[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-390-gdb1d141
git at osgeo.org
git at osgeo.org
Tue Aug 10 17:13:50 PDT 2021
the project "PostGIS".
The branch, main has been updated
via db1d141fa287987a0526a1d9b08939ce523965cf (commit)
from b01f7eac5dd1bc7364859ae947e42f82efc7aa00 (commit)
revisions in full, below.
commit db1d141fa287987a0526a1d9b08939ce523965cf
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Aug 11 02:13:26 2021 +0200
GetFaceContainingPoint: reduce data access in some cases
diff --git a/topology/sql/query/GetFaceContainingPoint.sql.in b/topology/sql/query/GetFaceContainingPoint.sql.in
index 505d0c2..86c6337 100644
--- a/topology/sql/query/GetFaceContainingPoint.sql.in
+++ b/topology/sql/query/GetFaceContainingPoint.sql.in
@@ -109,38 +109,41 @@ BEGIN
-- dangling, we can return their common
-- side face, otherwise the point will be
-- on multiple face boundaries
+ -- early exit if the closest edge has
+ -- left_face != right_face, don't bother
+ -- fetching more edges
+ IF closestEdge.left_face != closestEdge.right_face THEN
+ RAISE EXCEPTION 'Two or more faces found';
+ END IF;
sql := format(
- WITH incident_edges AS (
- SELECT
- left_face,
- right_face
- FROM %1$I.edge_data
- WHERE start_node = $1
+ SELECT
+ left_face,
+ right_face
+ FROM %1$I.edge_data
+ WHERE (
+ start_node = $1
OR end_node = $1
- side_faces AS (
- SELECT left_face side_face
- FROM incident_edges
- UNION
- SELECT right_face
- SELECT array_agg(side_face) sideFaces
- FROM side_faces
+ AND (
+ left_face != $2
+ OR right_face != $2
+ LIMIT 1
atopology
#ifdef POSTGIS_TOPOLOGY_DEBUG
RAISE DEBUG 'SQL: %', sql;
#endif
- EXECUTE sql USING closestNode INTO rec;
- IF array_upper(rec.sideFaces, 1) > 1
+ EXECUTE sql USING closestNode, closestEdge.left_face INTO rec;
+ IF FOUND
THEN
- ELSE
- RETURN rec.sideFaces[1];
END IF;
+ RETURN closestEdge.left_face;
END IF; --} query point is the node
Summary of changes:
topology/sql/query/GetFaceContainingPoint.sql.in | 41 +++++++++++++-----------
1 file changed, 22 insertions(+), 19 deletions(-)
hooks/post-receive
