug prevented this from working for MULTIPOINT. 1.3.4+ works with MULTIPOINT as well.</para>
@@ -2981,7 +3029,7 @@ select ST_WrapX(the_geom, -30, 360);
<refentry id="ST_Simplify">
<refnamediv>
<refname>ST_Simplify</refname>
- <refpurpose>Returns a "simplified" version of the given geometry using
+ <refpurpose>Returns a simplified version of a geometry, using
the Douglas-Peucker algorithm.</refpurpose>
</refnamediv>
@@ -3044,9 +3092,8 @@ select ST_WrapX(the_geom, -30, 360);
<refentry id="ST_SimplifyPreserveTopology">
<refnamediv>
<refname>ST_SimplifyPreserveTopology</refname>
- the Douglas-Peucker algorithm. Will avoid creating derived
- geometries (polygons in particular) that are invalid.</refpurpose>
+ <refpurpose>Returns a simplified and valid version of a geometry, using
+ the Douglas-Peucker algorithm.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -3097,7 +3144,7 @@ FROM (SELECT ST_Buffer('POINT(1 3)', 10,12) As the_geom) As foo;
<refentry id="ST_SimplifyVW">
<refnamediv>
<refname>ST_SimplifyVW</refname>
- <refpurpose>Returns a "simplified" version of the given geometry using the Visvalingam-Whyatt algorithm</refpurpose>
+ <refpurpose>Returns a simplified version of a geometry, using the Visvalingam-Whyatt algorithm</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -3146,7 +3193,7 @@ LINESTRING(5 2,7 25,10 10)
<refentry id="ST_ChaikinSmoothing">
<refnamediv>
<refname>ST_ChaikinSmoothing</refname>
- <refpurpose>Returns a "smoothed" version of the given geometry using the Chaikin algorithm</refpurpose>
+ <refpurpose>Returns a smoothed version of a geometry, using the Chaikin algorithm</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -3196,68 +3243,11 @@ FROM (SELECT 'POLYGON((0 0, 8 8, 0 16, 0 0))'::geometry geom) As foo;
</refsection>
</refentry>
- <refentry id="ST_FilterByM">
- <refnamediv>
- <refname>ST_FilterByM</refname>
- <refpurpose>Filters vertex points based on their m-value</refpurpose>
- </refnamediv>
- <refsynopsisdiv>
- <funcsynopsis>
- <funcprototype>
- <funcdef>geometry <function>ST_FilterByM</function></funcdef>
- <paramdef><type>geometry</type> <parameter>geom</parameter></paramdef>
- <paramdef><type>double precision</type> <parameter>min</parameter></paramdef>
- <paramdef><type>double precision</type> <parameter>max = null</parameter></paramdef>
- <paramdef><type>boolean</type> <parameter>returnM = false</parameter></paramdef>
- </funcprototype>
- </funcsynopsis>
- </refsynopsisdiv>
- <refsection>
- <title>Description</title>
- <para>Filters away vertex points based on their m-value. Returns a geometry with only
- vertex points that have a m-value larger or equal to the min value and smaller or equal to
- the max value. If max-value argument is left out only min value is considered. If fourth argument is left out the m-value
- will not be in the resulting geometry. If resulting geometry have too few vertex points left for its geometry type an empty
- geometry will be returned. In a geometry collection
- geometries without enough points will just be left out silently.</para>
- <para>This function is mainly intended to be used in conjunction with ST_SetEffectiveArea. ST_EffectiveArea sets the effective area
- of a vertex in its m-value. With ST_FilterByM it then is possible to get a simplified version of the geometry without any calculations, just by filtering</para>
- <note><para>There is a difference in what ST_SimplifyVW returns when not enough points meet the criteria compared to ST_FilterByM.
- ST_SimplifyVW returns the geometry with enough points while ST_FilterByM returns an empty geometry</para></note>
- <note><para>Note that the returned geometry might be invalid</para></note>
- <note><para>This function returns all dimensions, also the z and m-value</para></note>
- <para>Availability: 2.5.0</para>
- </refsection>
- <refsection>
- <title>Examples</title>
- <para>A linestring is filtered</para>
- <programlisting>
-SELECT ST_AsText(ST_FilterByM(geom,30)) simplified
-FROM (SELECT ST_SetEffectiveArea('LINESTRING(5 2, 3 8, 6 20, 7 25, 10 10)'::geometry) geom) As foo;
--result
- simplified
- LINESTRING(5 2,7 25,10 10)
- </programlisting>
- </refsection>
- <refsection>
- <title>See Also</title>
- <para><xref linkend="ST_SetEffectiveArea" />, <xref linkend="ST_SimplifyVW" /></para>
- </refsection>
- </refentry>
<refentry id="ST_SetEffectiveArea">
<refnamediv>
<refname>ST_SetEffectiveArea</refname>
<refpurpose>
- Sets the effective area for each vertex, storing the value in the M ordinate. A simplified geometry can then be generated by filtering on the M ordinate.
+ Sets the effective area for each vertex, using the Visvalingam-Whyatt algorithm.
</refpurpose>
</refnamediv>
@@ -3487,8 +3477,7 @@ GEOMETRYCOLLECTION(
<refname>ST_SymDifference</refname>
<refpurpose>Returns a geometry that represents the portions of A and B
- that do not intersect. It is called a symmetric difference because
- ST_SymDifference(A,B) = ST_SymDifference(B,A).</refpurpose>
+ that do not intersect.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -3713,8 +3702,8 @@ LINESTRING(44.7994523421035 82.5156766227011,85 85)</screen>
<refentry id="ST_Union">
<refnamediv>
<refname>ST_Union</refname>
- <refpurpose>Returns a geometry that represents the point set union of
- the Geometries.</refpurpose>
+ <refpurpose>Returns a geometry that represents the point-set union of
+ the input geometries.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -3931,7 +3920,7 @@ on that same grid. This method requires GEOS-3.9.0 or higher.
<refnamediv>
<refname>ST_VoronoiLines</refname>
- <refpurpose>Returns the boundaries between the cells of the Voronoi diagram constructed from the vertices of a geometry.</refpurpose>
+ <refpurpose>Returns the boundaries of the Voronoi diagram constructed from the vertices of a geometry.</refpurpose>
</refnamediv>
<refsynopsisdiv>
Summary of changes:
doc/reference_processing.xml | 189 ++++++++++++++++++++-----------------------
1 file changed, 89 insertions(+), 100 deletions(-)
hooks/post-receive
