[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-449-g24d601b
Sat Aug 28 14:15:50 PDT 2021
the project "PostGIS".
       via  24d601b4bcf019a2ccb8e65c37a36b6be7fe5b85 (commit)
      from  a5847a3117e6e6631487db7afb6410cf92f3487b (commit)
revisions in full, below.
commit 24d601b4bcf019a2ccb8e65c37a36b6be7fe5b85
Author: Bruce Rindahl <bruce.rindahl at gmail.com>
Date:   Sat Aug 28 17:13:32 2021 -0400
    Update installation.xml
    Remove most of the make check output and just leave in the summaries.
    Closes https://github.com/postgis/postgis/pull/631
diff --git a/doc/installation.xml b/doc/installation.xml
index b2e0c06..7a469ae 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -759,8 +759,8 @@ CREATE EXTENSION postgis_tiger_geocoder FROM unpackaged;
 	  </caution>
 	  <para>
-		If successful, the output of the test should be similar to the
-		following:
+		If successful, make check will produce the output of almost 500 tests.  The results will look similar to the
+		following (numerous lines omitted below):
 	  </para>
 	  <programlisting>
@@ -768,365 +768,9 @@ CREATE EXTENSION postgis_tiger_geocoder FROM unpackaged;
      CUnit - A unit testing framework for C - Version 2.1-3
      http://cunit.sourceforge.net/
-Suite: algorithm
-  Test: test_lw_segment_side ...passed
-  Test: test_lw_segment_intersects ...passed
-  Test: test_lwline_crossing_short_lines ...passed
-  Test: test_lwline_crossing_long_lines ...passed
-  Test: test_lwline_crossing_bugs ...passed
-  Test: test_lwpoint_set_ordinate ...passed
-  Test: test_lwpoint_get_ordinate ...passed
-  Test: test_point_interpolate ...passed
-  Test: test_lwline_interpolate_points ...passed
-  Test: test_lwline_interpolate_point_3d ...passed
-  Test: test_lwline_clip ...passed
-  Test: test_lwpoly_clip ...passed
-  Test: test_lwtriangle_clip ...passed
-  Test: test_lwline_clip_big ...passed
-  Test: test_lwmline_clip ...passed
-  Test: test_geohash_point ...passed
-  Test: test_geohash_precision ...passed
-  Test: test_geohash ...passed
-  Test: test_geohash_point_as_int ...passed
-  Test: test_isclosed ...passed
-  Test: test_lwgeom_simplify ...passed
-  Test: test_lw_arc_center ...passed
-  Test: test_point_density ...passed
-  Test: test_kmeans ...passed
-  Test: test_median_handles_3d_correctly ...passed
-  Test: test_median_robustness ...passed
-  Test: test_lwpoly_construct_circle ...passed
-  Test: test_trim_bits ...passed
-  Test: test_lwgeom_remove_repeated_points ...passed
-Suite: buildarea
-  Test: buildarea1 ...passed
-  Test: buildarea2 ...passed
-  Test: buildarea3 ...passed
-  Test: buildarea4 ...passed
-  Test: buildarea4b ...passed
-  Test: buildarea5 ...passed
-  Test: buildarea6 ...passed
-  Test: buildarea7 ...passed
-Suite: geometry_clean
-  Test: test_lwgeom_make_valid ...passed
-Suite: clip_by_rectangle
-  Test: test_lwgeom_clip_by_rect ...DEBUG1: lwgeom_clip_by_rect: GEOS Error: IllegalArgumentException: Invalid number of points in LinearRing found 3 - must be 0 or >= 4
-passed
-Suite: force_sfs
-  Test: test_sfs_11 ...passed
-  Test: test_sfs_12 ...passed
-  Test: test_sqlmm ...passed
-Suite: geodetic
-  Test: test_sphere_direction ...passed
-  Test: test_sphere_project ...passed
-  Test: test_lwgeom_area_sphere ...passed
-  Test: test_gbox_from_spherical_coordinates ...passed
-  Test: test_gserialized_get_gbox_geocentric ...passed
-  Test: test_clairaut ...passed
-  Test: test_edge_intersection ...passed
-  Test: test_edge_intersects ...passed
-  Test: test_edge_distance_to_point ...passed
-  Test: test_edge_distance_to_edge ...passed
