[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. 8236205f53843d0ef5519a17535af1def8b89d1a
git at osgeo.org
git at osgeo.org
Tue Aug 24 09:15:26 PDT 2021
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
via 8236205f53843d0ef5519a17535af1def8b89d1a (commit)
from d7c42220eb672eee3b181686f12f27e13ec81575 (commit)
revisions in full, below.
commit 8236205f53843d0ef5519a17535af1def8b89d1a
Author: Regina Obe <lr at pcorp.us>
Date: Tue Aug 24 12:15:21 2021 -0400
Update jenkings jobs. Instructions for building reallie and bessie changes
diff --git a/debian/reallie.txt b/debian/reallie.txt
new file mode 100644
index 0000000..1d83006
--- /dev/null
+++ b/debian/reallie.txt
@@ -0,0 +1,25 @@
+#reallie is running 64-bit Debian 11 lxd container on host.postgis.net
+#Debian GNU/Linux 11 (bullseye)
+sudo bash
+apt install default-jdk
+apt install autoconf libtool build-essential
+apt install libreadline7 libreadline7-dev zlib1g-dev
+apt install libcunit1-dev libcunit1-doc libcunit1
+apt install docbook
+apt install libxml2-dev xsltproc docbook-xsl docbook-mathml gettext
+apt install libjson-c-dev
+#apt install dblatex #for pdf building
+#apt install imagemagick #for doc building
+apt install libxml2 libxml2-dev
+apt install bison flex
+apt install libiconv-hook1
+apt install git
+apt install proj-bin
+apt install postgresql-server-dev
+#installed geos 3.7.1
+apt install libgeos libgeos-dev libproj-dev
+apt install libgdal-dev
+apt install pkg-config
+#for code coverage testing
+sudo apt install lcov
diff --git a/freebsd/bessie_setup.txt b/freebsd/bessie_setup.txt
index 3997540..5c4dae9 100644
--- a/freebsd/bessie_setup.txt
+++ b/freebsd/bessie_setup.txt
@@ -168,3 +168,21 @@ sudo gmake install
sudo gmake installcheck PGUSER=postgres
sudo cpan TAP::Parser::SourceHandler::pgTAP
+#fix date time https://www.cyberciti.biz/faq/howto-set-date-and-time-timezone-in-freebsd/
+date yymmddhhmmss
+e.g date 2106121811
+#set time without changing date
+date hhmmss
+e.g. - date 1810
+cp /usr/share/zoneinfo/US/Eastern /etc/localtime
+#see list of packages
+pkg info | grep postgresql
+#lists all installed
+pkg info –all
+pkg remove postgresql12-server postgresql12-contrib postgresql12-client gdal
+pkg install postgresql12-server postgresql12-contrib postgresql12-client gdal
+/usr/local/etc/rc.d/postgresql initdb
diff --git a/windows/jobs/GDAL_Branch_1.9_w64_win64/config.xml b/windows/jobs/GDAL_Branch_1.9_w64_win64/config.xml
deleted file mode 100644
index 9b55711..0000000
--- a/windows/jobs/GDAL_Branch_1.9_w64_win64/config.xml
+++ /dev/null
@@ -1,71 +0,0 @@
-<?xml version='1.0' encoding='UTF-8'?>
-<project>
- <actions/>
- <description></description>
- <logRotator>
- <daysToKeep>1</daysToKeep>
- <numToKeep>2</numToKeep>
- <artifactDaysToKeep>-1</artifactDaysToKeep>
- <artifactNumToKeep>-1</artifactNumToKeep>
- </logRotator>
- <keepDependencies>false</keepDependencies>
- <properties>
- <hudson.model.ParametersDefinitionProperty>
- <parameterDefinitions>
- <hudson.model.StringParameterDefinition>
- <name>GDAL_VER</name>
- <defaultValue>1.9</defaultValue>
- </hudson.model.StringParameterDefinition>
- <name>GDAL_VER_MICRO</name>
- <defaultValue>1</defaultValue>
- </parameterDefinitions>
- </hudson.model.ParametersDefinitionProperty>
- </properties>
- <scm class="hudson.scm.SubversionSCM">
- <locations>
- <hudson.scm.SubversionSCM_-ModuleLocation>
- <remote>https://svn.osgeo.org/gdal/tags/1.9.1/gdal</remote>
- <local>branches/1.9</local>
- </hudson.scm.SubversionSCM_-ModuleLocation>
- </locations>
- <excludedRegions></excludedRegions>
