[postgis-tickets] [PostGIS] #4979: There are still problems with empty geographies
trac at osgeo.org
Sun Aug 22 00:54:10 PDT 2021
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 3.1.4
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Changes (by ezimanyi):
* status: closed => reopened
* resolution: worksforme =>
Comment:
I have still the same problems :-(
I have just downloaded version 3.1.3 from the link Regina told me, and do
the following steps
cd postgis-3.1.3/
chmod +x configure
./configure
make
sudo make install
The problem is still there
esteban at DESKTOP-9FBND60:~/src/MobilityDB/build$ dropdb -p 5433 test_pg3
esteban at DESKTOP-9FBND60:~/src/MobilityDB/build$ createdb -p 5433 test_pg3
esteban at DESKTOP-9FBND60:~/src/MobilityDB/build$ psql -p 5433 test_pg3
psql (13.2)
Type "help" for help.
test_pg3=# create extension postgis;
CREATE EXTENSION
test_pg3=# select geography 'Point(1 1)';
2021-08-22 09:46:06.943 CEST [19008] ERROR: lwgeom_set_geodetic:
unsupported geom type: Unknown at character 18
2021-08-22 09:46:06.943 CEST [19008] STATEMENT: select geography 'Point(1
1)';
ERROR: lwgeom_set_geodetic: unsupported geom type: Unknown
LINE 1: select geography 'Point(1 1)';
test_pg3=# select postgis_full_version();
POSTGIS="3.1.3 008d2db" [EXTENSION] PGSQL="130" GEOS="3.8.0-CAPI-1.13.1 "
PROJ="6.3.1" LIBXML="2.9.10" LIBJSON="0.13.1"
LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
(1 row)
test_pg3=#
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4979#comment:3>