-  Test: test_lwgeom_distance_sphere ...passed
-  Test: test_lwgeom_check_geodetic ...passed
-  Test: test_gserialized_from_lwgeom ...passed
-  Test: test_spheroid_distance ...passed
-  Test: test_spheroid_area ...passed
-  Test: test_lwpoly_covers_point2d ...passed
-  Test: test_gbox_utils ...passed
-  Test: test_vector_angle ...passed
-  Test: test_vector_rotate ...passed
-  Test: test_lwgeom_segmentize_sphere ...passed
-  Test: test_ptarray_contains_point_sphere ...passed
-  Test: test_ptarray_contains_point_sphere_iowa ...passed
-  Test: test_gbox_to_string_truncated ...passed
-Suite: geos
-  Test: test_geos_noop ...passed
-  Test: test_geos_subdivide ...passed
-  Test: test_geos_linemerge ...passed
-  Test: test_geos_offsetcurve ...passed
-  Test: test_geos_offsetcurve_crash ...passed
-  Test: test_geos_makevalid ...passed
-Suite: clustering
-  Test: basic_test ...passed
-  Test: nonsequential_test ...passed
-  Test: basic_distance_test ...passed
-  Test: single_input_test ...passed
-  Test: empty_inputs_test ...passed
-  Test: multipoint_test ...passed
-  Test: dbscan_test ...passed
-  Test: dbscan_test_3612a ...passed
-  Test: dbscan_test_3612b ...passed
-  Test: dbscan_test_3612c ...passed
-Suite: clustering_unionfind
-  Test: test_unionfind_create ...passed
-  Test: test_unionfind_union ...passed
-  Test: test_unionfind_ordered_by_cluster ...passed
-  Test: test_unionfind_path_compression ...passed
-  Test: test_unionfind_collapse_cluster_ids ...passed
-Suite: homogenize
-  Test: test_coll_point ...passed
-  Test: test_coll_line ...passed
-  Test: test_coll_poly ...passed
-  Test: test_coll_coll ...passed
-  Test: test_geom ...passed
-  Test: test_coll_curve ...passed
-Suite: encoded_polyline_input
-  Test: in_encoded_polyline_test_geoms ...passed
-  Test: in_encoded_polyline_test_precision ...passed
-Suite: geojson_input
-  Test: in_geojson_test_srid ...passed
-  Test: in_geojson_test_bbox ...passed
-  Test: in_geojson_test_geoms ...passed
-Suite: iterator
-  Test: test_point_count ...passed
-  Test: test_ordering ...passed
-  Test: test_modification ...passed
-  Test: test_mixed_rw_access ...passed
-  Test: test_cannot_modify_read_only ...passed
-  Test: test_no_memory_leaked_when_iterator_is_partially_used ...passed
-Suite: twkb_input
-  Test: test_twkb_in_point ...passed
-  Test: test_twkb_in_linestring ...passed
-  Test: test_twkb_in_polygon ...passed
-  Test: test_twkb_in_multipoint ...passed
-  Test: test_twkb_in_multilinestring ...passed
-  Test: test_twkb_in_multipolygon ...passed
-  Test: test_twkb_in_collection ...passed
-  Test: test_twkb_in_precision ...passed
-Suite: serialization/deserialization
-  Test: test_typmod_macros ...passed
-  Test: test_flags_macros ...passed
-  Test: test_serialized_srid ...NOTICE: SRID value -3005 converted to the officially unknown SRID value 0
-passed
-  Test: test_gserialized_from_lwgeom_size ...passed
-  Test: test_gbox_serialized_size ...passed
-  Test: test_lwgeom_from_gserialized ...passed
-  Test: test_lwgeom_count_vertices ...passed
-  Test: test_on_gser_lwgeom_count_vertices ...passed
-  Test: test_geometry_type_from_string ...passed
-  Test: test_lwcollection_extract ...passed
-  Test: test_lwgeom_free ...passed
-  Test: test_lwgeom_swap_ordinates ...passed
-  Test: test_f2d ...passed
-  Test: test_lwgeom_clone ...passed
-  Test: test_lwgeom_force_clockwise ...passed
-  Test: test_lwgeom_calculate_gbox ...passed
-  Test: test_lwgeom_is_empty ...passed
-  Test: test_lwgeom_same ...passed
-  Test: test_lwline_from_lwmpoint ...passed
-  Test: test_lwgeom_as_curve ...passed
-  Test: test_lwgeom_scale ...passed
