[postgis-tickets] [PostGIS] #4972: debbie failing on regress PostGIS 2.4 +WARNING: 'postgis.backend' is already set and cannot be changed
PostGIS trac at osgeo.org
Sun Aug 15 20:48:56 PDT 2021
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  medium     |  Milestone:  PostGIS 2.4.10
 Component:  buildbots  |    Version:  2.4.x
Resolution:  fixed      |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"4b1d5ffc63884850a2645df1359574f20cbcc331/git" 4b1d5ff/git]:
 #!CommitTicketReference repository="git"
 revision="4b1d5ffc63884850a2645df1359574f20cbcc331"
 Try to fix debbie's complaining about warning backend change.  Closes
 #4972 for PostGIS 2.4.10
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4972#comment:1>