- <includedRegions></includedRegions>
- <excludedUsers></excludedUsers>
- <excludedRevprop></excludedRevprop>
- <excludedCommitMessages></excludedCommitMessages>
- <workspaceUpdater class="hudson.scm.subversion.UpdateUpdater"/>
- </scm>
- <canRoam>true</canRoam>
- <disabled>false</disabled>
- <blockBuildWhenDownstreamBuilding>false</blockBuildWhenDownstreamBuilding>
- <blockBuildWhenUpstreamBuilding>false</blockBuildWhenUpstreamBuilding>
- <triggers class="vector"/>
- <concurrentBuild>false</concurrentBuild>
- <customWorkspace>C:/Jenkins/gdal</customWorkspace>
- <builders>
- <hudson.tasks.BatchFile>
- <command>cd %WORKSPACE%
-set SH_WORKSPACE=/c/jenkins/gdal
-echo export GDAL_VER=%GDAL_VER% > build_%JOB_NAME%.sh
-echo export PROJECTS=/c/jenkins >> build_%JOB_NAME%.sh
-echo export PATH=".:/bin:/include:/mingw/bin:/mingw/include:/c/Windows/system32:/c/Windows:/usr/local/bin" >> build_%JOB_NAME%.sh
-echo cd '%SH_WORKSPACE%/branches/%GDAL_VER%' >> build_%JOB_NAME%.sh
-echo sh autogen.sh >> build_%JOB_NAME%.sh
-echo ./configure --host=x86_64-w64-mingw32 --prefix=${SH_WORKSPACE}/rel-${GDAL_VER}.${GDAL_VER_MICRO}w64 >> build_%JOB_NAME%.sh
-echo make clean >> build_%JOB_NAME%.sh
-echo make check >> build_%JOB_NAME%.sh
-echo make install >> build_%JOB_NAME%.sh
-</command>
- </hudson.tasks.BatchFile>
- <command>set WD=C:\ming64\msys\bin\
-%WD%sh --login -i -c '"%WORKSPACE%\build_%JOB_NAME%.sh"'</command>
- </builders>
- <publishers/>
- <buildWrappers/>
-</project>
\ No newline at end of file
diff --git a/windows/jobs/GDAL_Branch_1.9_w64_win64/nextBuildNumber b/windows/jobs/GDAL_Branch_1.9_w64_win64/nextBuildNumber
index 7ed6ff8..0000000
--- a/windows/jobs/GDAL_Branch_1.9_w64_win64/nextBuildNumber
+++ /dev/null
@@ -1 +0,0 @@
-5
diff --git a/windows/jobs/GEOS_Trunk_ming/config.xml b/windows/jobs/GEOS_Trunk_ming/config.xml
index e2db633..0000000
--- a/windows/jobs/GEOS_Trunk_ming/config.xml
+++ /dev/null
@@ -1,90 +0,0 @@
-<project>
- <actions/>
- <logRotator>
- <daysToKeep>5</daysToKeep>
- <numToKeep>10</numToKeep>
- </logRotator>
- <properties>
- <name>GEOS_VER</name>
- <description>Branch development of GEOS 3.4</description>
- <defaultValue>3.4.0dev</defaultValue>
- <name>OS_BUILD</name>
- <defaultValue>64</defaultValue>
- <name>MING_HOST</name>
- <defaultValue>x86_64-w64-mingw32</defaultValue>
- </properties>
- <scm class="hudson.scm.SubversionSCM" plugin="subversion at 1.43">
- <locations>
- <remote>https://svn.osgeo.org/geos/trunk</remote>
- <local>branches/3.4</local>
- </locations>
- </scm>
- <customWorkspace>C:\jenkins\geos</customWorkspace>
- <builders>
-set SH_WORKSPACE=/c/jenkins/geos
-REM xcopy /Y %WORKSPACE%\branches\3.4\include\geos\platform.h.in.%OS_BUILD% %WORKSPACE%\branches\3.4\include\geos\platform.h.in
-REM xcopy /Y %WORKSPACE%\branches\3.4\include\geos\platform.h.in.32 %WORKSPACE%\branches\3.4\include\geos\platform.h.in
-echo export OS_BUILD=%OS_BUILD% > build_%JOB_NAME%w%OS_BUILD%.sh
-echo export GEOS_VER=%GEOS_VER% >> build_%JOB_NAME%w%OS_BUILD%.sh
-echo export PROJECTS=/c/jenkins >> build_%JOB_NAME%w%OS_BUILD%.sh
-echo export MING_HOST=%MING_HOST% >> build_%JOB_NAME%w%OS_BUILD%.sh
-echo cd %SH_WORKSPACE%/branches/3.4 >> build_%JOB_NAME%w%OS_BUILD%.sh
-echo sh autogen.sh >> build_%JOB_NAME%w%OS_BUILD%.sh
-echo ./configure --host=${MING_HOST} --prefix=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD} >> build_%JOB_NAME%w%OS_BUILD%.sh
-echo make clean >> build_%JOB_NAME%w%OS_BUILD%.sh
-echo make >> build_%JOB_NAME%w%OS_BUILD%.sh