-  Test: test_gserialized_is_empty ...passed
-  Test: test_gserialized_peek_gbox_p_no_box_when_empty ...passed
-  Test: test_gserialized_peek_gbox_p_gets_correct_box ...passed
-  Test: test_gserialized_peek_gbox_p_fails_for_unsupported_cases ...passed
-  Test: test_gbox_same_2d ...passed
-  Test: test_signum_macro ...passed
-Suite: lwstroke
-  Test: test_lwcurve_linearize ...passed
-  Test: test_unstroke ...passed
-Suite: measures
-  Test: test_mindistance2d_tolerance ...passed
-  Test: test_mindistance3d_tolerance ...NOTICE: One or both of the geometries is missing z-value. The unknown z-value will be regarded as "any value"
-NOTICE: One or both of the geometries is missing z-value. The unknown z-value will be regarded as "any value"
-passed
-  Test: test_rect_tree_contains_point ...passed
-  Test: test_rect_tree_intersects_tree ...passed
-  Test: test_lwgeom_segmentize2d ...NOTICE: ptarray.c:448 - ptarray_segmentize2d: Too many segments required (1.000000e+101)
-NOTICE: liblwgeom code interrupted
-passed
-  Test: test_lwgeom_locate_along ...passed
-  Test: test_lw_dist2d_pt_arc ...passed
-  Test: test_lw_dist2d_seg_arc ...passed
-  Test: test_lw_dist2d_arc_arc ...passed
-  Test: test_lw_arc_length ...passed
-  Test: test_lw_dist2d_pt_ptarrayarc ...passed
-  Test: test_lw_dist2d_ptarray_ptarrayarc ...passed
-  Test: test_lwgeom_tcpa ...passed
-  Test: test_lwgeom_is_trajectory ...NOTICE: Geometry is not a LINESTRING
-NOTICE: Line does not have M dimension
-NOTICE: Measure of vertex 1 (1) not bigger than measure of vertex 0 (1)
-NOTICE: Measure of vertex 1 (0) not bigger than measure of vertex 0 (1)
-NOTICE: Measure of vertex 2 (2) not bigger than measure of vertex 1 (3)
-passed
-  Test: test_rect_tree_distance_tree ...passed
-Suite: effectivearea
-  Test: do_test_lwgeom_effectivearea_lines ...passed
-  Test: do_test_lwgeom_effectivearea_polys ...passed
-Suite: chaikin
-  Test: do_test_chaikin_lines ...passed
-  Test: do_test_chaikin_polygons ...passed
-Suite: filterm
-  Test: do_test_filterm_single_geometries ...passed
-  Test: do_test_filterm_collections ...passed
-Suite: minimum_bounding_circle
-  Test: test_empty ...passed
-Suite: miscellaneous
-  Test: test_misc_force_2d ...passed
-  Test: test_misc_simplify ...passed
-  Test: test_misc_count_vertices ...passed
-  Test: test_misc_area ...passed
-  Test: test_misc_wkb ...passed
-  Test: test_grid ...passed
-  Test: test_grid_in_place ...passed
-  Test: test_clone ...passed
-  Test: test_lwmpoint_from_lwgeom ...passed
-Suite: noding
-  Test: test_lwgeom_node ...passed
-Suite: encoded_polyline_output
-  Test: out_encoded_polyline_test_geoms ...passed
-  Test: out_encoded_polyline_test_srid ...passed
-  Test: out_encoded_polyline_test_precision ...passed
-Suite: geojson_output
-  Test: out_geojson_test_precision ...passed
-  Test: out_geojson_test_dims ...passed
-  Test: out_geojson_test_srid ...passed
-  Test: out_geojson_test_bbox ...passed
-  Test: out_geojson_test_geoms ...passed
-Suite: gml_output
-  Test: out_gml_test_precision ...passed
-  Test: out_gml_test_srid ...passed
-  Test: out_gml_test_dims ...passed
-  Test: out_gml_test_geodetic ...passed
-  Test: out_gml_test_geoms ...passed
-  Test: out_gml_test_geoms_prefix ...passed
-  Test: out_gml_test_geoms_nodims ...passed
-  Test: out_gml2_extent ...passed
-  Test: out_gml3_extent ...passed
-Suite: kml_output
-  Test: out_kml_test_precision ...passed
-  Test: out_kml_test_dims ...passed
-  Test: out_kml_test_geoms ...passed
-  Test: out_kml_test_prefix ...passed
-Suite: svg_output
-  Test: out_svg_test_precision ...passed
