[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-429-g2e34b53
git at osgeo.org
git at osgeo.org
Tue Aug 24 22:08:49 PDT 2021
the project "PostGIS".
via 2e34b5345425065e56eee17e3a829e53bda5af67 (commit)
from 1b67b830c052a3ce770f47ad04d467acf6087cf8 (commit)
revisions in full, below.
commit 2e34b5345425065e56eee17e3a829e53bda5af67
Author: Regina Obe <lr at pcorp.us>
Date: Wed Aug 25 01:08:44 2021 -0400
Minor typos and the_geom to geom from Bruce Rindahl. Closes https://github.com/postgis/postgis/pull/629
diff --git a/doc/administration.xml b/doc/administration.xml
index eb7c081..a6204c6 100644
--- a/doc/administration.xml
+++ b/doc/administration.xml
@@ -249,7 +249,7 @@ environment).</para></note>
ALTER EXTENSION postgis_topology UPDATE TO "&last_release_version;";</programlisting>
<para>If you get an error notice something like:</para>
<programlisting>No migration path defined for ... to &last_release_version;</programlisting>
- <para>Then you'll need to backup your database, create a fresh one as described in <xref linkend="create_new_db_extensions" /> and then restore your backup ontop of this new database.</para>
+ <para>Then you'll need to backup your database, create a fresh one as described in <xref linkend="create_new_db_extensions" /> and then restore your backup on top of this new database.</para>
<para>If you get a notice message like:</para>
<programlisting>Version "&last_release_version;" of extension "postgis" is already installed</programlisting>
<para>
diff --git a/doc/extras.xml b/doc/extras.xml
index 144782c..82fc17e 100644
--- a/doc/extras.xml
+++ b/doc/extras.xml
@@ -3,7 +3,7 @@
<title>PostGIS Extras</title>
<para>This chapter documents features found in the extras folder of the PostGIS source tarballs and source repository. These
- are not always packaged with PostGIS binary releases, but are usually plpgsql based or standard shell scripts that can be run as is.</para>
+ are not always packaged with PostGIS binary releases, but are usually PL/pgSQL based or standard shell scripts that can be run as is.</para>
&extras_address_standardizer;
&extras_tigergeocoder;
diff --git a/doc/extras_address_standardizer.xml b/doc/extras_address_standardizer.xml
index 8ca5985..f70a6d4 100644
--- a/doc/extras_address_standardizer.xml
+++ b/doc/extras_address_standardizer.xml
@@ -3,7 +3,7 @@
<title>Address Standardizer</title>
<para>This is a fork of the <ulink url="http://www.pagcgeo.org/docs/html/pagc-11.html">PAGC standardizer</ulink> (original code for this portion was <ulink url="http://sourceforge.net/p/pagc/code/360/tree/branches/sew-refactor/postgresql">PAGC PostgreSQL Address Standardizer</ulink>). </para>
<para>The address standardizer is a single line address parser that takes an input address and normalizes it based on a set of rules stored in a table and helper lex and gaz tables.</para>
- <para>The code is built into a single postgresql extension library called <code>address_standardizer</code> which can be installed with <code>CREATE EXTENSION address_standardizer;</code>. In addition to the address_standardizer extension, a sample data extension called <code>address_standardizer_data_us</code> extensions is built, which contains gaz, lex, and rules tables for US data. This extensions can be installed via: <code>CREATE EXTENSION address_standardizer_data_us;</code></para>
+ <para>The code is built into a single PostgreSQL extension library called <code>address_standardizer</code> which can be installed with <code>CREATE EXTENSION address_standardizer;</code>. In addition to the address_standardizer extension, a sample data extension called <code>address_standardizer_data_us</code> extensions is built, which contains gaz, lex, and rules tables for US data. This extensions can be installed via: <code>CREATE EXTENSION address_standardizer_data_us;</code></para>
<para>The code for this extension can be found in the PostGIS <filename>extensions/address_standardizer</filename> and is currently self-contained.</para>
<para>For installation instructions refer to: <xref linkend="installing_pagc_address_standardizer" />.</para>
<sect2 id="Address_Standardizer_Basics"><title>How the Parser Works</title>
diff --git a/doc/extras_historytable.xml b/doc/extras_historytable.xml
index 6b2d4d4..c15120f 100644
--- a/doc/extras_historytable.xml
+++ b/doc/extras_historytable.xml
@@ -82,7 +82,7 @@
<refentry id="Postgis_Enable_History">
<refnamediv>
<refname>Postgis_Enable_History</refname>
- <refpurpose>Registers a tablein the history_information table for tracking and also adds in side line history table and insert, update, delete rules on the table.</refpurpose>
+ <refpurpose>Registers a table in the history_information table for tracking and also adds in side line history table and insert, update, delete rules on the table.</refpurpose>
</refnamediv>
<refsynopsisdiv>
diff --git a/doc/extras_tigergeocoder.xml b/doc/extras_tigergeocoder.xml
index e117e0f..bd39dd3 100644
--- a/doc/extras_tigergeocoder.xml
+++ b/doc/extras_tigergeocoder.xml
@@ -148,7 +148,7 @@ DROP INDEX tiger_data.idx_tiger_data_ma_county_snd_name;
<refsection>
<title>Description</title>
- <para>Generates a script that drops all tables in the specified schema that start with <varname>county_all</varname>, <varname>state_all</varname> or stae code followed by <varname>county</varname> or <varname>state</varname>. This is needed if you are upgrading from <varname>tiger_2010</varname> to <varname>tiger_2011</varname> data.</para>
+ <para>Generates a script that drops all tables in the specified schema that start with <varname>county_all</varname>, <varname>state_all</varname> or state code followed by <varname>county</varname> or <varname>state</varname>. This is needed if you are upgrading from <varname>tiger_2010</varname> to <varname>tiger_2011</varname> data.</para>
<para>Availability: 2.1.0</para>
@@ -514,7 +514,7 @@ false
<para>Given a geometry will return the census tract location of that geometry. NAD 83 long lat is assumed if no spatial ref sys is specified.</para>
- <note><para>This function uses the census <varname>tract</varname> whic is not loaded by default. If you have already loaded your state table, you can load tract
+ <note><para>This function uses the census <varname>tract</varname> which is not loaded by default. If you have already loaded your state table, you can load tract
as well as bg, and tabblock using the <xref linkend="Loader_Generate_Census_Script" /> script.</para>
<para>If you have not loaded your state data yet and want these additional tables loaded, do the following</para>
<programlisting>UPDATE tiger.loader_lookuptables SET load = true WHERE load = false AND lookup_name IN('tract', 'bg', 'tabblock');</programlisting>
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index b74f48b..78ccbfd 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -801,7 +801,7 @@ to take care of that.
That the statistics updated by autovacuum
will NOT be visible to transactions which started before autovacuum
process completed, so long-running transactions will need to run
-ANALYZE themeselves, to use updated statistics.
+ANALYZE themselves, to use updated statistics.
</para>
</note>
diff --git a/doc/faq.xml b/doc/faq.xml
index 1d4a065..8bf4b8b 100644
--- a/doc/faq.xml
+++ b/doc/faq.xml
@@ -218,10 +218,10 @@ VALUES (
<emphasis>might</emphasis> meet the condition of interest. The spatial
functions are then use to test the condition exactly.</para>
- <programlisting>SELECT id, the_geom
+ <programlisting>SELECT id, geom
FROM thetable
WHERE
- ST_Contains(the_geom,'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))');</programlisting>
+ ST_Contains(geom,'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))');</programlisting>
</answer>
</qandaentry>
@@ -358,9 +358,9 @@ WHERE ST_DWithin(geocolumn, 'POINT(1000 1000)', 100.0);</programlisting>
the geometries being reprojected must already have an SRID set on
them. Once that is done, a reprojection is as simple as referring to
the desired destination SRID. The below projects a geometry to NAD 83 long lat.
