[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-397-g6571dc8
git at osgeo.org
git at osgeo.org
Thu Aug 12 14:06:53 PDT 2021
the project "PostGIS".
The branch, main has been updated
via 6571dc8fde5cb396bfaf6db394f39b765535028c (commit)
from b4f0beefdc3bcd2ed555ce9da6f096655e875ec3 (commit)
revisions in full, below.
commit 6571dc8fde5cb396bfaf6db394f39b765535028c
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Aug 12 21:13:25 2021 +0200
Use angles to determine side of point on edge when closest is a vertex
Closes #4962 again
Includes regress test for getFaceContainingPoint
(failing without the change)
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 23b99c1..49aa52b 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -7182,6 +7182,8 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
lwerror("error computing azimuth of shortestLine [%.15g %.15g,%.15g %.15g]",
shortestLineP0->x, shortestLineP0->y,
shortestLineP1->x, shortestLineP1->y);
+ lwgeom_free(shortestLine);
+ _lwt_release_edges(closestEdge, 1);
return -1;
@@ -7193,10 +7195,12 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
if ( ! found ) {
lwerror("Unexpected backend return: _lwt_FindAdjacentEdges(%d) found no edges when we previously found edge %d ending on that node",
closestNode, closestEdge->edge_id);
return -1;
return ee.cwFace;
@@ -7209,6 +7213,7 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
if ( closestEdge->face_left == closestEdge->face_right )
containingFace = closestEdge->face_left;
return containingFace;
@@ -7217,6 +7222,7 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
if ( dist == 0 )
/* We checked the dangling case above */
lwerror("Two or more faces found");
return -1;
@@ -7225,11 +7231,11 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
/* find closest segment on closestEdge and use lw_segment_side
* to determine on which side our query point falls */
- shortestLineP0 = getPoint2d_cp(((LWLINE *)shortestLine)->points, 1);
- closestSegmentIndex = ptarray_closest_segment_2d(closestEdge->geom->points, shortestLineP0, NULL);
+ shortestLineP1 = getPoint2d_cp(((LWLINE *)shortestLine)->points, 1);
+ closestSegmentIndex = ptarray_closest_segment_2d(closestEdge->geom->points, shortestLineP1, NULL);
LWDEBUGF(1, "Closest segment to edge %d is %d", closestEdge->edge_id, closestSegmentIndex);
closestSegmentP0 = getPoint2d_cp(closestEdge->geom->points, closestSegmentIndex);
- closestSegmentP1 = getPoint2d_cp(closestEdge->geom->points, ++closestSegmentIndex);
+ closestSegmentP1 = getPoint2d_cp(closestEdge->geom->points, closestSegmentIndex + 1);
LWDEBUGF(1, "Closest segment to edge %d is LINESTRING(%g %g, %g %g)",
closestSegmentP0->x,
@@ -7239,11 +7245,94 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
/* Find on which side of the segment the query point lays */
+ shortestLineP0 = getPoint2d_cp(((LWLINE *)shortestLine)->points, 0);
+ if ( p2d_same(shortestLineP0, closestSegmentP0) )
+ /* Closest point is first point of closest segment (this should
+ * never happen as we'd have returned the previous segment in
+ * this case, unless it was the very first segment, and in that
+ * case we'd have cought this earlier, as it would be a NODE
+ * This would be more of an assert...