-  Test: out_svg_test_dims ...passed
-  Test: out_svg_test_relative ...passed
-  Test: out_svg_test_geoms ...passed
-  Test: out_svg_test_srid ...passed
-Suite: x3d_output
-  Test: out_x3d3_test_precision ...passed
-  Test: out_x3d3_test_geoms ...passed
-  Test: out_x3d3_test_option ...passed
-Suite: ptarray
-  Test: test_ptarray_append_point ...passed
-  Test: test_ptarray_append_ptarray ...passed
-  Test: test_ptarray_locate_point ...passed
-  Test: test_ptarray_isccw ...passed
-  Test: test_ptarray_signed_area ...passed
-  Test: test_ptarray_insert_point ...passed
-  Test: test_ptarray_contains_point ...passed
-  Test: test_ptarrayarc_contains_point ...passed
-  Test: test_ptarray_scale ...passed
-Suite: printing
-  Test: test_lwprint_default_format ...passed
-  Test: test_lwprint_format_orders ...passed
-  Test: test_lwprint_optional_format ...passed
-  Test: test_lwprint_oddball_formats ...passed
-  Test: test_lwprint_bad_formats ...passed
-Suite: sfcgal
-  Test: test_sfcgal_noop ...passed
-Suite: split
-  Test: test_lwline_split_by_point_to ...passed
-  Test: test_lwgeom_split ...passed
-Suite: stringbuffer
-  Test: test_stringbuffer_append ...passed
-  Test: test_stringbuffer_aprintf ...passed
-Suite: surface
-  Test: triangle_parse ...passed
-  Test: tin_parse ...passed
-  Test: polyhedralsurface_parse ...passed
-  Test: surface_dimension ...passed
-Suite: spatial_trees
-  Test: test_tree_circ_create ...passed
-  Test: test_tree_circ_pip ...passed
-  Test: test_tree_circ_pip2 ...passed
-  Test: test_tree_circ_distance ...passed
-  Test: test_tree_circ_distance_threshold ...passed
-Suite: triangulate
-  Test: test_lwgeom_delaunay_triangulation ...passed
-  Test: test_lwgeom_voronoi_diagram ...passed
-  Test: test_lwgeom_voronoi_diagram_expected_empty ...passed
-  Test: test_lwgeom_voronoi_diagram_custom_envelope ...passed
-Suite: twkb_output
-  Test: test_twkb_out_point ...passed
-  Test: test_twkb_out_linestring ...passed
-  Test: test_twkb_out_polygon ...passed
-  Test: test_twkb_out_multipoint ...passed
-  Test: test_twkb_out_multilinestring ...passed
-  Test: test_twkb_out_multipolygon ...passed
-  Test: test_twkb_out_collection ...passed
-  Test: test_twkb_out_idlist ...passed
-Suite: varint
-  Test: test_zigzag ...passed
-  Test: test_varint ...passed
-  Test: test_varint_roundtrip ...passed
-Suite: wkb_input
-  Test: test_wkb_in_point ...passed
-  Test: test_wkb_in_linestring ...passed
-  Test: test_wkb_in_polygon ...passed
-  Test: test_wkb_in_multipoint ...passed
-  Test: test_wkb_in_multilinestring ...passed
-  Test: test_wkb_in_multipolygon ...passed
-  Test: test_wkb_in_collection ...passed
-  Test: test_wkb_in_circularstring ...passed
-  Test: test_wkb_in_compoundcurve ...passed
-  Test: test_wkb_in_curvpolygon ...passed
-  Test: test_wkb_in_multicurve ...passed
-  Test: test_wkb_in_multisurface ...passed
-  Test: test_wkb_in_malformed ...passed
-Suite: wkb_output
-  Test: test_wkb_out_point ...passed
-  Test: test_wkb_out_linestring ...passed
-  Test: test_wkb_out_polygon ...passed
-  Test: test_wkb_out_multipoint ...passed
-  Test: test_wkb_out_multilinestring ...passed
-  Test: test_wkb_out_multipolygon ...passed
-  Test: test_wkb_out_collection ...passed
-  Test: test_wkb_out_circularstring ...passed
-  Test: test_wkb_out_compoundcurve ...passed
-  Test: test_wkb_out_curvpolygon ...passed
-  Test: test_wkb_out_multicurve ...passed
-  Test: test_wkb_out_multisurface ...passed
-  Test: test_wkb_out_polyhedralsurface ...passed
-Suite: wkt_input
-  Test: test_wkt_in_point ...passed
-  Test: test_wkt_in_linestring ...passed
