[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-400-g497e63d
Fri Aug 13 03:10:34 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  497e63d0a4d224c0fd1573747d91a6acf70213c3 (commit)
      from  9f12ffaa0bc2495e7b9f6f027f32bdaf6941ce4c (commit)
revisions in full, below.
commit 497e63d0a4d224c0fd1573747d91a6acf70213c3
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Aug 13 11:20:32 2021 +0200
    Add GetFaceContainingPoint tests (query point in opposite quadrant)
    Closest point is a node of degree 3
diff --git a/topology/test/regress/getfacecontainingpoint.sql b/topology/test/regress/getfacecontainingpoint.sql
index 8780423..df7a485 100644
--- a/topology/test/regress/getfacecontainingpoint.sql
+++ b/topology/test/regress/getfacecontainingpoint.sql
@@ -9,6 +9,53 @@ SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(24 14,
 -- Add holes touching shell defined in CCW order
 SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(32 14, 33 17,31 17, 32 14)');
+-- Add cluster of edges forming 2 adjacent faces
+-- and exposing a node of degree 3 on the upper-right
+-- corner where all edge-ends are on the lower-left
+-- quadrant and the central edge have the bounding box
+-- with smallest x/y
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(11 8, 19 12)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(12 9, 19 12)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(12.42 8.2, 19 12)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(11 8, 12 9)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(11 8, 12.42 8.2)');
+-- and exposing a node of degree 3 on the bottom-right
+-- corner where all edge-ends are on the upper-left
+-- with smallest x and biggest y
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(11 20, 19 16)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(12 19, 19 16)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(12.42 19.8, 19 16)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(11 20, 12 19)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(11 20, 12.42 19.8)');
+-- and exposing a node of degree 3 on the bottom-left
+-- corner where all edge-ends are on the upper-right
+-- with biggest x/y
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(45 20, 37 16)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(44 19, 37 16)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(43.58 19.8, 37 16)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(45 20, 44 19)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(45 20, 43.58 19.8)');
+-- and exposing a node of degree 3 on the upper-left
+-- corner where all edge-ends are on the bottomr-right
+-- with biggest x and smallest y
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(45 8, 37 12)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(44 9, 37 12)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(43.58 8.2, 37 12)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(45 8, 44 9)');
+SELECT NULL FROM topology.TopoGeo_addLineString('city_data', 'LINESTRING(45 8, 43.58 8.2)');
 -- Get face containing the "point on surface" of each face's geometry
 SELECT 'pos', face_id, topology.GetFaceContainingPoint(
@@ -65,7 +112,20 @@ INSERT INTO city_data.query_points VALUES
 -- Query point on the right of the closest segment and right of ring
 ( 13, 'POINT(33.1 17.2)' ),
 -- Query point near the start of a dangling edge
-( 14, 'POINT(8 36)' );
+( 14, 'POINT(8 36)' ),
+-- Query point near node of degree 3 with leftmost-bottommost edge
+-- not in query point face
+( 15, 'POINT(19.5 12.2)' ),
+-- Query point near node of degree 3 with leftmost-uppermost edge
+( 16, 'POINT(19.5 15.8)' ),
+-- Query point near node of degree 3 with rightmost-uppermost edge
+( 17, 'POINT(36.5 15.8)' ),
+-- Query point near node of degree 3 with rightmost-bottommost edge
+( 18, 'POINT(36.5 12.2)' )
 SELECT 't'||id, topology.GetFaceContainingPoint('city_data', g)
 FROM city_data.query_points
diff --git a/topology/test/regress/getfacecontainingpoint_expected b/topology/test/regress/getfacecontainingpoint_expected
index d284e60..9df926e 100644
--- a/topology/test/regress/getfacecontainingpoint_expected
+++ b/topology/test/regress/getfacecontainingpoint_expected
@@ -9,6 +9,14 @@ pos|8|8
 pos|9|9
 pos|10|10
 pos|11|11
+pos|12|12
+pos|13|13
+pos|14|14
+pos|15|15
+pos|16|16
+pos|17|17
+pos|18|18
+pos|19|19
 ERROR:  Two or more faces found
@@ -27,3 +35,7 @@ t11|10
 t12|10
 t13|10
 t14|1
+t15|12
+t16|15
+t17|16
+t18|19
Summary of changes:
 topology/test/regress/getfacecontainingpoint.sql   | 62 +++++++++++++++++++++-
 .../test/regress/getfacecontainingpoint_expected   | 12 +++++
 2 files changed, 73 insertions(+), 1 deletion(-)
hooks/post-receive
