[postgis-tickets] [PostGIS] #4979: There are still problems with empty geographies
trac at osgeo.org
Sat Aug 21 19:15:44 PDT 2021
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.1.4
Component: postgis | Version: 2.5.x
Resolution: worksforme | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => worksforme
Comment:
ezimanyi,
Can you upgrade to the latest PostGIS 3.1.2.. PostGIS 3.1.2 was released
already so you shouldn't be running a dev version or if dev it should be
PostGIS 3.1.3dev. I can't replicate the above issue on my 3.1.2 or
3.1.3dev
On mine:
POSTGIS="3.1.2 3.1.2" [EXTENSION] PGSQL="130" GEOS="3.9.1-CAPI-1.14.1"
SFCGAL="1.3.8" PROJ="7.1.1" GDAL="GDAL 3.2.3, released 2021/04/27"
LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)"
TOPOLOGY RASTER
select geography 'Point empty';
returns:
0101000020E6100000000000000000F87F000000000000F87F
select geography 'Point(1 1)';
Returns:
0101000020E6100000000000000000F03F000000000000F03F
I'm going to close this out, but feel free to reopen if you still have
issue. It's possible it is an issue with proj thought I doubt it as I
don't think that part of the code uses proj.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4979#comment:2>