-echo make install >> build_%JOB_NAME%w%OS_BUILD%.sh
-echo strip ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/*.dll >> build_%JOB_NAME%w%OS_BUILD%.sh
-echo make check >> build_%JOB_NAME%w%OS_BUILD%.sh
-</command>
- <command>set WD=C:\ming%OS_BUILD%\msys\bin\
-REM %WD%sh --login -i -c '"%WORKSPACE%\build_%JOB_NAME%w%OS_BUILD%.sh"'
-%WD%sh --login -i -c '"%WORKSPACE%\build_%JOB_NAME%w%OS_BUILD%.sh"'</command>
- </builders>
- <publishers>
- <hudson.tasks.Mailer>
- <recipients>regina at arrival3d.com</recipients>
- <dontNotifyEveryUnstableBuild>true</dontNotifyEveryUnstableBuild>
- <sendToIndividuals>false</sendToIndividuals>
- </hudson.tasks.Mailer>
- </publishers>
- <buildWrappers/>
-</project>
diff --git a/windows/jobs/GEOS_Trunk_ming/nextBuildNumber b/windows/jobs/GEOS_Trunk_ming/nextBuildNumber
index 987e7ca..0000000
--- a/windows/jobs/GEOS_Trunk_ming/nextBuildNumber
+++ /dev/null
@@ -1 +0,0 @@
-77
diff --git a/windows/jobs/GEOS_Trunk_mingw64_build_all/config.xml b/windows/jobs/GEOS_Trunk_mingw64_build_all/config.xml
index 71954d1..0000000
--- a/windows/jobs/GEOS_Trunk_mingw64_build_all/config.xml
+++ /dev/null
@@ -1,104 +0,0 @@
-<project>
- <actions/>
- <logRotator>
- <numToKeep>4</numToKeep>
- </logRotator>
- <properties>
- </properties>
- <locations>
- </locations>
- </scm>
- <triggers class="vector">
- <hudson.triggers.SCMTrigger>
- <spec>5,10,20,30,40,50 * * * *</spec>
- </hudson.triggers.SCMTrigger>
- </triggers>
- <builders>
- <hudson.plugins.parameterizedtrigger.TriggerBuilder>
- <configs>
- <hudson.plugins.parameterizedtrigger.BlockableBuildTriggerConfig>
- <configs>
- <hudson.plugins.parameterizedtrigger.CurrentBuildParameters/>
- <hudson.plugins.parameterizedtrigger.PredefinedBuildParameters>
- <properties>OS_BUILD=32
-MING_HOST=i686-w64-mingw32</properties>
- </hudson.plugins.parameterizedtrigger.PredefinedBuildParameters>
- </configs>
- <projects>GEOS_Trunk_ming</projects>
- <condition>ALWAYS</condition>
- <triggerWithNoParameters>false</triggerWithNoParameters>
- <block>
- <unstableThreshold>
- <name>FAILURE</name>
- <ordinal>2</ordinal>
- <color>RED</color>
- </unstableThreshold>
- <failureThreshold>
- </failureThreshold>
- </block>
- <buildAllNodesWithLabel>false</buildAllNodesWithLabel>
- </hudson.plugins.parameterizedtrigger.BlockableBuildTriggerConfig>
- </configs>
- </hudson.plugins.parameterizedtrigger.TriggerBuilder>
- <configs>
- <configs>
- <properties>OS_BUILD=64
-MING_HOST=x86_64-w64-mingw32</properties>
- </configs>
- </configs>
- </builders>
- <publishers>
- <sendToIndividuals>true</sendToIndividuals>
- </publishers>
- <buildWrappers/>
-</project>
diff --git a/windows/jobs/GEOS_Trunk_mingw64_build_all/nextBuildNumber b/windows/jobs/GEOS_Trunk_mingw64_build_all/nextBuildNumber
index b6a7d89..0000000
--- a/windows/jobs/GEOS_Trunk_mingw64_build_all/nextBuildNumber
+++ /dev/null
@@ -1 +0,0 @@
-16
diff --git a/windows/jobs/PG_ED_STOP/config.xml b/windows/jobs/PG_ED_STOP/config.xml
index 0000000..e897cd8
--- /dev/null
+++ b/windows/jobs/PG_ED_STOP/config.xml
@@ -0,0 +1,100 @@
+<?xml version='1.0' encoding='UTF-8'?>
+<project>
+ <actions/>
+ <description>PostGIS regress for entrprise db Visual c++ compiled</description>
+ <logRotator class="hudson.tasks.LogRotator">
+ <daysToKeep>10</daysToKeep>
+ <numToKeep>30</numToKeep>
+ <artifactDaysToKeep>-1</artifactDaysToKeep>
+ <artifactNumToKeep>-1</artifactNumToKeep>
+ </logRotator>
+ <keepDependencies>false</keepDependencies>
+ <properties>
+ <hudson.model.ParametersDefinitionProperty>
+ <parameterDefinitions>
+ <hudson.model.StringParameterDefinition>