- The below will only work if the srid of the_geom is not -1 (not undefined spatial ref)</para>
+ The below will only work if the srid of geom is not -1 (not undefined spatial ref)</para>
- <programlisting>SELECT ST_Transform(the_geom,4269) FROM geotable;</programlisting>
+ <programlisting>SELECT ST_Transform(geom,4269) FROM geotable;</programlisting>
</answer>
</qandaentry>
@@ -375,7 +375,7 @@ WHERE ST_DWithin(geocolumn, 'POINT(1000 1000)', 100.0);</programlisting>
<programlisting>
--To check number of geometries are really blank
- SELECT count(gid) FROM geotable WHERE the_geom IS NULL;</programlisting>
+ SELECT count(gid) FROM geotable WHERE geom IS NULL;</programlisting>
</answer>
</qandaentry>
@@ -432,7 +432,7 @@ WHERE ST_DWithin(geocolumn, 'POINT(1000 1000)', 100.0);</programlisting>
</para>
<para>Furthermore, PostGIS operations contain error-prevention code which may peturb
- input geometries by tiny amounts in order to prevent robustness errors from occuring.
+ input geometries by tiny amounts in order to prevent robustness errors from occurring.
These minor alterations also may produce computed results which are not fully consistent.
</para>
diff --git a/doc/faq_raster.xml b/doc/faq_raster.xml
index bcf9221..68f90b3 100644
--- a/doc/faq_raster.xml
+++ b/doc/faq_raster.xml
@@ -37,7 +37,7 @@
</question>
<answer>
- <para>PostGIS Raster is part of the PostGIS codebase and generally available with most PostGIS binary distributions. Starting with PostGIS 3.0, PostGIS raster is now a separate extension and requires: `CREATE EXTENSION postgis_raster;` to enable it in your database. If you are compiling your own PostGIS, you will need to compile with GDAL otherwise postgis_raster extension will not be builit.</para>
+ <para>PostGIS Raster is part of the PostGIS codebase and generally available with most PostGIS binary distributions. Starting with PostGIS 3.0, PostGIS raster is now a separate extension and requires: `CREATE EXTENSION postgis_raster;` to enable it in your database. If you are compiling your own PostGIS, you will need to compile with GDAL otherwise postgis_raster extension will not be built.</para>
<para>Refer to <ulink url="http://postgis.net/install/">Download PostGIS binaries</ulink> for popular distributions of PostGIS that include raster support.</para>
</answer>
</qandaentry>
diff --git a/doc/performance_tips.xml b/doc/performance_tips.xml
index e38a357..3b9db46 100644
--- a/doc/performance_tips.xml
+++ b/doc/performance_tips.xml
@@ -61,7 +61,7 @@
example, the commands are like:</para>
<programlisting>SELECT AddGeometryColumn('myschema','mytable','bbox','4326','GEOMETRY','2');
-UPDATE mytable SET bbox = ST_Envelope(ST_Force2D(the_geom));</programlisting>
+UPDATE mytable SET bbox = ST_Envelope(ST_Force2D(geom));</programlisting>
<para>Now change your query to use the && operator against bbox
instead of geom_column, like:</para>
@@ -97,12 +97,12 @@ WHERE bbox && ST_SetSRID('BOX3D(0 0,1 1)'::box3d,4326);</programlisting>
<programlisting>lwgeom=# CLUSTER my_geom_index ON my_table;
ERROR: cannot cluster when index access method does not handle null values
-HINT: You may be able to work around this by marking column "the_geom" NOT NULL.</programlisting>
+HINT: You may be able to work around this by marking column "geom" NOT NULL.</programlisting>
<para>As the HINT message tells you, one can work around this deficiency
by adding a "not null" constraint to the table:</para>
- <programlisting>lwgeom=# ALTER TABLE my_table ALTER COLUMN the_geom SET not null;
+ <programlisting>lwgeom=# ALTER TABLE my_table ALTER COLUMN geom SET not null;
ALTER TABLE</programlisting>
<para>Of course, this will not work if you in fact need NULL values in
@@ -121,7 +121,7 @@ ALTER TABLE</programlisting>
overhead for large geometries. To avoid this overhead, it may be feasible
to pre-drop those additional dimensions once and forever:</para>
- <programlisting>UPDATE mytable SET the_geom = ST_Force2D(the_geom);
+ <programlisting>UPDATE mytable SET geom = ST_Force2D(geom);
VACUUM FULL ANALYZE mytable;</programlisting>
<para>Note that if you added your geometry column using
@@ -136,7 +136,7 @@ VACUUM FULL ANALYZE mytable;</programlisting>
running a simple "VACUUM;" between your UPDATEs. This drastically reduces
the need for temporary disk space. Additionally, if you have mixed
dimension geometries, restricting the UPDATE by "WHERE
- dimension(the_geom)>2" skips re-writing of geometries that already are
+ dimension(geom)>2" skips re-writing of geometries that already are
in 2D.</para>
</sect1>
diff --git a/doc/reference_accessor.xml b/doc/reference_accessor.xml
index 4838163..0a09c18 100644
--- a/doc/reference_accessor.xml
+++ b/doc/reference_accessor.xml
@@ -437,7 +437,7 @@ ST_Dimension
<refsection>
<title>Standard Examples</title>
<programlisting>SELECT sometable.field1, sometable.field1,
- (ST_Dump(sometable.the_geom)).geom AS the_geom
+ (ST_Dump(sometable.geom)).geom AS geom
FROM sometable;
-- Break a compound curve into its constituent linestrings and circularstrings
@@ -911,18 +911,18 @@ FROM (
<title>Examples</title>
<para>General form of query.</para>
<programlisting>SELECT polyTable.field1, polyTable.field1,
- (ST_DumpRings(polyTable.the_geom)).geom As the_geom
+ (ST_DumpRings(polyTable.geom)).geom As geom
FROM polyTable;
</programlisting>
<para>A polygon with a single hole.</para>
-<programlisting>SELECT path, ST_AsEWKT(geom) As the_geom
+<programlisting>SELECT path, ST_AsEWKT(geom) As geom
FROM ST_DumpRings(
ST_GeomFromEWKT('POLYGON((-8149064 5133092 1,-8149064 5132986 1,-8148996 5132839 1,-8148972 5132767 1,-8148958 5132508 1,-8148941 5132466 1,-8148924 5132394 1,
-8148903 5132210 1,-8148930 5131967 1,-8148992 5131978 1,-8149237 5132093 1,-8149404 5132211 1,-8149647 5132310 1,-8149757 5132394 1,
-8150305 5132788 1,-8149064 5133092 1),
(-8149362 5132394 1,-8149446 5132501 1,-8149548 5132597 1,-8149695 5132675 1,-8149362 5132394 1))')
