[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-428-g1b67b83
Tue Aug 24 20:27:19 PDT 2021
the project "PostGIS".
       via  1b67b830c052a3ce770f47ad04d467acf6087cf8 (commit)
      from  1045eede8bf6c781707e5aa25bff3b16b789a086 (commit)
revisions in full, below.
commit 1b67b830c052a3ce770f47ad04d467acf6087cf8
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Aug 24 23:27:14 2021 -0400
    Add in missing availability and enhanced notes for ST_Point* functions, add an example using srid for ST_Point
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 8827d4e..e3c926c 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -673,6 +673,7 @@ FROM provinces p;
 		<note><para>For geodetic coordinates, <varname>X</varname> is longitude and <varname>Y</varname> is latitude</para></note>
 		<para>&sqlmm_compliant; SQL-MM 3: 6.1.2</para>
+        <para>Enhanced: 3.2.0 now allows for a 3rd argument that is the srid</para>
 	  </refsection>
@@ -680,12 +681,14 @@ FROM provinces p;
 	  <refsection>
 		<title>Examples: Geometry</title>
-		<programlisting>SELECT ST_SetSRID( ST_Point( -71.104, 42.315), 4326)</programlisting>
+        <programlisting>SELECT ST_Point( -71.104, 42.315, 4326)</programlisting>
+		<programlisting>SELECT ST_Point( -71.104, 42.315)</programlisting>
 	  </refsection>
 	  <refsection>
 		<title>Examples: Geography</title>
+		<programlisting>SELECT CAST(ST_Point(-71.104, 42.315, 4326) AS geography);</programlisting>
 		<programlisting>SELECT CAST(ST_SetSRID( ST_Point( -71.104, 42.315), 4326) AS geography);</programlisting>
 		<para>PostgreSQL also provides the <varname>::</varname> short-hand for casting</para>
@@ -730,6 +733,7 @@ SELECT ST_Transform(ST_SetSRID( ST_Point( 3637510, 3014852 ), 2273), 4326)::geog
       <refsection>
         <title>Description</title>
         <para>Returns an Point with the given X, Y and Z coordinate values, and optionally an SRID number.</para>
+        <para>Availability: 3.2.0</para>
       </refsection>
       <refsection>
@@ -766,6 +770,7 @@ SELECT ST_Transform(ST_SetSRID( ST_Point( 3637510, 3014852 ), 2273), 4326)::geog
       <refsection>
         <para>Returns an Point with the given X, Y and M coordinate values, and optionally an SRID number.</para>
       </refsection>
       <refsection>
@@ -804,6 +809,7 @@ SELECT ST_Transform(ST_SetSRID( ST_Point( 3637510, 3014852 ), 2273), 4326)::geog
       <refsection>
         <para>Returns an Point with the given X, Y, Z and M coordinate values, and optionally an SRID number.</para>
       </refsection>
       <refsection>
Summary of changes:
 doc/reference_constructor.xml | 8 +++++++-
 1 file changed, 7 insertions(+), 1 deletion(-)
hooks/post-receive