+ <name>PG_VER</name>
+ <description></description>
+ <defaultValue>9.3</defaultValue>
+ </hudson.model.StringParameterDefinition>
+ <name>OS_BUILD</name>
+ <defaultValue>64</defaultValue>
+ <name>PGPORT</name>
+ <defaultValue>7453</defaultValue>
+ <name>GEOS_VER</name>
+ <defaultValue>3.4.2</defaultValue>
+ <name>PROJ_VER</name>
+ <defaultValue>4.8.0</defaultValue>
+ <name>GDAL_VER</name>
+ <defaultValue>1.10.0</defaultValue>
+ <name>POSTGIS_MAJOR_VERSION</name>
+ <defaultValue>2</defaultValue>
+ <name>POSTGIS_MINOR_VERSION</name>
+ <name>POSTGIS_MICRO_VERSION</name>
+ <defaultValue>0dev</defaultValue>
+ <name>GCC_TYPE</name>
+ <defaultValue>gcc48</defaultValue>
+ <name>JSON_VER</name>
+ <defaultValue>0.10</defaultValue>
+ </parameterDefinitions>
+ </hudson.model.ParametersDefinitionProperty>
+ </properties>
+ <scm class="hudson.scm.NullSCM"/>
+ <canRoam>true</canRoam>
+ <disabled>false</disabled>
+ <blockBuildWhenDownstreamBuilding>false</blockBuildWhenDownstreamBuilding>
+ <blockBuildWhenUpstreamBuilding>false</blockBuildWhenUpstreamBuilding>
+ <triggers class="vector"/>
+ <concurrentBuild>false</concurrentBuild>
+ <customWorkspace>e:\jenkins\postgis</customWorkspace>
+ <builders>
+ <org.jenkinsci.plugins.managedscripts.WinBatchBuildStep plugin="managed-scripts at 1.0.2">
+ <command>org.jenkinsci.plugins.managedscripts.WinBatchConfig1353141929421</command>
+ </org.jenkinsci.plugins.managedscripts.WinBatchBuildStep>
+ <command>org.jenkinsci.plugins.managedscripts.WinBatchConfig1353142250187</command>
+ <command>org.jenkinsci.plugins.managedscripts.WinBatchConfig1353143619453</command>
+ </builders>
+ <publishers>
+ <hudson.tasks.Mailer plugin="mailer at 1.4">
+ <recipients></recipients>
+ <dontNotifyEveryUnstableBuild>true</dontNotifyEveryUnstableBuild>
+ <sendToIndividuals>false</sendToIndividuals>
+ </hudson.tasks.Mailer>
+ </publishers>
+ <buildWrappers/>
+</project>
diff --git a/windows/jobs/PG_ED_STOP/nextBuildNumber b/windows/jobs/PG_ED_STOP/nextBuildNumber
index 0000000..5333cde
--- /dev/null
+++ b/windows/jobs/PG_ED_STOP/nextBuildNumber
@@ -0,0 +1 @@
+22268
diff --git a/windows/jobs/Planet PostGIS refresh/config.xml b/windows/jobs/Planet PostGIS refresh/config.xml
index 9829438..0000000
--- a/windows/jobs/Planet PostGIS refresh/config.xml
+++ /dev/null
@@ -1,50 +0,0 @@
-<project>
- <actions/>
- <logRotator>
- <daysToKeep>4</daysToKeep>
- </logRotator>
- <properties/>
- <locations>
- <remote>http://svn.osgeo.org/postgis/planetpostgis</remote>
- <local>.</local>
- </locations>
- </scm>
- <hudson.triggers.TimerTrigger>
- <spec>5,10,15,20,30,35,40,50,55 * * * *</spec>
- </hudson.triggers.TimerTrigger>
- </triggers>
- <customWorkspace>C:\jenkins\planetpostgis\venus</customWorkspace>
- <builders>
- <command>set PATH=%PATH%;C:\ming64\projects\xsltproc;C:\Python27
-cd %WORKSPACE%
-REM del /S *.pyc
-REM del /S *.tmplc
-REM C:\python27\python runtests.py
-C:\python27\python planet.py planetpostgis.ini</command>
- </builders>
- <publishers/>
- <buildWrappers/>
-</project>
diff --git a/windows/jobs/Planet PostGIS refresh/nextBuildNumber b/windows/jobs/Planet PostGIS refresh/nextBuildNumber
index 0446c40..0000000
--- a/windows/jobs/Planet PostGIS refresh/nextBuildNumber
+++ /dev/null
@@ -1 +0,0 @@
-21442
diff --git a/windows/jobs/PostGIS_2_windows_PGVERSION_winnie/config.xml b/windows/jobs/PostGIS_2_windows_PGVERSION_winnie/config.xml
index 0000000..2ce9a6b
--- /dev/null
+++ b/windows/jobs/PostGIS_2_windows_PGVERSION_winnie/config.xml
@@ -0,0 +1,181 @@