) as foo;
- path | the_geom
+ path | geom
{0} | POLYGON((-8149064 5133092 1,-8149064 5132986 1,-8148996 5132839 1,-8148972 5132767 1,-8148958 5132508 1,
@@ -1159,13 +1159,13 @@ POLYGON((20 75,20 150,125 150,125 75,20 75))</programlisting>
<programlisting>
--If you have a table of polygons
-SELECT gid, ST_ExteriorRing(the_geom) AS ering
+SELECT gid, ST_ExteriorRing(geom) AS ering
FROM sometable;
--If you have a table of MULTIPOLYGONs
--and want to return a MULTILINESTRING composed of the exterior rings of each polygon
-SELECT gid, ST_Collect(ST_ExteriorRing(the_geom)) AS erings
- FROM (SELECT gid, (ST_Dump(the_geom)).geom As the_geom
+SELECT gid, ST_Collect(ST_ExteriorRing(geom)) AS erings
+ FROM (SELECT gid, (ST_Dump(geom)).geom As geom
FROM sometable) As foo
GROUP BY gid;
@@ -1241,13 +1241,13 @@ LINESTRING(0 0 1,1 1 1,1 2 1,1 1 1,0 0 1)
<programlisting>--Extracting a subset of points from a 3d multipoint
-SELECT n, ST_AsEWKT(ST_GeometryN(the_geom, n)) As geomewkt
+SELECT n, ST_AsEWKT(ST_GeometryN(geom, n)) As geomewkt
FROM (
VALUES (ST_GeomFromEWKT('MULTIPOINT(1 2 7, 3 4 7, 5 6 7, 8 9 10)') ),
( ST_GeomFromEWKT('MULTICURVE(CIRCULARSTRING(2.5 2.5,4.5 2.5, 3.5 3.5), (10 11, 12 11))') )
- )As foo(the_geom)
+ )As foo(geom)
CROSS JOIN generate_series(1,100) n
-WHERE n <= ST_NumGeometries(the_geom);
+WHERE n <= ST_NumGeometries(geom);
n | geomewkt
@@ -1260,9 +1260,9 @@ WHERE n <= ST_NumGeometries(the_geom);
--Extracting all geometries (useful when you want to assign an id)
-SELECT gid, n, ST_GeometryN(the_geom, n)
+SELECT gid, n, ST_GeometryN(geom, n)
FROM sometable CROSS JOIN generate_series(1,100) n
-WHERE n <= ST_NumGeometries(the_geom);</programlisting>
+WHERE n <= ST_NumGeometries(geom);</programlisting>
</refsection>
<refsection><title>Polyhedral Surfaces, TIN and Triangle Examples</title>
@@ -1474,10 +1474,10 @@ SELECT ST_AsEWKT(ST_GeometryN(geom,2)) as wkt
<programlisting>
-SELECT ST_AsText(ST_InteriorRingN(the_geom, 1)) As the_geom
+SELECT ST_AsText(ST_InteriorRingN(geom, 1)) As geom
FROM (SELECT ST_BuildArea(
ST_Collect(ST_Buffer(ST_Point(1,2), 20,3),
- ST_Buffer(ST_Point(1, 2), 10,3))) As the_geom
+ ST_Buffer(ST_Point(1, 2), 10,3))) As geom
) as foo;
</programlisting>
</refsection>
@@ -1942,15 +1942,15 @@ SELECT ST_IsEmpty(ST_GeomFromText('POLYGON((1 2, 3 4, 5 6, 1 2))'));
<refsection>
- <programlisting>SELECT ST_IsRing(the_geom), ST_IsClosed(the_geom), ST_IsSimple(the_geom)
-FROM (SELECT 'LINESTRING(0 0, 0 1, 1 1, 1 0, 0 0)'::geometry AS the_geom) AS foo;
+ <programlisting>SELECT ST_IsRing(geom), ST_IsClosed(geom), ST_IsSimple(geom)
+FROM (SELECT 'LINESTRING(0 0, 0 1, 1 1, 1 0, 0 0)'::geometry AS geom) AS foo;
st_isring | st_isclosed | st_issimple
t | t | t
(1 row)
-SELECT ST_IsRing(the_geom), ST_IsClosed(the_geom), ST_IsSimple(the_geom)
-FROM (SELECT 'LINESTRING(0 0, 0 1, 1 0, 1 1, 0 0)'::geometry AS the_geom) AS foo;
+SELECT ST_IsRing(geom), ST_IsClosed(geom), ST_IsSimple(geom)
+FROM (SELECT 'LINESTRING(0 0, 0 1, 1 0, 1 1, 0 0)'::geometry AS geom) AS foo;
f | t | f
@@ -2117,10 +2117,10 @@ FROM (SELECT 'LINESTRING(0 0, 0 1, 1 0, 1 1, 0 0)'::geometry AS the_geom) AS foo
<programlisting>
--Return how much byte space Boston takes up in our Mass data set
-SELECT pg_size_pretty(SUM(ST_MemSize(the_geom))) as totgeomsum,
-pg_size_pretty(SUM(CASE WHEN town = 'BOSTON' THEN ST_MemSize(the_geom) ELSE 0 END)) As bossum,
-CAST(SUM(CASE WHEN town = 'BOSTON' THEN ST_MemSize(the_geom) ELSE 0 END)*1.00 /
- SUM(ST_MemSize(the_geom))*100 As numeric(10,2)) As perbos
+SELECT pg_size_pretty(SUM(ST_MemSize(geom))) as totgeomsum,
+pg_size_pretty(SUM(CASE WHEN town = 'BOSTON' THEN ST_MemSize(geom) ELSE 0 END)) As bossum,
+CAST(SUM(CASE WHEN town = 'BOSTON' THEN ST_MemSize(geom) ELSE 0 END)*1.00 /
+ SUM(ST_MemSize(geom))*100 As numeric(10,2)) As perbos
FROM towns;
totgeomsum bossum perbos
@@ -2134,8 +2134,8 @@ SELECT ST_MemSize(ST_GeomFromText('CIRCULARSTRING(220268 150415,220227 150505,22
73
--What percentage of our table is taken up by just the geometry
-SELECT pg_total_relation_size('public.neighborhoods') As fulltable_size, sum(ST_MemSize(the_geom)) As geomsize,
-sum(ST_MemSize(the_geom))*1.00/pg_total_relation_size('public.neighborhoods')*100 As pergeom
+SELECT pg_total_relation_size('public.neighborhoods') As fulltable_size, sum(ST_MemSize(geom)) As geomsize,
+sum(ST_MemSize(geom))*1.00/pg_total_relation_size('public.neighborhoods')*100 As pergeom
FROM neighborhoods;
fulltable_size geomsize pergeom
@@ -2261,8 +2261,8 @@ SELECT ST_NPoints(ST_GeomFromEWKT('LINESTRING(77.29 29.07 1,77.42 29.26 0,77.27
<refsection>
- <programlisting>SELECT ST_NRings(the_geom) As Nrings, ST_NumInteriorRings(the_geom) As ninterrings
- FROM (SELECT ST_GeomFromText('POLYGON((1 2, 3 4, 5 6, 1 2))') As the_geom) As foo;
+ <programlisting>SELECT ST_NRings(geom) As Nrings, ST_NumInteriorRings(geom) As ninterrings
+ FROM (SELECT ST_GeomFromText('POLYGON((1 2, 3 4, 5 6, 1 2))') As geom) As foo;
nrings | ninterrings
1 | 0
@@ -2365,13 +2365,13 @@ POLYGON((-7 4.2,-7.1 5,-7.1 4.3,-7 4.2)))'));
<programlisting>
--If you have a regular polygon
-SELECT gid, field1, field2, ST_NumInteriorRings(the_geom) AS numholes
+SELECT gid, field1, field2, ST_NumInteriorRings(geom) AS numholes
FROM sometable;
--If you have multipolygons
--And you want to know the total number of interior rings in the MULTIPOLYGON
-SELECT gid, field1, field2, SUM(ST_NumInteriorRings(the_geom)) AS numholes
-FROM (SELECT gid, field1, field2, (ST_Dump(the_geom)).geom As the_geom
+SELECT gid, field1, field2, SUM(ST_NumInteriorRings(geom)) AS numholes
+FROM (SELECT gid, field1, field2, (ST_Dump(geom)).geom As geom
GROUP BY gid, field1,field2;
</programlisting>
diff --git a/doc/reference_bbox.xml b/doc/reference_bbox.xml
index 15055ce..77cab73 100644
--- a/doc/reference_bbox.xml
+++ b/doc/reference_bbox.xml
@@ -183,11 +183,11 @@ instead.
