[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-413-g87a815c
Fri Aug 20 23:00:22 PDT 2021
the project "PostGIS".
       via  87a815cfb038e24e760cbdba1d9fb64d5debd943 (commit)
      from  86a8a59791431b279e4d6511c96af0d3e45332d5 (commit)
revisions in full, below.
commit 87a815cfb038e24e760cbdba1d9fb64d5debd943
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Aug 21 01:53:53 2021 -0400
    Upgrade path patchfor address_standardizer_data_us
    and minor fix to patch Closes #4974
    PostGIS upgrade change to not use temp tables Closes #4975
    Closes https://github.com/postgis/postgis/pull/623
    Credits: Jan Katins (Aiven)
diff --git a/NEWS b/NEWS
index ba7bec1..e9eafe3 100644
--- a/NEWS
+++ b/NEWS
@@ -41,6 +41,9 @@ PostGIS 3.2.0
   - ST_Srid(topogeometry) override, to speedup lookups (Sandro Santilli)
   - #2175, Avoid creating additional nodes when adding same closed
            line to topology (Sandro Santilli)
+  - #4974, Upgrade path for address_standardizer_data_us
+    (Jan Katins of Aiven, Regina Obe)
+  - #4975, PostGIS upgrade change to not use temp tables (Jan Katins of Aiven)
  * New features*
   - #4923, topology.ValidateTopologyRelation (Sandro Santilli)
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index 3c64b47..820b7e8 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -47,7 +47,7 @@ DATA_built = \
 all:  sql/address_standardizer.sql sql/address_standardizer--1.0--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql \
  sql/$(EXTENSION)_data_us.sql sql/address_standardizer-- at POSTGIS_LIB_VERSION@.sql sql/$(EXTENSION)_data_us-- at POSTGIS_LIB_VERSION@.sql  sql/$(EXTENSION)_data_us--$(EXTVERSION)--$(EXTVERSION)next.sql \
-sql/$(EXTENSION)_data_us--$(EXTVERSION)next--$(EXTVERSION).sql \
+sql/$(EXTENSION)_data_us--$(EXTVERSION)next--$(EXTVERSION).sql sql/$(EXTENSION)_data_us--ANY--$(EXTVERSION).sql \
 sql/test-init-extensions.sql sql/test-parseaddress.sql sql/test-standardize_address_1.sql sql/test-standardize_address_2.sql
 EXTRA_CLEAN = sql/
@@ -118,8 +118,25 @@ sql/$(EXTENSION)_data_us--$(EXTVERSION)next--$(EXTVERSION).sql: sql/$(EXTENSION)
 sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS)
 	cat $(EXTENSION_UPGRADE_SCRIPTS) > $@
+sql/$(EXTENSION)_data_us--ANY--$(EXTVERSION).sql: sql/$(EXTENSION)_data_us--$(EXTVERSION).sql
+	mkdir -p sql
+	cat $^ > $@
 include ../upgrade-paths-rules.mk
+install: install-upgrade-paths-data-us
+# address_standardizer is already defined, we have to additionally create
+# the upgrade path scripts for address_standardizer_data_us
+install-upgrade-paths-data-us:
+	tpl='$(EXTENSION)_data_us--ANY--$(EXTVERSION).sql'; \
+	$(INSTALL_DATA) sql/$${tpl} "$(EXTDIR)/$${tpl}"; \
+	ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)_data_us--$(EXTVERSION)--$(EXTVERSION)next.sql; \
+	ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)_data_us--$(EXTVERSION)next--$(EXTVERSION).sql; \
+	for OLD_VERSION in $(UPGRADEABLE_VERSIONS); do \
+		ln -fs "$${tpl}" $(EXTDIR)/$(EXTENSION)_data_us--$$OLD_VERSION--$(EXTVERSION).sql; \
+	done
 mk-st-regexp: mk-st-regexp.pl
 	$(PERL) -c mk-st-regexp.pl
 	rm -f mk-st-regexp
diff --git a/utils/postgis_proc_upgrade.pl b/utils/postgis_proc_upgrade.pl
index 859641b..23cd812 100755
--- a/utils/postgis_proc_upgrade.pl
+++ b/utils/postgis_proc_upgrade.pl
@@ -203,7 +203,7 @@ BEGIN
 EOF
         print "OR version_from_num IN ( ${missing} )" if ($missing);
         print <<"EOF";
-     FROM _postgis_upgrade_info
+     FROM _postgis_upgrade_info()
   THEN
       EXECUTE \$postgis_proc_upgrade_parsed_def\$ $def \$postgis_proc_upgrade_parsed_def\$;
   END IF;
@@ -286,7 +286,7 @@ BEGIN
     EXECUTE \$postgis_proc_upgrade_parsed_def\$ $pg12_def \$postgis_proc_upgrade_parsed_def\$;
   ELSIF $last_updated > version_from_num OR (
       $last_updated = version_from_num AND version_from_isdev
-    ) FROM _postgis_upgrade_info
+    ) FROM _postgis_upgrade_info()
   THEN
     EXECUTE 'DROP AGGREGATE IF EXISTS $aggsig';
@@ -322,7 +322,7 @@ EOF
 DO LANGUAGE 'plpgsql'
