[postgis-tickets] [PostGIS] #4976: No such function as ST_Angel(geometry, geometry, geometry)
PostGIS trac at osgeo.org
Fri Aug 20 11:27:34 PDT 2021
#4976: No such function as ST_Angel(geometry,geometry, geometry)
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  closed
  Priority:  blocker        |  Milestone:  PostGIS 3.2.0
 Component:  documentation  |    Version:  master
Resolution:  fixed          |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"1c03eb65188d33db061d7d9d91243d0e6e848022/git" 1c03eb6/git]:
 #!CommitTicketReference repository="git"
 revision="1c03eb65188d33db061d7d9d91243d0e6e848022"
 Fix proto should be a 4 point with 4th geometry being optional. Closes
 #4976
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4976#comment:4>