+<?xml version='1.1' encoding='UTF-8'?>
+<project>
+ <actions/>
+ <description>PostGIS 2 major branch build for a specific version of PostgreSQL and port,
+using builds script store in branch/ci/winnie being build</description>
+ <properties>
+ <jenkins.model.BuildDiscarderProperty>
+ <strategy class="hudson.tasks.LogRotator">
+ <daysToKeep>3</daysToKeep>
+ <numToKeep>10</numToKeep>
+ </strategy>
+ </jenkins.model.BuildDiscarderProperty>
+ <description> </description>
+ <defaultValue>10</defaultValue>
+ <trim>false</trim>
+ <defaultValue>32</defaultValue>
+ <defaultValue>9445</defaultValue>
+ <defaultValue>3.6.2</defaultValue>
+ <defaultValue>2.2.3</defaultValue>
+ <defaultValue>4.9.3</defaultValue>
+ <name>POSTGIS_SVN_REVISION</name>
+ <defaultValue>15475</defaultValue>
+ <defaultValue>4</defaultValue>
+ <defaultValue>0</defaultValue>
+ <defaultValue>0.12</defaultValue>
+ <name>SFCGAL_VER</name>
+ <defaultValue></defaultValue>
+ <name>PCRE_VER</name>
+ <defaultValue>8.33</defaultValue>
+ <name>SOURCE_FOLDER</name>
+ <defaultValue>branches\2.4</defaultValue>
+ <name>OVERRIDE</name>
+ <name>CGAL_VER</name>
+ <defaultValue>4.11</defaultValue>
+ <defaultValue>1.3.2</defaultValue>
+ <name>ICON_VER</name>
+ <name>LIBXML_VER</name>
+ <defaultValue>2.9.9</defaultValue>
+ </properties>
+ <triggers/>
+ <customWorkspace>E:\jenkins\postgis</customWorkspace>
+ <builders>
+ <org.jenkinsci.plugins.conditionalbuildstep.ConditionalBuilder plugin="conditional-buildstep at 1.3.6">
+ <runner class="org.jenkins_ci.plugins.run_condition.BuildStepRunner$Fail" plugin="run-condition at 1.2"/>
+ <runCondition class="org.jenkins_ci.plugins.run_condition.contributed.BatchFileCondition" plugin="run-condition at 1.2">
+ <command>set WD=C:\ming%OS_BUILD%%GCC_TYPE%\msys\usr\bin\
+set MSYSTEM=MINGW%OS_BUILD%
+PATH=C:\ming%OS_BUILD%%GCC_TYPE%\msys\bin\;C:\ming%OS_BUILD%%GCC_TYPE%\msys\usr\bin\;%PATH%
+ at SET PGPORT=%PGPORT:.=%
+%WD%sh --login -c '"%WORKSPACE%\%SOURCE_FOLDER%\ci\winnie\build_postgis.sh"'</command>
+ </runCondition>
+ <conditionalbuilders>
+ <hudson.tasks.BatchFile>
+%WD%sh --login -c '"%WORKSPACE%\%SOURCE_FOLDER%\ci\winnie\package_postgis.sh"'</command>
+ </hudson.tasks.BatchFile>
+ </conditionalbuilders>
+ </org.jenkinsci.plugins.conditionalbuildstep.ConditionalBuilder>
+ <command>E:
+cd E:\jenkins\postgis\win_web\download\windows
+set pgfolder=pg%PG_VER%
+REM strip .
+set pgfolder=%pgfolder:.=%
+copy /Y %pgfolder%\buildbot\postgis-%pgfolder%-binaries-%POSTGIS_MAJOR_VERSION%.%POSTGIS_MINOR_VERSION%.%POSTGIS_MICRO_VERSION%w%OS_BUILD%%GCC_TYPE%.zip appveyor\postgis-%pgfolder%-binaries-%POSTGIS_MAJOR_VERSION%.%POSTGIS_MINOR_VERSION%w%OS_BUILD%%GCC_TYPE%.zip</command>
+ </builders>
+ <publishers/>
+ <buildWrappers/>
+</project>
diff --git a/windows/jobs/PostGIS_2_windows_PGVERSION_winnie/nextBuildNumber b/windows/jobs/PostGIS_2_windows_PGVERSION_winnie/nextBuildNumber
index 0000000..45ff58e
--- /dev/null
+++ b/windows/jobs/PostGIS_2_windows_PGVERSION_winnie/nextBuildNumber
@@ -0,0 +1 @@
+10631
diff --git a/windows/jobs/PostGIS_Deploy_SrcTar/config.xml b/windows/jobs/PostGIS_Deploy_SrcTar/config.xml
index 71709ad..0000000
--- a/windows/jobs/PostGIS_Deploy_SrcTar/config.xml
+++ /dev/null
@@ -1,100 +0,0 @@
-<project>
- <actions/>
- <description>PostGIS is an extension to the PostgreSQL object-relational database system which allows GIS (Geographic Information Systems) objects to be stored in the database. PostGIS includes support for GiST-based R-Tree spatial indexes, and functions for analysis and processing of GIS objects.
