[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-401-g4ffb70a
git at osgeo.org
git at osgeo.org
Fri Aug 13 06:58:08 PDT 2021
the project "PostGIS".
The branch, main has been updated
via 4ffb70ab4c05776a0be70ecfd98e5d26f33e6d00 (commit)
from 497e63d0a4d224c0fd1573747d91a6acf70213c3 (commit)
revisions in full, below.
commit 4ffb70ab4c05776a0be70ecfd98e5d26f33e6d00
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Aug 13 15:57:45 2021 +0200
Drop conditional on PostgreSQL 9.5 as we're not supporting it anyway
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 9f0756d..1524461 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -3005,20 +3005,9 @@ cb_getClosestEdge( const LWT_BE_TOPOLOGY* topo, const LWPOINT* pt, uint64_t *num
initStringInfo(sql);
- /* TODO: avoid executing ST_ShortestLine twice (to be confirmed it
- * if it is called twice
appendStringInfoString(sql, "SELECT ");
addEdgeFields(sql, fields, 0);
- appendStringInfo(sql, " FROM \"%s\".edge_data ORDER BY ", topo->name);
-#if POSTGIS_PGSQL_VERSION < 95
- appendStringInfo(sql, "ST_Length(ST_ShortestLine(geom, $1))");
-#else
- appendStringInfo(sql, "geom <-> $1");
-#endif
- appendStringInfo(sql, " ASC, edge_id ASC LIMIT 1");
+ appendStringInfo(sql, " FROM \"%s\".edge_data ORDER BY geom <-> $1 ASC, edge_id ASC LIMIT 1", topo->name);
POSTGIS_DEBUGF(1, "cb_getClosestEdge query: %s", sql->data);
Summary of changes:
topology/postgis_topology.c | 13 +------------
1 file changed, 1 insertion(+), 12 deletions(-)
hooks/post-receive
