[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-396-gb4f0bee
Wed Aug 11 08:32:57 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  b4f0beefdc3bcd2ed555ce9da6f096655e875ec3 (commit)
      from  ab07f273d3f65fab1ff7f0c885b99d94b50d671e (commit)
revisions in full, below.
commit b4f0beefdc3bcd2ed555ce9da6f096655e875ec3
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Aug 11 16:39:01 2021 +0200
    Drop redundant getPoint2d_p_ro function
    Closes #4965
diff --git a/liblwgeom/gserialized.c b/liblwgeom/gserialized.c
index bed0386..1a66023 100644
--- a/liblwgeom/gserialized.c
+++ b/liblwgeom/gserialized.c
@@ -234,7 +234,7 @@ size_t gserialized_from_lwgeom_size(const LWGEOM *geom)
 * Allocate a new #LWGEOM from a #GSERIALIZED. The resulting #LWGEOM will have coordinates
-* that are double aligned and suitable for direct reading using getPoint2d_p_ro
+* that are double aligned and suitable for direct reading using getPoint2d_cp
 LWGEOM* lwgeom_from_gserialized(const GSERIALIZED *g)
diff --git a/liblwgeom/gserialized.h b/liblwgeom/gserialized.h
index 5ec53f7..6ca6e4f 100644
--- a/liblwgeom/gserialized.h
+++ b/liblwgeom/gserialized.h
@@ -149,7 +149,7 @@ size_t gserialized_from_lwgeom_size(const LWGEOM *geom);
 LWGEOM *lwgeom_from_gserialized(const GSERIALIZED *g);
diff --git a/liblwgeom/gserialized1.h b/liblwgeom/gserialized1.h
index 9506c57..e84b975 100644
--- a/liblwgeom/gserialized1.h
+++ b/liblwgeom/gserialized1.h
@@ -149,7 +149,7 @@ size_t gserialized1_from_lwgeom_size(const LWGEOM *geom);
 LWGEOM* lwgeom_from_gserialized1(const GSERIALIZED *g);
@@ -160,4 +160,4 @@ const float * gserialized1_get_float_box_p(const GSERIALIZED *g, size_t *ndims);
 int gserialized1_peek_gbox_p(const GSERIALIZED *g, GBOX *gbox);
-int gserialized1_peek_first_point(const GSERIALIZED *g, POINT4D *out_point);
\ No newline at end of file
+int gserialized1_peek_first_point(const GSERIALIZED *g, POINT4D *out_point);
diff --git a/liblwgeom/gserialized2.h b/liblwgeom/gserialized2.h
index c80a739..c703722 100644
--- a/liblwgeom/gserialized2.h
+++ b/liblwgeom/gserialized2.h
@@ -161,7 +161,7 @@ size_t gserialized2_from_lwgeom_size(const LWGEOM *geom);
 LWGEOM* lwgeom_from_gserialized2(const GSERIALIZED *g);
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index c074d8b..bbff3a3 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -830,7 +830,7 @@ extern GSERIALIZED* gserialized_from_lwgeom(LWGEOM *geom, size_t *size);
 extern LWGEOM* lwgeom_from_gserialized(const GSERIALIZED *g);
@@ -1930,12 +1930,6 @@ extern int lwgeom_calculate_gbox_cartesian(const LWGEOM *lwgeom, GBOX *gbox);
 extern int lwgeom_calculate_gbox(const LWGEOM *lwgeom, GBOX *gbox);
-* New function to read doubles directly from the double* coordinate array
-* of an aligned lwgeom #POINTARRAY (built by de-serializing a #GSERIALIZED).
-extern int getPoint2d_p_ro(const POINTARRAY *pa, uint32_t n, POINT2D **point);
 * Calculate geodetic (x/y/z) box and add values to gbox. Return #LW_SUCCESS on success.
 extern int ptarray_calculate_gbox_geodetic(const POINTARRAY *pa, GBOX *gbox);
diff --git a/liblwgeom/lwgeodetic.c b/liblwgeom/lwgeodetic.c
index 82e6c15..ea204fb 100644
--- a/liblwgeom/lwgeodetic.c
+++ b/liblwgeom/lwgeodetic.c
@@ -2873,24 +2873,6 @@ int lwline_covers_lwline(const LWLINE* lwline1, const LWLINE* lwline2)
 	return LW_TRUE;
-* This function can only be used on LWGEOM that is built on top of
-* GSERIALIZED, otherwise alignment errors will ensue.
-int getPoint2d_p_ro(const POINTARRAY *pa, uint32_t n, POINT2D **point)
-	uint8_t *pa_ptr = NULL;
-	assert(pa);
-	assert(n < pa->npoints);
-	pa_ptr = getPoint_internal(pa, n);
-	/* printf( "pa_ptr[0]: %g\n", *((double*)pa_ptr)); */
-	*point = (POINT2D*)pa_ptr;
-	return LW_SUCCESS;
 	uint32_t i;
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index b58c8b2..7994d60 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -1332,14 +1332,14 @@ int
 ptarray_closest_vertex_2d(const POINTARRAY *pa, const POINT2D *qp, double *dist)
 	uint32_t t, pn=0;
-	POINT2D *p;
+	const POINT2D *p;
 	double mindist = DBL_MAX;
 	/* Loop through pointarray looking for nearest segment */
 	for (t=0; t<pa->npoints; t++)
 		double dist_sqr;
-		getPoint2d_p_ro(pa, t, &p);
+		p = getPoint2d_cp(pa, t);
 		dist_sqr = distance2d_sqr_pt_pt(p, qp);
 		if (dist_sqr < mindist)
Summary of changes:
 liblwgeom/gserialized.c  |  2 +-
 liblwgeom/gserialized.h  |  2 +-
 liblwgeom/gserialized1.h |  4 ++--
 liblwgeom/gserialized2.h |  2 +-
 liblwgeom/liblwgeom.h.in |  8 +-------
 liblwgeom/lwgeodetic.c   | 18 ------------------
 liblwgeom/ptarray.c      |  4 ++--
 7 files changed, 8 insertions(+), 32 deletions(-)
hooks/post-receive