<refsection>
- <programlisting>SELECT ST_EstimatedExtent('ny', 'edges', 'the_geom');
+ <programlisting>SELECT ST_EstimatedExtent('ny', 'edges', 'geom');
--result--
BOX(-8877653 4912316,-8010225.5 5589284)
-SELECT ST_EstimatedExtent('feature_poly', 'the_geom');
+SELECT ST_EstimatedExtent('feature_poly', 'geom');
--result--
BOX(-124.659652709961 24.6830825805664,-67.7798080444336 49.0012092590332)
</programlisting>
@@ -271,7 +271,7 @@ BOX(-124.659652709961 24.6830825805664,-67.7798080444336 49.0012092590332)
<note>
<para>Pre version 1.3, ST_Expand was used in conjunction with <xref linkend="ST_Distance" /> to do indexable distance queries. For example,
- <code>the_geom && ST_Expand('POINT(10 20)', 10) AND ST_Distance(the_geom, 'POINT(10 20)') < 10</code>.
+ <code>geom && ST_Expand('POINT(10 20)', 10) AND ST_Distance(geom, 'POINT(10 20)') < 10</code>.
This has been replaced by the easier <xref linkend="ST_DWithin" /> construct.</para>
</note>
@@ -365,14 +365,14 @@ SELECT ST_Expand(CAST('BOX3D(778783 2951741 1,794875 2970042.61545891 10)' As bo
<note><para>Examples below use Massachusetts State Plane ft (SRID=2249)</para></note>
<programlisting>
-SELECT ST_Extent(the_geom) as bextent FROM sometable;
+SELECT ST_Extent(geom) as bextent FROM sometable;
st_bextent
BOX(739651.875 2908247.25,794875.8125 2970042.75)
--Return extent of each category of geometries
FROM sometable
GROUP BY category ORDER BY category;
@@ -384,7 +384,7 @@ GROUP BY category ORDER BY category;
--Force back into a geometry
-- and render the extended text representation of that geometry
-SELECT ST_SetSRID(ST_Extent(the_geom),2249) as bextent FROM sometable;
+SELECT ST_SetSRID(ST_Extent(geom),2249) as bextent FROM sometable;
bextent
@@ -438,8 +438,8 @@ SELECT ST_SetSRID(ST_Extent(the_geom),2249) as bextent FROM sometable;
<refsection>
<programlisting>
-SELECT ST_3DExtent(foo.the_geom) As b3extent
-FROM (SELECT ST_MakePoint(x,y,z) As the_geom
+SELECT ST_3DExtent(foo.geom) As b3extent
+FROM (SELECT ST_MakePoint(x,y,z) As geom
FROM generate_series(1,3) As x
CROSS JOIN generate_series(1,2) As y
CROSS JOIN generate_series(0,2) As Z) As foo;
@@ -448,8 +448,8 @@ FROM (SELECT ST_MakePoint(x,y,z) As the_geom
BOX3D(1 1 0,3 2 2)
--Get the extent of various elevated circular strings
-FROM (SELECT ST_Translate(ST_Force_3DZ(ST_LineToCurve(ST_Buffer(ST_Point(x,y),1))),0,0,z) As the_geom
+FROM (SELECT ST_Translate(ST_Force_3DZ(ST_LineToCurve(ST_Buffer(ST_Point(x,y),1))),0,0,z) As geom
@@ -497,9 +497,9 @@ FROM (SELECT ST_Translate(ST_Force_3DZ(ST_LineToCurve(ST_Buffer(ST_Point(x,y),1)
<programlisting>
--Return all features that fall reside or partly reside in a US national atlas coordinate bounding box
--It is assumed here that the geometries are stored with SRID = 2163 (US National atlas equal area)
-SELECT feature_id, feature_name, the_geom
+SELECT feature_id, feature_name, geom
FROM features
-WHERE the_geom && ST_SetSRID(ST_MakeBox2D(ST_Point(-989502.1875, 528439.5625),
+WHERE geom && ST_SetSRID(ST_MakeBox2D(ST_Point(-989502.1875, 528439.5625),
ST_Point(-987121.375 ,529933.1875)),2163)</programlisting>
</refsection>
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index e3c926c..3548178 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -96,7 +96,7 @@ MULTICURVE(CIRCULARSTRING(220268 150415,220227 150505,220227 150406),
<title>Examples - Array variant</title>
<para>Using an array constructor for a subquery.</para>
<programlisting>
-SELECT ST_Collect( ARRAY( SELECT the_geom FROM sometable ) );
+SELECT ST_Collect( ARRAY( SELECT geom FROM sometable ) );
</programlisting>
<para>Using an array constructor for values.</para>
<programlisting>
@@ -112,8 +112,8 @@ MULTILINESTRING((1 2,3 4),(3 4,4 5))
<title>Examples - Aggregate variant</title>
<para>Creating multiple collections by grouping geometries in a table.</para>
<programlisting>
-SELECT stusps, ST_Collect(f.the_geom) as geom
- FROM (SELECT stusps, (ST_Dump(the_geom)).geom As the_geom
+SELECT stusps, ST_Collect(f.geom) as geom
+ FROM (SELECT stusps, (ST_Dump(geom)).geom As geom
FROM
somestatetable ) As f
GROUP BY stusps
@@ -309,7 +309,7 @@ SELECT ST_AsEWKT( ST_MakeLine(ST_MakePoint(1,2,3), ST_MakePoint(3,4,5) ));
<para>Create a line from an array formed by a subquery with ordering.</para>
<programlisting>
-SELECT ST_MakeLine( ARRAY( SELECT ST_Centroid(the_geom) FROM visit_locations ORDER BY visit_time) );
+SELECT ST_MakeLine( ARRAY( SELECT ST_Centroid(geom) FROM visit_locations ORDER BY visit_time) );
</programlisting>
<para>Create a 3D line from an array of 3D points</para>
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index 742b81b..bcd5041 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -61,9 +61,9 @@ only for those that are not closed.
