[postgis-tickets] [PostGIS] #4967: Dronie PostgreSQL 9.5 PostGIS 2.5 compile / regress failing
trac at osgeo.org
Thu Aug 12 11:30:39 PDT 2021
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.6
Component: buildbots | Version: 2.5.x
Keywords: |
This might have something to do with my upgrade of trisquel about a month
ago, but still the error is puzzling:
https://dronie.osgeo.org/postgis/postgis/2028/1/2
Configure details
-------------- Compiler Info -------------
C compiler: gcc -O0 -Wall -fno-omit-frame-pointer -Werror
SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
-------------- Additional Info -------------
Interrupt Tests: DISABLED use: --with-interrupt-tests to enable
-------------- Dependencies --------------
GEOS config: /usr/local/bin/geos-config
GEOS version: 3.6.5
GDAL config: /usr/local/bin/gdal-config
GDAL version: 2.2.3
PostgreSQL config: /usr/lib/postgresql/9.5/bin/pg_config
PostgreSQL version: PostgreSQL 9.5.25
PROJ4 version: 49
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.9.3
JSON-C support: yes
protobuf-c support: yes
protobuf-c version: 1003000
PCRE support: no
Perl: /usr/bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
SFCGAL support: disabled
Address Standardizer support: disabled
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets: /usr/share/xml/docbook/stylesheet/docbook-xsl
dblatex:
convert: /usr/bin/convert
mathml2.dtd: /usr/share/xml/schema/w3c/mathml/dtd/mathml2.dtd
configure: WARNING: --------- GEOS VERSION WARNING ------------
configure: WARNING: You are building against GEOS 3.6.5
configure: WARNING: To take advantage of all the features of
configure: WARNING: this PostGIS version requires GEOS 3.7.0 or higher.
configure: WARNING: To take advantage of most of the features of this
configure: WARNING: we recommend GEOS 3.6 or higher
configure: WARNING: You can download the latest versions from
configure: WARNING: http://trac.osgeo.org/geos
configure: WARNING:
Error details:
gcc -I../liblwgeom -O0 -Wall -fno-omit-frame-pointer -Werror
-I/usr/include/postgresql/9.5/server -fPIC -DPIC -Wall -Wmissing-
prototypes -c -o lwgeom_cache.o lwgeom_cache.c
prototypes -c -o lwgeom_pg.o lwgeom_pg.c
lwgeom_transform.c:15:22: fatal error: postgres.h: No such file or
directory
compilation terminated.
Makefile:61: recipe for target 'lwgeom_transform.o' failed
make[1]: *** [lwgeom_transform.o] Error 1
make[1]: *** Waiting for unfinished jobs....
lwgeom_cache.c:13:22: fatal error: postgres.h: No such file or directory
make[1]: *** [lwgeom_cache.o] Error 1
lwgeom_pg.c:17:22: fatal error: postgres.h: No such file or directory
Makefile:61: recipe for target 'lwgeom_cache.o' failed
make[1]: *** [lwgeom_pg.o] Error 1
Makefile:61: recipe for target 'lwgeom_pg.o' failed
gserialized_gist.c:12:22: fatal error: postgres.h: No such file or
directory
make[1]: *** [gserialized_gist.o] Error 1
make: *** [all] Error 1
Makefile:61: recipe for target 'gserialized_gist.o' failed
make[1]: Leaving directory '/drone/src/libpgcommon'
GNUmakefile:16: recipe for target 'all' failed
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4967>