-  Test: test_wkt_in_polygon ...passed
-  Test: test_wkt_in_multipoint ...passed
-  Test: test_wkt_in_multilinestring ...passed
-  Test: test_wkt_in_multipolygon ...passed
-  Test: test_wkt_in_collection ...passed
-  Test: test_wkt_in_circularstring ...passed
-  Test: test_wkt_in_compoundcurve ...passed
-  Test: test_wkt_in_curvpolygon ...passed
-  Test: test_wkt_in_multicurve ...passed
-  Test: test_wkt_in_multisurface ...passed
-  Test: test_wkt_in_tin ...passed
-  Test: test_wkt_in_polyhedralsurface ...passed
-  Test: test_wkt_in_errlocation ...passed
-  Test: test_wkt_double ...passed
-Suite: wkt_output
-  Test: test_wkt_out_point ...passed
-  Test: test_wkt_out_linestring ...passed
-  Test: test_wkt_out_polygon ...passed
-  Test: test_wkt_out_multipoint ...passed
-  Test: test_wkt_out_multilinestring ...passed
-  Test: test_wkt_out_multipolygon ...passed
-  Test: test_wkt_out_collection ...passed
-  Test: test_wkt_out_circularstring ...passed
-  Test: test_wkt_out_compoundcurve ...passed
-  Test: test_wkt_out_curvpolygon ...passed
-  Test: test_wkt_out_multicurve ...passed
-  Test: test_wkt_out_multisurface ...passed
-Suite: wrapx
-  Test: test_lwgeom_wrapx ...passed
 Run Summary:    Type  Total    Ran Passed Failed Inactive
               suites     44     44    n/a      0        0
@@ -1134,146 +778,15 @@ Run Summary:    Type  Total    Ran Passed Failed Inactive
              asserts   4215   4215   4215      0      n/a
 Elapsed time =    0.229 seconds
-PostgreSQL 12devel on x86_64-w64-mingw32, compiled by gcc.exe (x86_64-posix-seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
-  Postgis 3.0.0dev - r17081 - 2018-11-28 18:50:02
-  scripts 3.0.0dev r17081
-  GEOS: 3.7.0-CAPI-1.11.0 673b9939
-  PROJ: Rel. 5.2.0, September 15th, 2018
 Running tests
- ../loader/Point .............. ok
- ../loader/PointM .............. ok
- ../loader/PointZ .............. ok
- ../loader/MultiPoint .............. ok
- ../loader/MultiPointM .............. ok
- ../loader/MultiPointZ .............. ok
- ../loader/Arc .............. ok
- ../loader/ArcM .............. ok
- ../loader/ArcZ .............. ok
- ../loader/Polygon .............. ok
- ../loader/PolygonM .............. ok
- ../loader/PolygonZ .............. ok
- ../loader/TSTPolygon ......... ok
- ../loader/TSIPolygon ......... ok
- ../loader/TSTIPolygon ......... ok
- ../loader/PointWithSchema ..... ok
- ../loader/NoTransPoint ......... ok
- ../loader/NotReallyMultiPoint ......... ok
- ../loader/MultiToSinglePoint ......... ok
- ../loader/ReprojectPts ........ ok
- ../loader/ReprojectPtsGeog ........ ok
- ../loader/Latin1 .... ok
- ../loader/Latin1-implicit .... ok
- ../loader/mfile .... ok
- ../dumper/literalsrid ....... ok
- ../dumper/realtable ....... ok
- affine .. ok
- bestsrid .. ok
- binary .. ok
- boundary .. ok
- chaikin .. ok
- filterm .. ok
- cluster .. ok
- concave_hull .. ok
- concave_hull_hard .. ok
- ctors .. ok
- curvetoline .. ok
- dump .. ok
- dumppoints .. ok
- empty .. ok
- estimatedextent .. ok
- forcecurve .. ok
- geography .. ok
- geometric_median .. ok
- in_geohash .. ok
- in_gml .. ok
- in_kml .. ok
- in_encodedpolyline .. ok
- iscollection .. ok
- legacy .. ok
- long_xact .. ok
- lwgeom_regress .. ok
- measures .. ok
- minimum_bounding_circle .. ok
- normalize .. ok
- operators .. ok
- orientation .. ok
- out_geometry .. ok
- out_geography .. ok
- polygonize .. ok
- polyhedralsurface .. ok
- postgis_type_name .. ok
- quantize_coordinates .. ok
- regress .. ok
- regress_bdpoly .. ok
- regress_gist_index_nd .. ok
- regress_index .. ok
- regress_index_nulls .. ok
