[postgis-tickets] [PostGIS] #4979: There are still problems with empty geographies
trac at osgeo.org
Sat Aug 21 13:50:59 PDT 2021
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.4
Component: postgis | Version: 2.5.x
Keywords: |
esteban at DESKTOP-9FBND60:~/src/MobilityDB/test/point/data$ psql -p 5433
test_pg3
psql (13.2)
Type "help" for help.
test_pg3=# create extension postgis;
CREATE EXTENSION
test_pg3=# select postgis_full_version();
POSTGIS="3.1.2dev b02ee95" [EXTENSION] PGSQL="130"
GEOS="3.8.0-CAPI-1.13.1 " PROJ="6.3.1" LIBXML="2.9.10" LIBJSON="0.13
.1" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
(1 row)
test_pg3=# select geography 'Point empty';
ERROR: lwgeom_set_geodetic: unsupported geom type: Unknown
LINE 1: select geography 'Point empty';
test_pg3=# select geography 'Linestring empty';
LINE 1: select geography 'Linestring empty';
test_pg3=# select geography 'Polygon empty';
LINE 1: select geography 'Polygon empty';
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4979>