-<p>
-This project contains the packaging scripts for the <b>latest development snapshot</b> of PostGIS which build after every successful build of PostGIS-trunk-build job.
-</description>
- <logRotator>
- <daysToKeep>-1</daysToKeep>
- <numToKeep>1</numToKeep>
- </logRotator>
- <properties>
- <name>POSTGIS_TAG</name>
- <description>The svn revision of this build (updates the revision variable on the PostGIS website)</description>
- <defaultValue>trunk</defaultValue>
- <name>POSTGIS_MAJOR_VERSION</name>
- <description>The latest artifact version (major) to deploy to the PostGIS website from the PostGIS_trunk_build project</description>
- <defaultValue>2</defaultValue>
- <name>POSTGIS_MINOR_VERSION</name>
- <description>The latest artifact version (minor) to deploy to the PostGIS website from the PostGIS_trunk_build project</description>
- <name>POSTGIS_MICRO_VERSION</name>
- <description>The latest artifact version (micro) to deploy to the PostGIS website from the build project</description>
- <defaultValue>0SVN</defaultValue>
- <defaultValue>1.9.1</defaultValue>
- <name>LIBXML_VER</name>
- <defaultValue>2.7.8</defaultValue>
- <name>PG_VER</name>
- <defaultValue>9.1</defaultValue>
- <name>PROJ_VER</name>
- <defaultValue>4.8.0</defaultValue>
- </properties>
- <locations>
- <remote>http://svn.osgeo.org/postgis/buildbots/windows/mingw64/scripts</remote>
- <local>mingw64/scripts</local>
- </locations>
- </scm>
- <customWorkspace>C:\jenkins\postgis</customWorkspace>
- <builders>
-%WD%sh --login -i -c '"%WORKSPACE%\mingw64\scripts\make_dist_src.sh"'</command>
- </builders>
- <publishers/>
- <buildWrappers/>
-</project>
diff --git a/windows/jobs/PostGIS_Deploy_SrcTar/nextBuildNumber b/windows/jobs/PostGIS_Deploy_SrcTar/nextBuildNumber
index 1e8b314..0000000
--- a/windows/jobs/PostGIS_Deploy_SrcTar/nextBuildNumber
+++ /dev/null
@@ -1 +0,0 @@
-6
diff --git a/windows/jobs/PostGIS_EDB_Regress_winnie/config.xml b/windows/jobs/PostGIS_EDB_Regress_winnie/config.xml
index 0000000..04be83a
--- /dev/null
+++ b/windows/jobs/PostGIS_EDB_Regress_winnie/config.xml
@@ -0,0 +1,206 @@
+<project>
+ <actions/>
+ <properties>
+ </strategy>
+ <defaultValue>9442</defaultValue>
+ <defaultValue>3.8.1</defaultValue>
+ <defaultValue>5.2.0</defaultValue>
+ <defaultValue>2.4.4</defaultValue>
+ <defaultValue>5</defaultValue>
+ <defaultValue>3dev</defaultValue>
+ <defaultValue>1.3.8</defaultValue>
+ <name>PROJSO</name>
+ <defaultValue>libproj-13.dll</defaultValue>
+ <name>MAKE_EXTENSION</name>
+ <defaultValue>1</defaultValue>
+ <defaultValue>branches\2.5</defaultValue>
+ <name>PROTOBUF_VER</name>
+ <defaultValue>3.2.0</defaultValue>
+ <name>PROTOBUFC_VER</name>
+ <defaultValue>1.2.1</defaultValue>
+ <name>ZLIB_VER</name>
+ <defaultValue>1.2.11</defaultValue>
+ <defaultValue>2.7.8</defaultValue>
+ <defaultValue>1.15</defaultValue>
+ </properties>
+ <triggers/>
+ <builders>
+ <org.jenkinsci.plugins.managedscripts.WinBatchBuildStep plugin="managed-scripts at 1.4">
+ <configuredLocalRules/>
+bash --login -c '"%WORKSPACE%\%SOURCE_FOLDER%\ci\winnie\regress_postgis.sh"'</command>
+ </builders>
+ <publishers>
+ <hudson.tasks.Mailer plugin="mailer at 1.32">
+ <hudson.plugins.parameterizedtrigger.BuildTrigger plugin="parameterized-trigger at 2.37">
+ <configs>
+ <hudson.plugins.parameterizedtrigger.BuildTriggerConfig>
+ <configs>
+ <hudson.plugins.parameterizedtrigger.CurrentBuildParameters/>
+ </configs>
+ <projects>PG_ED_STOP</projects>
+ <condition>ALWAYS</condition>
+ <triggerWithNoParameters>false</triggerWithNoParameters>