- regress_management .. ok
- regress_selectivity .. ok
- regress_lrs .. ok
- regress_ogc .. ok
- regress_ogc_cover .. ok
- regress_ogc_prep .. ok
- regress_proj .. ok
- relate .. ok
- remove_repeated_points .. ok
- removepoint .. ok
- reverse .. ok
- setpoint .. ok
- simplify .. ok
- simplifyvw .. ok
- size .. ok
- snaptogrid .. ok
- split .. ok
- sql-mm-serialize .. ok
- sql-mm-circularstring .. ok
- sql-mm-compoundcurve .. ok
- sql-mm-curvepoly .. ok
- sql-mm-general .. ok
- sql-mm-multicurve .. ok
- sql-mm-multisurface .. ok
- swapordinates .. ok
- summary .. ok
- temporal .. ok
- tickets .. ok
- twkb .. ok
- typmod .. ok
- wkb .. ok
- wkt .. ok
- wmsservers .. ok
- knn_recheck .. ok
- temporal_knn .. ok
- hausdorff .. ok
- regress_buffer_params .. ok
- frechet .. ok
- offsetcurve .. ok
- relatematch .. ok
- isvaliddetail .. ok
- sharedpaths .. ok
- snap .. ok
- node .. ok
- unaryunion .. ok
- clean .. ok
- relate_bnr .. ok
- delaunaytriangles .. ok
- clipbybox2d .. ok
- subdivide .. ok
- voronoi .. ok
- minimum_clearance .. ok
- oriented_envelope .. ok
- in_geojson .. ok
- regress_brin_index .. ok
- regress_brin_index_3d .. ok
- regress_brin_index_geography .. ok
- regress_spgist_index_2d .. ok
- regress_spgist_index_3d .. ok
- regress_spgist_index_nd .. ok
- mvt .. ok
- geobuf .. ok
- mvt_jsonb .. ok
- uninstall .. ok (4643)
 Run tests: 134
 Failed: 0
@@ -1281,304 +794,55 @@ Failed: 0
 -- if you build with SFCGAL
-  SFCGAL: 1.3.2
 Running tests
- regress_sfcgal .. ok
- empty .. ok
- geography .. ok
- legacy .. ok
- measures .. ok
- regress_ogc .. ok
- regress .. ok
- tickets .. ok
- wmsservers .. ok
- approximatemedialaxis .. ok
 Run tests: 13
 Failed: 0
 -- if you built with raster support
-     CUnit - A unit testing framework for C - Version 2.1-2
-     http://cunit.sourceforge.net/
-Suite: pixtype
-  Test: test_pixtype_size ...passed
-  Test: test_pixtype_alignment ...passed
-  Test: test_pixtype_name ...passed
-  Test: test_pixtype_index_from_name ...passed
-  Test: test_pixtype_get_min_value ...passed
-  Test: test_pixtype_compare_clamped_values ...passed
-Suite: raster_basics
-  Test: test_raster_new ...passed
-  Test: test_raster_empty ...passed
-  Test: test_raster_metadata ...passed
-  Test: test_raster_clone ...passed
-  Test: test_raster_from_band ...passed
-  Test: test_raster_replace_band ...passed
-Suite: band_basics
-  Test: test_band_metadata ...passed
-  Test: test_band_pixtype_1BB ...passed
-  Test: test_band_pixtype_2BUI ...passed
-  Test: test_band_pixtype_4BUI ...passed
-  Test: test_band_pixtype_8BUI ...passed
-  Test: test_band_pixtype_8BSI ...passed
-  Test: test_band_pixtype_16BUI ...passed
-  Test: test_band_pixtype_16BSI ...passed
-  Test: test_band_pixtype_32BUI ...passed
-  Test: test_band_pixtype_32BSI ...passed
-  Test: test_band_pixtype_32BF ...passed
-  Test: test_band_pixtype_64BF ...passed
-  Test: test_band_get_pixel_line ...WARNING: Limiting returning number values to 1
-WARNING: Attempting to get pixel values with out of range raster coordinates: (5, 5)
-passed
-  Test: test_band_new_offline_from_path ...passed
-Suite: raster_wkb
-  Test: test_raster_wkb ...SRID value -1 converted to the officially unknown SRID value 0
-SRID value -1 converted to the officially unknown SRID value 0
-passed
-Suite: gdal
-  Test: test_gdal_configured ...passed
-  Test: test_gdal_drivers ...passed
-  Test: test_gdal_rasterize ...passed
-  Test: test_gdal_polygonize ...passed
-  Test: test_raster_to_gdal ...Warning 6: PNG driver doesn't support data type Float64. Only eight bit (Byte) and sixteen bit (UInt16) bands supported. Defaulting to Byte
