[postgis-tickets] [PostGIS] #4962: Adding a linestring to the topology can load topology multiple times
trac at osgeo.org
Thu Aug 12 14:07:00 PDT 2021
Reporter: strk | Owner: strk
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 3.2.0
Component: topology | Version: main
Resolution: fixed | Keywords:
Comment (by Sandro Santilli <strk@…>):
In [changeset:"6571dc8fde5cb396bfaf6db394f39b765535028c/git" 6571dc8/git]:
#!CommitTicketReference repository="git"
revision="6571dc8fde5cb396bfaf6db394f39b765535028c"
Use angles to determine side of point on edge when closest is a vertex
Closes #4962 again
Includes regress test for getFaceContainingPoint
(failing without the change)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4962#comment:6>
