[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-399-g9f12ffa
git at osgeo.org
git at osgeo.org
Fri Aug 13 00:59:37 PDT 2021
the project "PostGIS".
The branch, main has been updated
via 9f12ffaa0bc2495e7b9f6f027f32bdaf6941ce4c (commit)
from 9ee72d5cb6e9b049c1b048f77d28140e18b18504 (commit)
revisions in full, below.
commit 9f12ffaa0bc2495e7b9f6f027f32bdaf6941ce4c
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Aug 13 09:33:58 2021 +0200
Improve test for getFaceContainingPoint
Allow inspecting query points graphically
Add tests for query point near the start
of a dangling edge
diff --git a/topology/test/regress/getfacecontainingpoint.sql b/topology/test/regress/getfacecontainingpoint.sql
index d4befbd..8780423 100644
--- a/topology/test/regress/getfacecontainingpoint.sql
+++ b/topology/test/regress/getfacecontainingpoint.sql
@@ -24,56 +24,52 @@ FROM city_data.face
WHERE face_id > 0
ORDER BY face_id;
--- Query point near isolated edge in a face
-SELECT 't1', topology.GetFaceContainingPoint('city_data', 'POINT(11 34)');
+-- Query point on a node incident to multiple faces
+SELECT 'e1', topology.GetFaceContainingPoint('city_data', 'POINT(21 14)');
--- Query point near node of closed edge, outside of it
-SELECT 't2', topology.GetFaceContainingPoint('city_data', 'POINT(3.8 30.8)');
+-- Query point on a node incident to universe face and proper face
+SELECT 'e2', topology.GetFaceContainingPoint('city_data', 'POINT(9 22)');
--- Query point near node of closed edge, inside of it
-SELECT 't3', topology.GetFaceContainingPoint('city_data', 'POINT(4.2 31.2)');
+-- Query point on a non-dangling edge binding 2 faces
+SELECT 'e3', topology.GetFaceContainingPoint('city_data', 'POINT(28 14)');
--- Query point on a node of degree 1 incident to single face
-SELECT 't4', topology.GetFaceContainingPoint('city_data', 'POINT(25 35)');
+-- Query point on a non-dangling edge binding universe and proper face
+SELECT 'e4', topology.GetFaceContainingPoint('city_data', 'POINT(28 22)');
+CREATE TABLE city_data.query_points(id int primary key, g geometry);
+INSERT INTO city_data.query_points VALUES
+-- Query point near isolated edge in a face
+( 1, 'POINT(11 34)' ),
+-- Query point near node of closed edge, outside of it
+( 2, 'POINT(3.8 30.8)' ),
+-- Query point near node of closed edge, inside of it
+( 3, 'POINT(4.2 31.2)' ),
+-- Query point on a node of degree 1 incident to single face
+( 4, 'POINT(25 35)' ),
-- Query point on an dangling edge
-SELECT 't5', topology.GetFaceContainingPoint('city_data', 'POINT(25 33)');
+( 5, 'POINT(25 33)' ),
-- Query point on a node of degree 2 incident to single face
-SELECT 't6', topology.GetFaceContainingPoint('city_data', 'POINT(57 33)');
+( 6, 'POINT(57 33)' ),
-- Query point in hole touching shell, near edge having hole on the left
-SELECT 't7', topology.GetFaceContainingPoint('city_data', 'POINT(32 16.9)');
+( 7, 'POINT(32 16.9)' ),
-- Query point in hole touching shell, near edge having hole on the right
-SELECT 't8', topology.GetFaceContainingPoint('city_data', 'POINT(24 16.9)');
+( 8, 'POINT(24 16.9)' ),
-- Query point collinear with closest incoming segment (right of next one)
-SELECT 't9', topology.GetFaceContainingPoint('city_data', 'POINT(7.1 31)');
+( 9, 'POINT(7.1 31)' ),
-- Query point on the right of the closest segment but left of ring
-SELECT 't10', topology.GetFaceContainingPoint('city_data', 'POINT(26 16.8)');
+( 10, 'POINT(26 16.8)' ),
-- Query point on the left of the closest segment and left of ring
-SELECT 't11', topology.GetFaceContainingPoint('city_data', 'POINT(26 17.2)');
+( 11, 'POINT(26 17.2)' ),
-- Query point on the left of the closest segment but right of ring
-SELECT 't12', topology.GetFaceContainingPoint('city_data', 'POINT(33.1 17.8)');
+( 12, 'POINT(33.05 17.21)' ),
-- Query point on the right of the closest segment and right of ring
-SELECT 't13', topology.GetFaceContainingPoint('city_data', 'POINT(33.1 17.2)');
--- Query point on a node incident to multiple faces
-SELECT 'e1', topology.GetFaceContainingPoint('city_data', 'POINT(21 14)');
+( 13, 'POINT(33.1 17.2)' ),
+-- Query point near the start of a dangling edge
+( 14, 'POINT(8 36)' );
--- Query point on a node incident to universe face and proper face
-SELECT 'e2', topology.GetFaceContainingPoint('city_data', 'POINT(9 22)');
--- Query point on a non-dangling edge binding 2 faces
-SELECT 'e3', topology.GetFaceContainingPoint('city_data', 'POINT(28 14)');
--- Query point on a non-dangling edge binding universe and proper face
-SELECT 'e4', topology.GetFaceContainingPoint('city_data', 'POINT(28 22)');
+SELECT 't'||id, topology.GetFaceContainingPoint('city_data', g)
+FROM city_data.query_points
+ORDER BY id;
diff --git a/topology/test/regress/getfacecontainingpoint_expected b/topology/test/regress/getfacecontainingpoint_expected
index ef034b2..d284e60 100644
--- a/topology/test/regress/getfacecontainingpoint_expected
+++ b/topology/test/regress/getfacecontainingpoint_expected
@@ -9,6 +9,10 @@ pos|8|8
pos|9|9
pos|10|10
pos|11|11
+ERROR: Two or more faces found
t1|1
t2|1
t3|9
@@ -22,7 +26,4 @@ t10|10
t11|10
t12|10
t13|10
-ERROR: Two or more faces found
+t14|1
Summary of changes:
topology/test/regress/getfacecontainingpoint.sql | 68 ++++++++++------------
.../test/regress/getfacecontainingpoint_expected | 9 +--
2 files changed, 37 insertions(+), 40 deletions(-)
hooks/post-receive