-passed
-  Test: test_gdal_to_raster ...passed
-  Test: test_gdal_warp ...passed
-Suite: raster_geometry
-  Test: test_raster_envelope ...passed
-  Test: test_raster_envelope_geom ...passed
-  Test: test_raster_convex_hull ...passed
-  Test: test_raster_surface ...INFO: Ring Self-intersection at or near point 2 -2
-INFO: Ring Self-intersection at or near point 3 -3
-passed
-  Test: test_raster_perimeter ...passed
-  Test: test_raster_pixel_as_polygon ...passed
-Suite: raster_misc
-  Test: test_raster_cell_to_geopoint ...passed
-  Test: test_raster_geopoint_to_cell ...passed
-  Test: test_raster_from_two_rasters ...passed
-  Test: test_raster_compute_skewed_raster ...passed
-Suite: band_stats
-  Test: test_band_stats ...passed
-  Test: test_band_value_count ...passed
-Suite: band_misc
-  Test: test_band_get_nearest_pixel ...passed
-  Test: test_band_get_pixel_of_value ...passed
-  Test: test_pixel_set_to_array ...passed
-Suite: mapalgebra
-  Test: test_raster_iterator ...passed
-  Test: test_band_reclass ...passed
-  Test: test_raster_colormap ...passed
-Suite: spatial_relationship
-  Test: test_raster_geos_overlaps ...passed
-  Test: test_raster_geos_touches ...passed
-  Test: test_raster_geos_contains ...passed
-  Test: test_raster_geos_contains_properly ...passed
-  Test: test_raster_geos_covers ...passed
-  Test: test_raster_geos_covered_by ...passed
-  Test: test_raster_within_distance ...passed
-  Test: test_raster_fully_within_distance ...passed
-  Test: test_raster_intersects ...passed
-  Test: test_raster_same_alignment ...passed
-Suite: misc
-  Test: test_rgb_to_hsv ...passed
-  Test: test_hsv_to_rgb ...passed
-  Test: test_util_gdal_open ...passed
               suites     12     12    n/a      0        0
                tests     65     65     65      0        0
              asserts  45896  45896  45896      0      n/a
-Elapsed time =    0.499 seconds
-Loading Raster into 'postgis_reg'
-  raster scripts 3.0.0dev r17081
-  GDAL: GDAL 2.3.1, released 2018/06/22
 Running tests
- check_gdal .. ok
- load_outdb ... ok
- check_raster_columns .. ok
- check_raster_overviews .. ok
- rt_io .. ok
- rt_bytea .. ok
- rt_wkb .. ok
- box3d .. ok
- rt_addband .. ok
- rt_band .. ok
- rt_tile .. ok
- rt_dimensions .. ok
- rt_scale .. ok
- rt_pixelsize .. ok
- rt_upperleft .. ok
- rt_rotation .. ok
- rt_georeference .. ok
- rt_set_properties .. ok
- rt_isempty .. ok
- rt_hasnoband .. ok
- rt_metadata .. ok
- rt_rastertoworldcoord .. ok
- rt_worldtorastercoord .. ok
- rt_convexhull .. ok
- rt_envelope .. ok
- rt_band_properties .. ok
- rt_set_band_properties .. ok
- rt_pixelaspolygons .. ok
- rt_pixelaspoints .. ok
- rt_pixelascentroids .. ok
- rt_setvalues_array .. ok
- rt_summarystats .. ok
- rt_count .. ok
- rt_histogram .. ok
- rt_quantile .. ok
- rt_valuecount .. ok
- rt_valuepercent .. ok
- rt_bandmetadata .. ok
- rt_pixelvalue .. ok
- rt_neighborhood .. ok
- rt_nearestvalue .. ok
- rt_pixelofvalue .. ok
- rt_polygon .. ok
- rt_setbandpath .. ok
- rt_utility .. ok
- rt_fromgdalraster .. ok
- rt_asgdalraster .. ok
- rt_astiff .. ok
- rt_asjpeg .. ok
- rt_aspng .. ok
- rt_reclass .. ok
- rt_gdalwarp .. ok
- rt_asraster .. ok
- rt_dumpvalues .. ok
- rt_makeemptycoverage .. ok
- rt_createoverview .. ok
- rt_mapalgebraexpr .. ok
- rt_mapalgebrafct .. ok
- rt_mapalgebraexpr_2raster .. ok
- rt_mapalgebrafct_2raster .. ok
- rt_mapalgebrafctngb .. ok
- rt_mapalgebrafctngb_userfunc .. ok
- rt_intersection .. ok
- rt_clip .. ok
- rt_mapalgebra .. ok
- rt_mapalgebra_expr .. ok
- rt_mapalgebra_mask .. ok