</para>
<programlisting>
UPDATE sometable
-SET the_geom = ST_AddPoint(the_geom, ST_StartPoint(the_geom))
+SET geom = ST_AddPoint(geom, ST_StartPoint(geom))
FROM sometable
-WHERE ST_IsClosed(the_geom) = false;
+WHERE ST_IsClosed(geom) = false;
</programlisting>
</refsection>
@@ -1121,8 +1121,8 @@ GEOMETRYCOLLECTION(
<programlisting> -- 2D Example
-SELECT ST_AsText(ST_LineToCurve(foo.the_geom)) As curvedastext,ST_AsText(foo.the_geom) As non_curvedastext
- FROM (SELECT ST_Buffer('POINT(1 3)'::geometry, 3) As the_geom) As foo;
+SELECT ST_AsText(ST_LineToCurve(foo.geom)) As curvedastext,ST_AsText(foo.geom) As non_curvedastext
+ FROM (SELECT ST_Buffer('POINT(1 3)'::geometry, 3) As geom) As foo;
curvedatext non_curvedastext
@@ -1545,10 +1545,10 @@ UPDATE sometable
<refsection>
<programlisting>
-SELECT ST_AsText(the_geom) as line, ST_AsText(ST_Reverse(the_geom)) As reverseline
+SELECT ST_AsText(geom) as line, ST_AsText(ST_Reverse(geom)) As reverseline
FROM
(SELECT ST_MakeLine(ST_Point(1,2),
- ST_Point(1,10)) As the_geom) as foo;
+ ST_Point(1,10)) As geom) as foo;
--result
line | reverseline
@@ -1662,8 +1662,8 @@ SELECT ST_AsText(ST_SetPoint('LINESTRING(-1 2,-1 3)', 0, 'POINT(-1 1)'));
LINESTRING(-1 1,-1 3)
---Change last point in a line string (lets play with 3d linestring this time)
-SELECT ST_AsEWKT(ST_SetPoint(foo.the_geom, ST_NumPoints(foo.the_geom) - 1, ST_GeomFromEWKT('POINT(-1 1 3)')))
-FROM (SELECT ST_GeomFromEWKT('LINESTRING(-1 2 3,-1 3 4, 5 6 7)') As the_geom) As foo;
+SELECT ST_AsEWKT(ST_SetPoint(foo.geom, ST_NumPoints(foo.geom) - 1, ST_GeomFromEWKT('POINT(-1 1 3)')))
+FROM (SELECT ST_GeomFromEWKT('LINESTRING(-1 2 3,-1 3 4, 5 6 7)') As geom) As foo;
st_asewkt
LINESTRING(-1 2 3,-1 3 4,-1 1 3)
@@ -1796,11 +1796,11 @@ of interest not spawned from one side to the other.
<programlisting>
-- Move all components of the given geometries whose bounding box
-- falls completely on the left of x=0 to +360
-select ST_WrapX(the_geom, 0, 360);
+select ST_WrapX(geom, 0, 360);
-- falls completely on the left of x=-30 to +360
-select ST_WrapX(the_geom, -30, 360);
+select ST_WrapX(geom, -30, 360);
</programlisting>
</refsection>
@@ -1898,7 +1898,7 @@ select ST_WrapX(the_geom, -30, 360);
<programlisting>
--Snap your geometries to a precision grid of 10^-3
UPDATE mytable
- SET the_geom = ST_SnapToGrid(the_geom, 0.001);
+ SET geom = ST_SnapToGrid(geom, 0.001);
SELECT ST_AsText(ST_SnapToGrid(
ST_GeomFromText('LINESTRING(1.1115678 2.123, 4.111111 3.2374897, 4.11112 3.23748667)'),
diff --git a/doc/reference_exception.xml b/doc/reference_exception.xml
index 8021447..9dce6f5 100644
--- a/doc/reference_exception.xml
+++ b/doc/reference_exception.xml
@@ -40,8 +40,8 @@
<programlisting>UPDATE sometable
- SET the_geom = PostGIS_AddBBox(the_geom)
- WHERE PostGIS_HasBBox(the_geom) = false;</programlisting>
+ SET geom = PostGIS_AddBBox(geom)
+ WHERE PostGIS_HasBBox(geom) = false;</programlisting>
</refsection>
<!-- Optionally add a "See Also" section -->
@@ -93,12 +93,12 @@
--The force to ST_AsBinary before applying Box2D forces a recalculation of the box, and Box2D applied to the table geometry always
-- returns the cached bounding box.
UPDATE sometable
- SET the_geom = PostGIS_DropBBox(the_geom)
- WHERE Not (Box2D(ST_AsBinary(the_geom)) = Box2D(the_geom));
+ SET geom = PostGIS_DropBBox(geom)
+ WHERE Not (Box2D(ST_AsBinary(geom)) = Box2D(geom));
UPDATE sometable
- WHERE Not PostGIS_HasBBOX(the_geom);
+ WHERE Not PostGIS_HasBBOX(geom);
</programlisting>
@@ -142,8 +142,8 @@
<refsection>
- <programlisting>SELECT the_geom
-FROM sometable WHERE PostGIS_HasBBox(the_geom) = false;</programlisting>
+ <programlisting>SELECT geom
+FROM sometable WHERE PostGIS_HasBBox(geom) = false;</programlisting>
</refsection>
diff --git a/doc/reference_management.xml b/doc/reference_management.xml
index 412863d..88037aa 100644
--- a/doc/reference_management.xml
+++ b/doc/reference_management.xml
@@ -379,7 +379,7 @@ DROP TABLE my_schema.my_spatial_table;
<refsection>
- <programlisting> SELECT Find_SRID('public', 'tiger_us_state_2007', 'the_geom_4269');
+ <programlisting> SELECT Find_SRID('public', 'tiger_us_state_2007', 'geom_4269');
find_srid
4269
@@ -435,19 +435,19 @@ find_srid
<itemizedlist>
<listitem>
- <para><varname>enforce_dims_the_geom</varname> - ensures every
+ <para><varname>enforce_dims_geom</varname> - ensures every
geometry has the same dimension (see <xref
linkend="ST_NDims" />)</para>
</listitem>
<listitem>
- <para><varname>enforce_geotype_the_geom</varname> - ensures every
+ <para><varname>enforce_geotype_geom</varname> - ensures every
geometry is of the same type (see <xref
linkend="GeometryType" />)</para>
</listitem>
<listitem>
- <para><varname>enforce_srid_the_geom</varname> - ensures every
+ <para><varname>enforce_srid_geom</varname> - ensures every
geometry is in the same projection (see <xref
linkend="ST_SRID" />)</para>
</listitem>
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index abf7125..48f175e 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -712,14 +712,14 @@ SELECT ST_3DDistance(poly, mline) As dist3d,
<refsection>
- <programlisting>SELECT round(CAST(ST_DistanceSphere(ST_Centroid(the_geom), ST_GeomFromText('POINT(-118 38)',4326)) As numeric),2) As dist_meters,
-round(CAST(ST_Distance(ST_Transform(ST_Centroid(the_geom),32611),
+ <programlisting>SELECT round(CAST(ST_DistanceSphere(ST_Centroid(geom), ST_GeomFromText('POINT(-118 38)',4326)) As numeric),2) As dist_meters,
+round(CAST(ST_Distance(ST_Transform(ST_Centroid(geom),32611),
ST_Transform(ST_GeomFromText('POINT(-118 38)', 4326),32611)) As numeric),2) As dist_utm11_meters,
-round(CAST(ST_Distance(ST_Centroid(the_geom), ST_GeomFromText('POINT(-118 38)', 4326)) As numeric),5) As dist_degrees,