+ lwerror("Closest point is first point of closest segment, unexpectedly");
+ return -1;
+ else if ( p2d_same(shortestLineP0, closestSegmentP1) )
+ /* Closest point is last point of the closest segment,
+ * so we need to check if rotating the closest segment
+ * clockwise around its last point we encounter
+ * the shortestLine first (which means it's on the left
+ * of the closest edge) or the next segment first (which
+ * means the shortestLine is on the right)
+ const POINT2D *nextSegmentP0, *nextSegmentP1;
+ double azS0, azS1, azSL;
- do {
- containingFace = -1;
+ nextSegmentP0 = closestSegmentP1;
+ /* This would be more of an assert...*/
+ if ( closestSegmentIndex + 1 > closestEdge->geom->points->npoints )
+ lwerror("closestSegmentIndex is unexpectedly the last one and we didn't exit earlier as it would be a node");
+ return -1;
+ nextSegmentP1 = getPoint2d_cp(closestEdge->geom->points, closestSegmentIndex + 2);
+ if ( ! azimuth_pt_pt(closestSegmentP1, closestSegmentP0, &azS0)) {
+ lwerror("error computing azimuth of reversse closest segment [%.15g %.15g,%.15g %.15g]",
+ closestSegmentP1->x, closestSegmentP1->y,
+ closestSegmentP0->x, closestSegmentP0->y);
+ return -1;
+ if ( ! azimuth_pt_pt(nextSegmentP0, nextSegmentP1, &azS1)) {
+ lwerror("error computing azimuth of next segment [%.15g %.15g,%.15g %.15g]",
+ nextSegmentP0->x, nextSegmentP0->y,
+ nextSegmentP1->x, nextSegmentP1->y);
+ return -1;
+ if ( ! azimuth_pt_pt(shortestLineP0, shortestLineP1, &azSL) ) {
+ lwerror("error computing azimuth of shortestLine [%.15g %.15g,%.15g %.15g]",
+ shortestLineP0->x, shortestLineP0->y,
+ shortestLineP1->x, shortestLineP1->y);
+ return -1;
+ double angle_S0_S1 = azS1 - azS0;
+ if ( angle_S0_S1 < 0 ) angle_S0_S1 += 2 * M_PI;
+ double angle_S0_SL = azSL - azS0;
+ if ( angle_S0_SL < 0 ) angle_S0_SL += 2 * M_PI;
+ LWDEBUGF(1, "Azimuths from last point of closest segment: S0:%g, S1:%g (+%g), SL:%g (+%g)",
+ azS0,
+ azS1, angle_S0_S1,
+ azSL, angle_S0_SL
+ if ( angle_S0_SL < angle_S0_S1 )
+ /* shortest line was encountered first, is on the left */
+ containingFace = closestEdge->face_left;
+ else
+ /* shortest line NOT encountered first, is on the right */
+ containingFace = closestEdge->face_right;
+ else
+ /* Closest point is internal to closest segment, we can use
+ * lw_segment_side */
- shortestLineP1 = getPoint2d_cp(((LWLINE *)shortestLine)->points, 1);
LWDEBUGF(1, "Calling lw_segment_side((%g,%g),(%g,%g),(%g,%g)",
closestSegmentP0->y,
@@ -7259,26 +7348,20 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
if ( closestSegmentSide == -1 ) /* left */
- break;
else if ( closestSegmentSide == 1 ) /* right */
- break;
+ else
+ lwerror("Unexpected collinearity reported from lw_segment_side");
+ return -1;
- /* If the point was collinear to the closest segment
- * we need to check the next segment, as if this was
- * the last one we would have entered a previous branch
- * selecting the case in which the closest point is
- * a NODE, and ptarray_closest_segment_2d should be
- * always returning the *first* segment so there must
- * be a next one.
- closestSegmentP0 = closestSegmentP1;
- } while (1);
diff --git a/topology/test/regress/getfacecontainingpoint.sql b/topology/test/regress/getfacecontainingpoint.sql
index 9763a2d..d4befbd 100644
--- a/topology/test/regress/getfacecontainingpoint.sql
+++ b/topology/test/regress/getfacecontainingpoint.sql
@@ -51,6 +51,18 @@ SELECT 't8', topology.GetFaceContainingPoint('city_data', 'POINT(24 16.9)');
-- Query point collinear with closest incoming segment (right of next one)
SELECT 't9', topology.GetFaceContainingPoint('city_data', 'POINT(7.1 31)');
+-- Query point on the right of the closest segment but left of ring
+SELECT 't10', topology.GetFaceContainingPoint('city_data', 'POINT(26 16.8)');
+-- Query point on the left of the closest segment and left of ring
+SELECT 't11', topology.GetFaceContainingPoint('city_data', 'POINT(26 17.2)');
+-- Query point on the left of the closest segment but right of ring
+SELECT 't12', topology.GetFaceContainingPoint('city_data', 'POINT(33.1 17.8)');
+-- Query point on the right of the closest segment and right of ring
+SELECT 't13', topology.GetFaceContainingPoint('city_data', 'POINT(33.1 17.2)');
-- Query point on a node incident to multiple faces
SELECT 'e1', topology.GetFaceContainingPoint('city_data', 'POINT(21 14)');
diff --git a/topology/test/regress/getfacecontainingpoint_expected b/topology/test/regress/getfacecontainingpoint_expected
index 251363c..ef034b2 100644
--- a/topology/test/regress/getfacecontainingpoint_expected
+++ b/topology/test/regress/getfacecontainingpoint_expected
@@ -18,6 +18,10 @@ t6|0
t7|11
t8|4
t9|1
+t10|10
+t11|10
+t12|10
+t13|10
ERROR: Two or more faces found
Summary of changes:
liblwgeom/lwgeom_topo.c | 123 +++++++++++++++++----
topology/test/regress/getfacecontainingpoint.sql | 12 ++
.../test/regress/getfacecontainingpoint_expected | 4 +
3 files changed, 119 insertions(+), 20 deletions(-)
hooks/post-receive