+ <triggerFromChildProjects>false</triggerFromChildProjects>
+ </hudson.plugins.parameterizedtrigger.BuildTriggerConfig>
+ </configs>
+ </hudson.plugins.parameterizedtrigger.BuildTrigger>
+ </publishers>
+ <buildWrappers/>
+</project>
diff --git a/windows/jobs/PostGIS_EDB_Regress_winnie/nextBuildNumber b/windows/jobs/PostGIS_EDB_Regress_winnie/nextBuildNumber
index 0000000..c3e86be
--- /dev/null
+++ b/windows/jobs/PostGIS_EDB_Regress_winnie/nextBuildNumber
@@ -0,0 +1 @@
+12232
diff --git a/windows/jobs/Upload Windows Builds/config.xml b/windows/jobs/Upload Windows Builds/config.xml
index 04f9576..0000000
--- a/windows/jobs/Upload Windows Builds/config.xml
+++ /dev/null
@@ -1,64 +0,0 @@
-<project>
- <actions/>
- <properties>
- </properties>
- <scm class="hudson.scm.NullSCM"/>
- <customWorkspace>c:\jenkins\postgis\</customWorkspace>
- <builders/>
- <publishers>
- <be.certipost.hudson.plugin.SCPRepositoryPublisher plugin="scp at 1.8">
- <siteName>www.refractions.net</siteName>
- <entries>
- <be.certipost.hudson.plugin.Entry>
- <filePath>download/windows/pg92/buildbot</filePath>
- <sourceFile>builds/2.1/postgis-pg92*.zip</sourceFile>
- <keepHierarchy>false</keepHierarchy>
- </be.certipost.hudson.plugin.Entry>
- <filePath>versioning/</filePath>
- <sourceFile>builds/2.1/*.php</sourceFile>
- <filePath>download/windows/pg91/buildbot</filePath>
- <sourceFile>builds/2.1/postgis-pg91*.zip</sourceFile>
- <filePath>download/windows/pg90/buildbot</filePath>
- <sourceFile>builds/2.1/postgis-pg90*.zip</sourceFile>
- </entries>
- </be.certipost.hudson.plugin.SCPRepositoryPublisher>
- </publishers>
- <buildWrappers/>
-</project>
diff --git a/windows/jobs/Upload Windows Builds/nextBuildNumber b/windows/jobs/Upload Windows Builds/nextBuildNumber
index 8160622..0000000
--- a/windows/jobs/Upload Windows Builds/nextBuildNumber
+++ /dev/null
@@ -1 +0,0 @@
-303
diff --git a/windows/jobs/pgRouting_PGVersionEDB/config.xml b/windows/jobs/pgRouting_PGVersionEDB/config.xml
index 0000000..8d0fd62
--- /dev/null
+++ b/windows/jobs/pgRouting_PGVersionEDB/config.xml
@@ -0,0 +1,140 @@
+<project>
+ <actions/>
+ <description>Builds, regresses and packages pgRouting 2 for specific PostgreSQL version and OS_BUILD (32/64 bit)</description>
+ <properties>
+ <defaultValue>9.4</defaultValue>
+ <defaultValue>10444</defaultValue>
+ <defaultValue>2.2.1</defaultValue>
+ <defaultValue>3.7.0dev</defaultValue>
+ <defaultValue>4.9.1</defaultValue>
+ <name>PGROUTING_MICRO_VER</name>
+ <name>POSTGIS_VER</name>
+ <defaultValue>2.4.0dev</defaultValue>
+ <defaultValue>gcc81</defaultValue>
+ <name>GIT_COMMIT</name>
+ <name>PGROUTING_VER</name>
+ <defaultValue>folder</defaultValue>
+ </properties>
+ <triggers/>
+ <customWorkspace>E:\jenkins\pgrouting\branches\</customWorkspace>
+ <builders>
+ <command>IF "%GCC_TYPE%" == "gcc45" (@SET GCC_TYPE=)
+set WD=C:\ming%OS_BUILD%%GCC_TYPE%\msys\usr\bin\
+REM set WD=C:\ming%OS_BUILD%%GCC_TYPE%\msys1\bin\
+cd e:\jenkins\pgrouting\branches\%PGROUTING_VER%
+%WD%sh --login -c '"e:\jenkins\pgrouting\branches\%PGROUTING_VER%\tools\winnie\build_pgrouting.sh"'
+</command>
+REM set WD=C:\ming%OS_BUILD%%GCC_TYPE%\msys\bin\
+%WD%sh --login -c '"e:\jenkins\pgrouting\branches\%PGROUTING_VER%\tools\winnie\package_pgrouting.sh"'</command>
+ <org.jenkinsci.plugins.conditionalbuildstep.singlestep.SingleConditionalBuilder plugin="conditional-buildstep at 1.3.6">
+ <condition class="org.jenkins_ci.plugins.run_condition.core.AlwaysRun" plugin="run-condition at 1.3"/>
+ <buildStep class="hudson.plugins.parameterizedtrigger.TriggerBuilder" plugin="parameterized-trigger at 2.36">