-round(CAST(ST_Distance(ST_Transform(the_geom,32611),
+round(CAST(ST_Distance(ST_Centroid(geom), ST_GeomFromText('POINT(-118 38)', 4326)) As numeric),5) As dist_degrees,
+round(CAST(ST_Distance(ST_Transform(geom,32611),
ST_Transform(ST_GeomFromText('POINT(-118 38)', 4326),32611)) As numeric),2) As min_dist_line_point_meters
FROM
- (SELECT ST_GeomFromText('LINESTRING(-118.584 38.374,-118.583 38.5)', 4326) As the_geom) as foo;
+ (SELECT ST_GeomFromText('LINESTRING(-118.584 38.374,-118.583 38.5)', 4326) As geom) as foo;
dist_meters | dist_utm11_meters | dist_degrees | min_dist_line_point_meters
70424.47 | 70438.00 | 0.72900 | 65871.18
@@ -775,13 +775,13 @@ FROM
- ST_DistanceSpheroid(ST_Centroid(the_geom), ST_GeomFromText('POINT(-118 38)',4326), 'SPHEROID["WGS 84",6378137,298.257223563]')
+ ST_DistanceSpheroid(ST_Centroid(geom), ST_GeomFromText('POINT(-118 38)',4326), 'SPHEROID["WGS 84",6378137,298.257223563]')
As numeric),2) As dist_meters_spheroid,
- round(CAST(ST_DistanceSphere(ST_Centroid(the_geom), ST_GeomFromText('POINT(-118 38)',4326)) As numeric),2) As dist_meters_sphere,
+ round(CAST(ST_DistanceSphere(ST_Centroid(geom), ST_GeomFromText('POINT(-118 38)',4326)) As numeric),2) As dist_meters_sphere,
FROM
dist_meters_spheroid | dist_meters_sphere | dist_utm11_meters
70454.92 | 70424.47 | 70438.00
@@ -1175,22 +1175,22 @@ ST_3DLength
'SPHEROID["GRS_1980",6378137,298.257222101]' )
FROM geometry_table;
-SELECT ST_LengthSpheroid( the_geom, sph_m ) As tot_len,
-ST_LengthSpheroid(ST_GeometryN(the_geom,1), sph_m) As len_line1,
-ST_LengthSpheroid(ST_GeometryN(the_geom,2), sph_m) As len_line2
+SELECT ST_LengthSpheroid( geom, sph_m ) As tot_len,
+ST_LengthSpheroid(ST_GeometryN(geom,1), sph_m) As len_line1,
+ST_LengthSpheroid(ST_GeometryN(geom,2), sph_m) As len_line2
FROM (SELECT ST_GeomFromText('MULTILINESTRING((-118.584 38.374,-118.583 38.5),
- (-71.05957 42.3589 , -71.061 43))') As the_geom,
+ (-71.05957 42.3589 , -71.061 43))') As geom,
CAST('SPHEROID["GRS_1980",6378137,298.257222101]' As spheroid) As sph_m) as foo;
tot_len | len_line1 | len_line2
85204.5207562955 | 13986.8725229309 | 71217.6482333646
--3D
FROM (SELECT ST_GeomFromEWKT('MULTILINESTRING((-118.584 38.374 20,-118.583 38.5 30),
- (-71.05957 42.3589 75, -71.061 43 90))') As the_geom,
+ (-71.05957 42.3589 75, -71.061 43 90))') As geom,
@@ -1870,9 +1870,9 @@ FROM ST_GeogFromText('MULTIPOLYGON(((-71.1044543107478 42.340674480411,-71.10445
<refsection>
<para>Perimeter of a slightly elevated polygon in the air in Massachusetts state plane feet</para>
- <programlisting>SELECT ST_3DPerimeter(the_geom), ST_Perimeter2d(the_geom), ST_Perimeter(the_geom) FROM
+ <programlisting>SELECT ST_3DPerimeter(geom), ST_Perimeter2d(geom), ST_Perimeter(geom) FROM
(SELECT ST_GeomFromEWKT('SRID=2249;POLYGON((743238 2967416 2,743238 2967450 1,
-743265.625 2967416 1,743238 2967416 2))') As the_geom) As foo;
+743265.625 2967416 1,743238 2967416 2))') As geom) As foo;
ST_3DPerimeter | st_perimeter2d | st_perimeter
diff --git a/doc/reference_overlay.xml b/doc/reference_overlay.xml
index f535d13..85f4b2d 100644
--- a/doc/reference_overlay.xml
+++ b/doc/reference_overlay.xml
@@ -47,7 +47,7 @@
<programlisting>
-- Rely on implicit cast from geometry to box2d for the second parameter
-SELECT ST_ClipByBox2D(the_geom, ST_MakeEnvelope(0,0,10,10)) FROM mytab;
+SELECT ST_ClipByBox2D(geom, ST_MakeEnvelope(0,0,10,10)) FROM mytab;
</programlisting>
</refsection>
<refsection>
@@ -1045,7 +1045,7 @@ st_asewkt
GEOMETRYCOLLECTION(POINT(-2 3 1),LINESTRING(5 5 5,10 10 10),POLYGON((-7 4.2 2,-7.1 4.2 3,-7.1 4.3 2,-7 4.2 2)))
--Examples using new Array construct
-SELECT ST_Union(ARRAY(SELECT the_geom FROM sometable));
+SELECT ST_Union(ARRAY(SELECT geom FROM sometable));
SELECT ST_AsText(ST_Union(ARRAY[ST_GeomFromText('LINESTRING(1 2, 3 4)'),
ST_GeomFromText('LINESTRING(3 4, 4 5)')])) As wktunion;
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 1a0ab6b..ab5eb59 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -890,7 +890,7 @@ POLYGON((50 5,10 8,10 10,100 190,150 30,150 10,50 5))
<programlisting>
--Get estimate of infected area based on point observations
SELECT d.disease_type,
- ST_ConvexHull(ST_Collect(d.the_geom)) As the_geom
+ ST_ConvexHull(ST_Collect(d.geom)) As geom
FROM disease_obs As d
GROUP BY d.disease_type;
</programlisting>
@@ -1458,7 +1458,7 @@ LINESTRING Z (-30 -29.7 5,-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 1,-46 -32 11
<refsection>
<programlisting>SELECT d.disease_type,
- ST_MinimumBoundingCircle(ST_Collect(d.the_geom)) As the_geom
+ ST_MinimumBoundingCircle(ST_Collect(d.geom)) As geom
</programlisting>
@@ -1672,8 +1672,8 @@ It always gives a 2D result even when used on a 3D geometry.</para></note>
<para>Compute an open buffer around roads</para>
<programlisting>
SELECT ST_Union(
- ST_OffsetCurve(f.the_geom, f.width/2, 'quad_segs=4 join=round'),
- ST_OffsetCurve(f.the_geom, -f.width/2, 'quad_segs=4 join=round')
+ ST_OffsetCurve(f.geom, f.width/2, 'quad_segs=4 join=round'),
+ ST_OffsetCurve(f.geom, -f.width/2, 'quad_segs=4 join=round')
) as track
FROM someroadstable;
@@ -1950,8 +1950,8 @@ SELECT ST_AsEWKT(ST_PointOnSurface(ST_GeomFromEWKT('LINESTRING(0 5 1, 0 0 1, 0 1
<refsection>
<title>Examples: Polygonizing single linestrings</title>
<programlisting>
-SELECT ST_AsEWKT(ST_Polygonize(the_geom_4269)) As geomtextrep
-FROM (SELECT the_geom_4269 FROM ma.suffolk_edges ORDER BY tlid LIMIT 45) As foo;
+SELECT ST_AsEWKT(ST_Polygonize(geom_4269)) As geomtextrep
+FROM (SELECT geom_4269 FROM ma.suffolk_edges ORDER BY tlid LIMIT 45) As foo;
geomtextrep
@@ -1962,8 +1962,8 @@ geomtextrep
--Use ST_Dump to dump out the polygonize geoms into individual polygons
SELECT ST_AsEWKT((ST_Dump(foofoo.polycoll)).geom) As geomtextrep
