[postgis-tickets] [PostGIS] #4975: PostGIS upgrade should not use temp tables as that is banned by some security policies
PostGIS trac at osgeo.org
Wed Aug 18 16:54:53 PDT 2021
security policies
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.2.0
Component:  build/upgrade/install  |    Version:  2.5.x
 Keywords:                         |
 Aiven proposed a solution using a temp function _postgis_upgrade_info()
 instead of a temp table _postgis_upgrade_info.  I haven't tested the patch
 yet.  Will affect all our upgrades so needs careful testing.
 https://github.com/postgis/postgis/pull/623
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4975>