 \$postgis_proc_upgrade\$
 BEGIN
-  --IF $last_updated > version_from_num FROM _postgis_upgrade_info
+  --IF $last_updated > version_from_num FROM _postgis_upgrade_info()
     --We trust presence of operator rather than version info
     IF NOT EXISTS (
         SELECT o.oprname
@@ -405,7 +405,7 @@ EOF
 BEGIN
-  IF $last_updated > version_from_num FROM _postgis_upgrade_info THEN
+  IF $last_updated > version_from_num FROM _postgis_upgrade_info() THEN
   END IF;
 END
@@ -477,7 +477,7 @@ DO LANGUAGE 'plpgsql'
 BEGIN
   THEN
@@ -490,7 +490,7 @@ EOF
             print <<"EOF";
   $ELSE
     -- Last Updated: ${last_updated}
         ALTER OPERATOR FAMILY ${opclassname} USING ${opcidx}
           ADD $def;
@@ -511,7 +511,7 @@ EOF
 close(INPUT);
-print "DROP TABLE _postgis_upgrade_info;\n";
+print "DROP FUNCTION _postgis_upgrade_info();\n";
 #print "COMMIT;\n";
@@ -525,6 +525,8 @@ DECLARE
     new_scripts text;
     old_maj text;
     new_maj text;
+    postgis_upgrade_info RECORD;
+    postgis_upgrade_info_func_code TEXT;
 BEGIN
     -- This uses postgis_lib_version() rather then
@@ -557,24 +559,50 @@ BEGIN
     IF old_maj != new_maj THEN
         RAISE EXCEPTION 'Upgrade of MODULE from version % to version % requires a dump/reload. See PostGIS manual for instructions', old_scripts, new_scripts;
     END IF;
+    WITH versions AS (
+      SELECT 'NEWVERSION'::text as upgraded,
+      MODULE_scripts_installed() as installed
+    ) SELECT
+      upgraded as scripts_upgraded,
+      installed as scripts_installed,
+      substring(upgraded from '([0-9]+)\.')::int * 100 +
+      substring(upgraded from '[0-9]+\.([0-9]+)(\.|$)')::int
+        as version_to_num,
+      substring(installed from '([0-9]+)\.')::int * 100 +
+      substring(installed from '[0-9]+\.([0-9]+)(\.|$)')::int
+        as version_from_num,
+      installed ~ 'dev|alpha|beta'
+        as version_from_isdev
+      FROM versions INTO postgis_upgrade_info
+    postgis_upgrade_info_func_code := format($func_code$
+        CREATE FUNCTION _postgis_upgrade_info(OUT scripts_upgraded TEXT,
+                                              OUT scripts_installed TEXT,
+                                              OUT version_to_num INT,
+                                              OUT version_from_num INT,
+                                              OUT version_from_isdev BOOLEAN)
+        AS
+        $postgis_upgrade_info$
+        BEGIN
+            scripts_upgraded := %L :: TEXT;
+            scripts_installed := %L :: TEXT;
+            version_to_num := %L :: INT;
+            version_from_num := %L :: INT;
+            version_from_isdev := %L :: BOOLEAN;
+            RETURN;
+        END
+        $postgis_upgrade_info$ LANGUAGE 'plpgsql' IMMUTABLE;
+        $func_code$,
+        postgis_upgrade_info.scripts_upgraded,
+        postgis_upgrade_info.scripts_installed,
+        postgis_upgrade_info.version_to_num,
+        postgis_upgrade_info.version_from_num,
+        postgis_upgrade_info.version_from_isdev);
+    RAISE DEBUG 'Creating function %', postgis_upgrade_info_func_code;
+    EXECUTE postgis_upgrade_info_func_code;
 END
 LANGUAGE 'plpgsql';
-CREATE TEMPORARY TABLE _postgis_upgrade_info AS WITH versions AS (
-  SELECT 'NEWVERSION'::text as upgraded,
-  MODULE_scripts_installed() as installed
-) SELECT
-  upgraded as scripts_upgraded,
-  installed as scripts_installed,
-  substring(upgraded from '([0-9]*)\.')::int * 100 +
-  substring(upgraded from '[0-9]*\.([0-9]*)\.')::int
-    as version_to_num,
-  substring(installed from '([0-9]*)\.')::int * 100 +
-  substring(installed from '[0-9]*\.([0-9]*)\.')::int
-    as version_from_num,
-  installed ~ 'dev|alpha|beta'
-    as version_from_isdev
-  FROM versions
Summary of changes:
 NEWS                                        |  3 ++
 extensions/address_standardizer/Makefile.in | 19 +++++++-
 utils/postgis_proc_upgrade.pl               | 76 ++++++++++++++++++++---------
 3 files changed, 73 insertions(+), 25 deletions(-)
hooks/post-receive