- rt_union .. ok
- rt_invdistweight4ma .. ok
- rt_4ma .. ok
- rt_setvalues_geomval .. ok
- rt_elevation_functions .. ok
- rt_colormap .. ok
- rt_grayscale .. ok
- rt_gist_relationships .. ok
- rt_intersects .. ok
- rt_samealignment .. ok
- rt_geos_relationships .. ok
- rt_iscoveragetile .. ok
- bug_test_car5 .. ok
- permitted_gdal_drivers .. ok
- tickets .. ok
- loader/Basic .. ok
- loader/Projected ... ok
- loader/BasicCopy .. ok
- loader/BasicFilename .. ok
- loader/BasicOutDB .. ok
- loader/Tiled10x10 .. ok
- loader/Tiled10x10Copy .. ok
- loader/Tiled8x8 .. ok
- clean .. ok
 Run tests: 101
 Failed: 0
 -- topology regress
 Running tests
- regress/legacy_validate .. ok
- regress/legacy_predicate .. ok
- regress/legacy_invalid .. ok
- regress/sqlmm .. ok
- regress/legacy_query .. ok
- regress/addnode .. ok
- regress/addedge .. ok
- regress/addface .. ok
- regress/addface2.5d .. ok
- regress/addtopogeometrycolumn .. ok
- regress/polygonize .. ok
- regress/st_addisoedge .. ok
- regress/st_addisonode .. ok
- regress/st_addedgemodface .. ok
- regress/st_addedgenewfaces .. ok
- regress/st_changeedgegeom .. ok
- regress/st_createtopogeo .. ok
- regress/st_getfacegeometry .. ok
- regress/st_getfaceedges .. ok
- regress/st_modedgeheal .. ok
- regress/st_modedgesplit .. ok
- regress/st_newedgeheal .. ok
- regress/st_newedgessplit .. ok
- regress/st_remedgenewface .. ok
- regress/st_remedgemodface .. ok
- regress/st_simplify .. ok
- regress/topoelement .. ok
- regress/topoelementarray_agg .. ok
- regress/topogeo_addlinestring .. ok
- regress/topogeo_addpoint .. ok
- regress/topogeo_addpolygon .. ok
- regress/topogeom_edit .. ok
- regress/topogeometry_type .. ok
- regress/topojson .. ok
- regress/topologysummary .. ok
- regress/topo2.5d .. ok
- regress/totopogeom .. ok
- regress/droptopology .. ok
- regress/droptopogeometrycolumn .. ok
- regress/copytopology .. ok
- regress/createtopogeom .. ok
- regress/createtopology .. ok
- regress/gml .. ok
- regress/getnodebypoint .. ok
- regress/getedgebypoint .. ok
- regress/getfacebypoint .. ok
- regress/getringedges .. ok
- regress/gettopogeomelements .. ok
- regress/layertrigger .. ok
- regress/validatetopology .. ok
 Run tests: 51
 Failed: 0
@@ -1588,20 +852,16 @@ Failed: 0
-Suite: Shapefile Loader File shp2pgsql Test
-  Test: test_ShpLoaderCreate() ...passed
-  Test: test_ShpLoaderDestroy() ...passed
-Suite: Shapefile Loader File pgsql2shp Test
-  Test: test_ShpDumperCreate() ...passed
-  Test: test_ShpDumperDestroy() ...passed
               suites      2      2    n/a      0        0
                tests      4      4      4      0        0
              asserts      4      4      4      0      n/a</programlisting>
-	  <para>The <varname>postgis_tiger_geocoder</varname> and <varname>address_standardizer</varname> extensions, currenlty only support the standard PostgreSQL installcheck.  To test these use the below.  Note: the make install is not necessary if you already did make install at root of PostGIS code folder.</para>
+	  <para>The <varname>postgis_tiger_geocoder</varname> and <varname>address_standardizer</varname> extensions, currently only support the standard PostgreSQL installcheck.  To test these use the below.  Note: the make install is not necessary if you already did make install at root of PostGIS code folder.</para>
 	  <para>For address_standardizer:
 	  <programlisting>cd extensions/address_standardizer
 make install
Summary of changes:
 doc/installation.xml | 814 +++------------------------------------------------
 1 file changed, 37 insertions(+), 777 deletions(-)
hooks/post-receive