+ <configs>
+ <hudson.plugins.parameterizedtrigger.BlockableBuildTriggerConfig>
+ <configs>
+ </configs>
+ <buildAllNodesWithLabel>false</buildAllNodesWithLabel>
+ </hudson.plugins.parameterizedtrigger.BlockableBuildTriggerConfig>
+ </configs>
+ </buildStep>
+ <runner class="org.jenkins_ci.plugins.run_condition.BuildStepRunner$Fail" plugin="run-condition at 1.3"/>
+ </org.jenkinsci.plugins.conditionalbuildstep.singlestep.SingleConditionalBuilder>
+ </builders>
+ <publishers/>
+ <buildWrappers/>
+</project>
diff --git a/windows/jobs/pgRouting_PGVersionEDB/nextBuildNumber b/windows/jobs/pgRouting_PGVersionEDB/nextBuildNumber
index 0000000..ac7be74
--- /dev/null
+++ b/windows/jobs/pgRouting_PGVersionEDB/nextBuildNumber
@@ -0,0 +1 @@
+9145
Summary of changes:
raspberry_pi/berrie64.txt => debian/reallie.txt | 4 +-
freebsd/bessie_setup.txt | 18 ++
windows/jobs/GDAL_Branch_1.9_w64_win64/config.xml | 71 -------
.../jobs/GDAL_Branch_1.9_w64_win64/nextBuildNumber | 1 -
windows/jobs/GEOS_Trunk_ming/config.xml | 90 ---------
windows/jobs/GEOS_Trunk_ming/nextBuildNumber | 1 -
.../jobs/GEOS_Trunk_mingw64_build_all/config.xml | 104 -----------
.../GEOS_Trunk_mingw64_build_all/nextBuildNumber | 1 -
.../config.xml | 41 +---
windows/jobs/PG_ED_STOP/nextBuildNumber | 1 +
windows/jobs/Planet PostGIS refresh/config.xml | 50 -----
.../jobs/Planet PostGIS refresh/nextBuildNumber | 1 -
.../PostGIS_2_windows_PGVERSION_winnie/config.xml | 181 ++++++++++++++++++
.../nextBuildNumber | 1 +
windows/jobs/PostGIS_Deploy_SrcTar/config.xml | 100 ----------
windows/jobs/PostGIS_Deploy_SrcTar/nextBuildNumber | 1 -
windows/jobs/PostGIS_EDB_Regress_winnie/config.xml | 206 +++++++++++++++++++++
.../PostGIS_EDB_Regress_winnie/nextBuildNumber | 1 +
windows/jobs/Upload Windows Builds/config.xml | 64 -------
windows/jobs/Upload Windows Builds/nextBuildNumber | 1 -
windows/jobs/pgRouting_PGVersionEDB/config.xml | 140 ++++++++++++++
.../jobs/pgRouting_PGVersionEDB/nextBuildNumber | 1 +
22 files changed, 561 insertions(+), 518 deletions(-)
copy raspberry_pi/berrie64.txt => debian/reallie.txt (84%)
delete mode 100644 windows/jobs/GDAL_Branch_1.9_w64_win64/config.xml
delete mode 100644 windows/jobs/GDAL_Branch_1.9_w64_win64/nextBuildNumber
delete mode 100644 windows/jobs/GEOS_Trunk_ming/config.xml
delete mode 100644 windows/jobs/GEOS_Trunk_ming/nextBuildNumber
delete mode 100644 windows/jobs/GEOS_Trunk_mingw64_build_all/config.xml
delete mode 100644 windows/jobs/GEOS_Trunk_mingw64_build_all/nextBuildNumber
copy windows/jobs/{PostGIS_mingW_regress => PG_ED_STOP}/config.xml (73%)
create mode 100644 windows/jobs/PG_ED_STOP/nextBuildNumber
delete mode 100644 windows/jobs/Planet PostGIS refresh/config.xml
delete mode 100644 windows/jobs/Planet PostGIS refresh/nextBuildNumber
create mode 100644 windows/jobs/PostGIS_2_windows_PGVERSION_winnie/config.xml
create mode 100644 windows/jobs/PostGIS_2_windows_PGVERSION_winnie/nextBuildNumber
delete mode 100644 windows/jobs/PostGIS_Deploy_SrcTar/config.xml
delete mode 100644 windows/jobs/PostGIS_Deploy_SrcTar/nextBuildNumber
create mode 100644 windows/jobs/PostGIS_EDB_Regress_winnie/config.xml
create mode 100644 windows/jobs/PostGIS_EDB_Regress_winnie/nextBuildNumber
delete mode 100644 windows/jobs/Upload Windows Builds/config.xml
delete mode 100644 windows/jobs/Upload Windows Builds/nextBuildNumber
create mode 100644 windows/jobs/pgRouting_PGVersionEDB/config.xml
create mode 100644 windows/jobs/pgRouting_PGVersionEDB/nextBuildNumber
hooks/post-receive