-FROM (SELECT ST_Polygonize(the_geom_4269) As polycoll
- FROM (SELECT the_geom_4269 FROM ma.suffolk_edges
+FROM (SELECT ST_Polygonize(geom_4269) As polycoll
+ FROM (SELECT geom_4269 FROM ma.suffolk_edges
ORDER BY tlid LIMIT 45) As foo) As foofoo;
geomtextrep
@@ -2222,14 +2222,14 @@ MULTILINESTRING((76 175,90 161),(90 161,101 150),(126 125,126 156.25)))
<refsection>
<para>A circle simplified too much becomes a triangle, medium an octagon, </para>
- <programlisting>SELECT ST_Npoints(the_geom) AS np_before,
- ST_NPoints(ST_Simplify(the_geom,0.1)) AS np01_notbadcircle,
- ST_NPoints(ST_Simplify(the_geom,0.5)) AS np05_notquitecircle,
- ST_NPoints(ST_Simplify(the_geom,1)) AS np1_octagon,
- ST_NPoints(ST_Simplify(the_geom,10)) AS np10_triangle,
- (ST_Simplify(the_geom,100) is null) AS np100_geometrygoesaway
+ <programlisting>SELECT ST_Npoints(geom) AS np_before,
+ ST_NPoints(ST_Simplify(geom,0.1)) AS np01_notbadcircle,
+ ST_NPoints(ST_Simplify(geom,0.5)) AS np05_notquitecircle,
+ ST_NPoints(ST_Simplify(geom,1)) AS np1_octagon,
+ ST_NPoints(ST_Simplify(geom,10)) AS np10_triangle,
+ (ST_Simplify(geom,100) is null) AS np100_geometrygoesaway
FROM
- (SELECT ST_Buffer('POINT(1 3)', 10,12) As the_geom) AS foo;
+ (SELECT ST_Buffer('POINT(1 3)', 10,12) As geom) AS foo;
np_before | np01_notbadcircle | np05_notquitecircle | np1_octagon | np10_triangle | np100_geometrygoesaway
@@ -2277,10 +2277,10 @@ MULTILINESTRING((76 175,90 161),(90 161,101 150),(126 125,126 156.25)))
<para>Same example as Simplify, but we see Preserve Topology prevents oversimplification. The circle can at most become a square.</para>
<programlisting>
-SELECT ST_Npoints(the_geom) As np_before, ST_NPoints(ST_SimplifyPreserveTopology(the_geom,0.1)) As np01_notbadcircle, ST_NPoints(ST_SimplifyPreserveTopology(the_geom,0.5)) As np05_notquitecircle,
-ST_NPoints(ST_SimplifyPreserveTopology(the_geom,1)) As np1_octagon, ST_NPoints(ST_SimplifyPreserveTopology(the_geom,10)) As np10_square,
-ST_NPoints(ST_SimplifyPreserveTopology(the_geom,100)) As np100_stillsquare
-FROM (SELECT ST_Buffer('POINT(1 3)', 10,12) As the_geom) As foo;
+SELECT ST_Npoints(geom) As np_before, ST_NPoints(ST_SimplifyPreserveTopology(geom,0.1)) As np01_notbadcircle, ST_NPoints(ST_SimplifyPreserveTopology(geom,0.5)) As np05_notquitecircle,
+ST_NPoints(ST_SimplifyPreserveTopology(geom,1)) As np1_octagon, ST_NPoints(ST_SimplifyPreserveTopology(geom,10)) As np10_square,
+ST_NPoints(ST_SimplifyPreserveTopology(geom,100)) As np100_stillsquare
+FROM (SELECT ST_Buffer('POINT(1 3)', 10,12) As geom) As foo;
--result--
np_before | np01_notbadcircle | np05_notquitecircle | np1_octagon | np10_square | np100_stillsquare
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index d536e15..3556ead 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -11477,7 +11477,7 @@ WITH pr AS
(SELECT ST_Clip(rast,ST_Expand(geom,50) ) As rast, g.geom
FROM aerials.o_2_boston AS r INNER JOIN
-- union our parcels of interest so they form a single geometry we can later intersect with
- (SELECT ST_Union(ST_Transform(the_geom,26986)) AS geom
+ (SELECT ST_Union(ST_Transform(geom,26986)) AS geom
FROM landparcels WHERE pid IN('0303890000', '0303900000')) As g
ON ST_Intersects(rast::geometry, ST_Expand(g.geom,50))
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index 9716178..efef1ed 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -676,7 +676,7 @@ SELECT ST_Covers(geog_poly, geog_pt) As poly_covers_pt,
<entry><para> <informalexample>
<programlisting>CREATE TABLE roads (
id serial NOT NULL,
- the_geom geometry,
+ geom geometry,
CONSTRAINT roads_pkey PRIMARY KEY (road_id)
);</programlisting>
</informalexample> </para></entry>
@@ -699,7 +699,7 @@ SELECT ST_Covers(geog_poly, geog_pt) As poly_covers_pt,
<para><informalexample>
<programlisting>SELECT roads.id
FROM roads, highways
-WHERE ST_Crosses(roads.the_geom, highways.the_geom);</programlisting>
+WHERE ST_Crosses(roads.geom, highways.geom);</programlisting>
</informalexample></para>
</refsection>
</refentry>
@@ -875,9 +875,9 @@ FROM (SELECT
</informaltable>
<programlisting>
-SELECT s1.gid, s2.gid, ST_LineCrossingDirection(s1.the_geom, s2.the_geom)
- FROM streets s1 CROSS JOIN streets s2 ON (s1.gid != s2.gid AND s1.the_geom && s2.the_geom )
-WHERE ST_CrossingDirection(s1.the_geom, s2.the_geom) > 0;
+SELECT s1.gid, s2.gid, ST_LineCrossingDirection(s1.geom, s2.geom)
+ FROM streets s1 CROSS JOIN streets s2 ON (s1.gid != s2.gid AND s1.geom && s2.geom )
+WHERE ST_CrossingDirection(s1.geom, s2.geom) > 0;
</programlisting>
</refsection>
@@ -2110,7 +2110,7 @@ ST_DWithin(
-- If the units of the spatial reference is meters then units would be meters
SELECT DISTINCT ON (s.gid) s.gid, s.school_name, s.geom, h.hospital_name
FROM schools s
- LEFT JOIN hospitals h ON ST_DWithin(s.the_geom, h.geom, 3000)
+ LEFT JOIN hospitals h ON ST_DWithin(s.geom, h.geom, 3000)
ORDER BY s.gid, ST_Distance(s.geom, h.geom);
-- The schools with no close hospitals
diff --git a/doc/reference_srs.xml b/doc/reference_srs.xml
index 51f2035..15122ed 100644
--- a/doc/reference_srs.xml
+++ b/doc/reference_srs.xml
@@ -217,11 +217,11 @@ SELECT ST_AsEWKT(ST_Transform(ST_GeomFromEWKT('SRID=2249;CIRCULARSTRING(743238 2
<para>Example of creating a partial functional index. For tables where you are not sure all the geometries
will be filled in, its best to use a partial index that leaves out null geometries which will both conserve space and make your index smaller and more efficient.</para>
<programlisting>
-CREATE INDEX idx_the_geom_26986_parcels
+CREATE INDEX idx_geom_26986_parcels
ON parcels
USING gist
- (ST_Transform(the_geom, 26986))
- WHERE the_geom IS NOT NULL;
+ (ST_Transform(geom, 26986))
+ WHERE geom IS NOT NULL;
</programlisting>
<para>Examples of using PROJ.4 text to transform with custom spatial references.</para>
