[postgis-tickets] [SCM] PostGIS branch stable-2.4 updated. 2.4.9-10-ge93b24e
Sun Aug 15 17:51:16 PDT 2021
the project "PostGIS".
The branch, stable-2.4 has been updated
       via  e93b24e4e8eff3a47cd4b1821ca144ae2c52c953 (commit)
      from  4f4b20058ed01c2c30ae4b6a8ca2818e67471202 (commit)
revisions in full, below.
commit e93b24e4e8eff3a47cd4b1821ca144ae2c52c953
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Aug 15 20:51:11 2021 -0400
    Backport Raúl Marín CUnit fixes. Closes  #4971 for PostGIS 2.4.10
diff --git a/NEWS b/NEWS
index 0342216..0dba387 100644
--- a/NEWS
+++ b/NEWS
@@ -10,6 +10,7 @@ YYYY/MM/DD
   - #4727, Fix geocentric bounding box computation for rare case (Paul Ramsey)
   - #4326, Fix CircularPolygon area calculation (Paul Ramsey)
   - #4968, Update autogen.sh to handle autoconf 2.71 issues (Raúl Marín, Regina Obe)
+  - #4971, Cunit fixes for newer CUnit (Raúl Marín, Regina Obe)
 PostGIS 2.4.9
diff --git a/liblwgeom/cunit/cu_in_twkb.c b/liblwgeom/cunit/cu_in_twkb.c
index 9313f13..43542b2 100644
--- a/liblwgeom/cunit/cu_in_twkb.c
+++ b/liblwgeom/cunit/cu_in_twkb.c
@@ -20,10 +20,10 @@
 ** Global variable to hold TWKB strings
-char *hex_a;
-char *hex_b;
-uint8_t precision = 0;
-uint8_t variant = 0;
+static char *hex_a;
+static char *hex_b;
+static uint8_t precision = 0;
+static uint8_t variant = 0;
 ** The suite initialization function.
diff --git a/liblwgeom/cunit/cu_in_wkb.c b/liblwgeom/cunit/cu_in_wkb.c
index 7a69575..1ac85ee 100644
--- a/liblwgeom/cunit/cu_in_wkb.c
+++ b/liblwgeom/cunit/cu_in_wkb.c
@@ -20,8 +20,8 @@
 ** Global variable to hold WKB strings
-char *hex_a;
-char *hex_b;
diff --git a/liblwgeom/cunit/cu_out_twkb.c b/liblwgeom/cunit/cu_out_twkb.c
index 27f51e9..3609416 100644
--- a/liblwgeom/cunit/cu_out_twkb.c
+++ b/liblwgeom/cunit/cu_out_twkb.c
@@ -21,8 +21,8 @@
 ** Global variable to hold hex TWKB strings
-char *s;
-char *w;
+static char *s;
+static char *w;
diff --git a/liblwgeom/cunit/cu_out_wkb.c b/liblwgeom/cunit/cu_out_wkb.c
index d60db1b..7b23fe6 100644
--- a/liblwgeom/cunit/cu_out_wkb.c
+++ b/liblwgeom/cunit/cu_out_wkb.c
@@ -20,8 +20,8 @@
 ** Global variable to hold hex WKB strings
-char *s;
-size_t s_size;
+static char *s;
+static size_t s_size;
diff --git a/liblwgeom/cunit/cu_out_wkt.c b/liblwgeom/cunit/cu_out_wkt.c
index c070efb..199ca62 100644
--- a/liblwgeom/cunit/cu_out_wkt.c
+++ b/liblwgeom/cunit/cu_out_wkt.c
@@ -20,7 +20,7 @@
 ** Global variable to hold WKT strings
-char *s = NULL;
+static char *s = NULL;
diff --git a/liblwgeom/cunit/cu_tester.c b/liblwgeom/cunit/cu_tester.c
index 04b8b5e..633fff0 100644
--- a/liblwgeom/cunit/cu_tester.c
+++ b/liblwgeom/cunit/cu_tester.c
@@ -16,6 +16,7 @@
 #include "cu_tester.h"
 #include "../postgis_config.h"
+char cu_error_msg[MAX_CUNIT_ERROR_LENGTH + 1] = {0};
 /* Internal funcs */
 static void
 cu_errorreporter(const char *fmt, va_list ap);
@@ -140,7 +141,7 @@ int main(int argc, char *argv[])
 	char *suite_name;
 	CU_pSuite suite_to_run;
 	char *test_name;
-	CU_pTest test_to_run;
+	CU_pTest test_to_run = NULL;
 	CU_ErrorCode errCode = 0;
 	CU_pTestRegistry registry;
 	int num_run;
@@ -206,7 +207,7 @@ int main(int argc, char *argv[])
 			else
-				if (test_name != NULL)
+				if (test_name != NULL && test_to_run != NULL)
 					/* Run only this test. */
 					printf("\nRunning test '%s' in suite '%s'.\n", test_name, suite_name);
diff --git a/liblwgeom/cunit/cu_tester.h b/liblwgeom/cunit/cu_tester.h
index 9e245df..9a4cc5a 100644
--- a/liblwgeom/cunit/cu_tester.h
+++ b/liblwgeom/cunit/cu_tester.h
@@ -10,6 +10,9 @@
+#ifndef _CU_TESTER_H
+#define _CU_TESTER_H 1
 #include "liblwgeom.h"
 #define MAX_CUNIT_ERROR_LENGTH 512
@@ -17,7 +20,7 @@
 #define PG_ADD_TEST(suite, testfunc) CU_add_test(suite, #testfunc, testfunc)
 /* Contains the most recent error message generated by lwerror. */
-char cu_error_msg[MAX_CUNIT_ERROR_LENGTH+1];
+extern char cu_error_msg[];
 /* Resets cu_error_msg back to blank. */
 void cu_error_msg_reset(void);
@@ -75,3 +78,5 @@ typedef void (*PG_SuiteSetup)(void);
 /* Utility functions */
 void do_fn_test(LWGEOM* (*transfn)(LWGEOM*), char *input_wkt, char *expected_wkt);
+#endif /* _CU_TESTER_H */
Summary of changes:
 NEWS                          | 1 +
 liblwgeom/cunit/cu_in_twkb.c  | 8 ++++----
 liblwgeom/cunit/cu_in_wkb.c   | 4 ++--
 liblwgeom/cunit/cu_out_twkb.c | 4 ++--
 liblwgeom/cunit/cu_out_wkb.c  | 4 ++--
 liblwgeom/cunit/cu_out_wkt.c  | 2 +-
 liblwgeom/cunit/cu_tester.c   | 5 +++--
 liblwgeom/cunit/cu_tester.h   | 7 ++++++-
 8 files changed, 21 insertions(+), 14 deletions(-)
hooks/post-receive