diff --git a/doc/reference_transaction.xml b/doc/reference_transaction.xml
index c5f1d50..36a0668 100644
--- a/doc/reference_transaction.xml
+++ b/doc/reference_transaction.xml
@@ -53,7 +53,7 @@
SELECT LockRow('towns', '353', 'priscilla');
BEGIN TRANSACTION;
SELECT AddAuth('joey');
- UPDATE towns SET the_geom = ST_Translate(the_geom,2,2) WHERE gid = 353;
+ UPDATE towns SET geom = ST_Translate(geom,2,2) WHERE gid = 353;
COMMIT;
diff --git a/doc/reference_transformation.xml b/doc/reference_transformation.xml
index 887eb2f..9034c9d 100644
--- a/doc/reference_transformation.xml
+++ b/doc/reference_transformation.xml
@@ -91,17 +91,17 @@ z' = z </programlisting> This method is a subcase of the 3D method
<programlisting>
--Rotate a 3d line 180 degrees about the z axis. Note this is long-hand for doing ST_Rotate();
- SELECT ST_AsEWKT(ST_Affine(the_geom, cos(pi()), -sin(pi()), 0, sin(pi()), cos(pi()), 0, 0, 0, 1, 0, 0, 0)) As using_affine,
- ST_AsEWKT(ST_Rotate(the_geom, pi())) As using_rotate
- FROM (SELECT ST_GeomFromEWKT('LINESTRING(1 2 3, 1 4 3)') As the_geom) As foo;
+ SELECT ST_AsEWKT(ST_Affine(geom, cos(pi()), -sin(pi()), 0, sin(pi()), cos(pi()), 0, 0, 0, 1, 0, 0, 0)) As using_affine,
+ ST_AsEWKT(ST_Rotate(geom, pi())) As using_rotate
+ FROM (SELECT ST_GeomFromEWKT('LINESTRING(1 2 3, 1 4 3)') As geom) As foo;
using_affine | using_rotate
LINESTRING(-1 -2 3,-1 -4 3) | LINESTRING(-1 -2 3,-1 -4 3)
(1 row)
--Rotate a 3d line 180 degrees in both the x and z axis
-SELECT ST_AsEWKT(ST_Affine(the_geom, cos(pi()), -sin(pi()), 0, sin(pi()), cos(pi()), -sin(pi()), 0, sin(pi()), cos(pi()), 0, 0, 0))
+SELECT ST_AsEWKT(ST_Affine(geom, cos(pi()), -sin(pi()), 0, sin(pi()), cos(pi()), -sin(pi()), 0, sin(pi()), cos(pi()), 0, 0, 0))
st_asewkt
LINESTRING(-1 -2 -3,-1 -4 -3)
@@ -361,8 +361,8 @@ SELECT ST_AsEWKT(ST_RotateZ(ST_GeomFromEWKT('LINESTRING(1 2 3, 1 1 1)'), pi()/2)
LINESTRING(-2 1 3,-1 1 1)
--Rotate a curved circle around z-axis
-SELECT ST_AsEWKT(ST_RotateZ(the_geom, pi()/2))
-FROM (SELECT ST_LineToCurve(ST_Buffer(ST_GeomFromText('POINT(234 567)'), 3)) As the_geom) As foo;
+SELECT ST_AsEWKT(ST_RotateZ(geom, pi()/2))
+FROM (SELECT ST_LineToCurve(ST_Buffer(ST_GeomFromText('POINT(234 567)'), 3)) As geom) As foo;
st_asewkt
diff --git a/doc/reference_troubleshooting.xml b/doc/reference_troubleshooting.xml
index 607a9a8..5e1f0f5 100644
--- a/doc/reference_troubleshooting.xml
+++ b/doc/reference_troubleshooting.xml
@@ -45,8 +45,8 @@
</refsection>
@@ -98,12 +98,12 @@
UPDATE sometable
UPDATE sometable
</programlisting>
@@ -147,8 +147,8 @@
<refsection>
</refsection>
diff --git a/doc/reference_validation.xml b/doc/reference_validation.xml
index 7cf7db0..66862f4 100644
--- a/doc/reference_validation.xml
+++ b/doc/reference_validation.xml
@@ -155,9 +155,9 @@ The optional <varname>flags</varname> parameter is a bitfield. It can have the f
<programlisting>
--First 3 Rejects from a successful quintuplet experiment
-SELECT gid, reason(ST_IsValidDetail(the_geom)), ST_AsText(location(ST_IsValidDetail(the_geom))) as location
+SELECT gid, reason(ST_IsValidDetail(geom)), ST_AsText(location(ST_IsValidDetail(geom))) as location
FROM
-(SELECT ST_MakePolygon(ST_ExteriorRing(e.buff), array_agg(f.line)) As the_geom, gid
+(SELECT ST_MakePolygon(ST_ExteriorRing(e.buff), array_agg(f.line)) As geom, gid
FROM (SELECT ST_Buffer(ST_Point(x1*10,y1), z1) As buff, x1*10 + y1*100 + z1*1000 As gid
FROM generate_series(-4,6) x1
CROSS JOIN generate_series(2,5) y1
@@ -170,7 +170,7 @@ FROM (SELECT ST_Buffer(ST_Point(x1*10,y1), z1) As buff, x1*10 + y1*100 + z1*1000
WHERE x1 > y1*0.75 AND z1 < x1*y1) As f
ON (ST_Area(e.buff) > 78 AND ST_Contains(e.buff, f.line))
GROUP BY gid, e.buff) As quintuplet_experiment
-WHERE ST_IsValid(the_geom) = false
+WHERE ST_IsValid(geom) = false
ORDER BY gid
LIMIT 3;
@@ -250,9 +250,9 @@ Self-intersection[150 150]
</programlisting>
<programlisting>
-SELECT gid, ST_IsValidReason(the_geom) as validity_info
+SELECT gid, ST_IsValidReason(geom) as validity_info
FROM
@@ -265,7 +265,7 @@ FROM (SELECT ST_Buffer(ST_Point(x1*10,y1), z1) As buff, x1*10 + y1*100 + z1*1000
ORDER BY gid
LIMIT 3;
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index 00345b8..ef885cf 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -1487,7 +1487,7 @@ gisdb=# SELECT
<programlisting>ALTER TABLE mytable
ADD CONSTRAINT geometry_valid_check
- CHECK (ST_IsValid(the_geom));</programlisting>
+ CHECK (ST_IsValid(geom));</programlisting>
<para>If you encounter any strange error messages such as "GEOS
Intersection() threw an error!" when calling PostGIS functions with valid
Summary of changes:
doc/administration.xml | 2 +-
doc/extras.xml | 2 +-
doc/extras_address_standardizer.xml | 2 +-
doc/extras_historytable.xml | 2 +-
doc/extras_tigergeocoder.xml | 4 +--
doc/extras_topology.xml | 2 +-
doc/faq.xml | 12 ++++----
doc/faq_raster.xml | 2 +-
doc/performance_tips.xml | 10 +++----
doc/reference_accessor.xml | 58 ++++++++++++++++++-------------------
doc/reference_bbox.xml | 24 +++++++--------
doc/reference_constructor.xml | 8 ++---
doc/reference_editor.xml | 22 +++++++-------
doc/reference_exception.xml | 16 +++++-----
doc/reference_management.xml | 8 ++---
doc/reference_measure.xml | 38 ++++++++++++------------
doc/reference_overlay.xml | 4 +--
doc/reference_processing.xml | 38 ++++++++++++------------
doc/reference_raster.xml | 2 +-
doc/reference_relationship.xml | 12 ++++----
doc/reference_srs.xml | 6 ++--
doc/reference_transaction.xml | 2 +-
doc/reference_transformation.xml | 14 ++++-----
doc/reference_troubleshooting.xml | 16 +++++-----
doc/reference_validation.xml | 12 ++++----
doc/using_postgis_dataman.xml | 2 +-
26 files changed, 160 insertions(+), 160 deletions(-)
hooks/post-receive
