[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-464-g5f4b44e
git at osgeo.org
git at osgeo.org
Mon Aug 30 19:14:30 PDT 2021
the project "PostGIS".
via 5f4b44edb30c8609d3f812d1f0bc6fd07d750f0f (commit)
from 25fe3dd0a651caeceb7aa3b10671d0c56e6dac1a (commit)
revisions in full, below.
commit 5f4b44edb30c8609d3f812d1f0bc6fd07d750f0f
Author: Rindahl <Bruce.Rindahl at ventura.org>
Date: Mon Aug 30 16:28:47 2021 -0700
More spelling errors
Also includes PROJ and PostGIS references
Closes https://github.com/postgis/postgis/pull/633
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index 48f175e..b16b5ca 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -39,7 +39,7 @@
To compute the area using the faster but less accurate spherical model use <varname>ST_Area(geog,false)</varname>.
</para>
<para>Enhanced: 2.0.0 - support for 2D polyhedral surfaces was introduced.</para>
- <para>Enhanced: 2.2.0 - measurement on spheroid performed with GeographicLib for improved accuracy and robustness. Requires Proj >= 4.9.0 to take advantage of the new feature.</para>
+ <para>Enhanced: 2.2.0 - measurement on spheroid performed with GeographicLib for improved accuracy and robustness. Requires PROJ >= 4.9.0 to take advantage of the new feature.</para>
<para>Changed: 3.0.0 - does not depend on SFCGAL anymore.</para>
<para>&sfs_compliant;</para>
<para>&sqlmm_compliant; SQL-MM 3: 8.1.2, 9.5.3</para>
@@ -151,7 +151,7 @@ from somegeogtable;</programlisting>
<para>Availability: 1.1.0</para>
<para>Enhanced: 2.0.0 support for geography was introduced.</para>
- <para>Enhanced: 2.2.0 measurement on spheroid performed with GeographicLib for improved accuracy and robustness. Requires Proj >= 4.9.0 to take advantage of the new feature.</para>
+ <para>Enhanced: 2.2.0 measurement on spheroid performed with GeographicLib for improved accuracy and robustness. Requires PROJ >= 4.9.0 to take advantage of the new feature.</para>
</refsection>
<refsection>
@@ -524,7 +524,7 @@ SELECT ST_AsEWKT(ST_3DClosestPoint(line,pt)) AS cp3d_line_pt,
<para>Availability: 1.5.0 geography support was introduced in 1.5. Speed improvements for planar to better handle large or many vertex geometries</para>
<para>Enhanced: 2.1.0 improved speed for geography. See <ulink url="http://boundlessgeo.com/2012/07/making-geography-faster/">Making Geography faster</ulink> for details.</para>
<para>Enhanced: 2.1.0 - support for curved geometries was introduced.</para>
</refsection>
@@ -1106,7 +1106,7 @@ FROM (SELECT ST_GeographyFromText(
<title>Description</title>
<para>Returns the 3-dimensional or 2-dimensional length of the geometry if it is a
- linestring or multi-linestring. For 2-d lines it will just return the 2-d length (same as ST_Length and ST_Length2D)</para>
+ LineString or MultiLineString. For 2-d lines it will just return the 2-d length (same as ST_Length and ST_Length2D)</para>
<para>&Z_support;</para>
<para>Changed: 2.0.0 In prior versions this used to be called ST_Length3D</para>
</refsection>
@@ -1416,7 +1416,7 @@ SELECT ST_AsEWKT(ST_3DLongestLine(line,pt)) AS lol3d_line_pt,
</para></entry>
</row>
<row>
- <entry><para>Multilinestring and polygon both 3d and 2d longest line
+ <entry><para>MultiLineString and Polygon both 3d and 2d longest line
<programlisting>SELECT ST_AsEWKT(ST_3DLongestLine(poly, mline)) As lol3d,
ST_AsEWKT(ST_LongestLine(poly, mline)) As lol2d
FROM (SELECT ST_GeomFromEWKT('POLYGON((175 150 5, 20 40 5, 35 45 5, 50 60 5, 100 100 5, 175 150 5))') As poly,
@@ -1617,7 +1617,7 @@ SELECT ST_3DMaxDistance(
</para>
<para>
- If no minimum clearance exists for a geometry (e.g. a single point, or a multipoint whose points are identical),
+ If no minimum clearance exists for a geometry (e.g. a single point, or a MultiPoint whose points are identical),
the return value is <varname>Infinity</varname>.
</para>
@@ -2126,7 +2126,7 @@ SELECT ST_AsEWKT(ST_3DShortestLine(line,pt)) AS shl3d_line_pt,
</para></entry>
</row>
<row>
- <entry><para>Multilinestring and polygon both 3d and 2d shortest line
+ <entry><para>MultiLineString and polygon both 3d and 2d shortest line
<programlisting>SELECT ST_AsEWKT(ST_3DShortestLine(poly, mline)) As shl3d,
ST_AsEWKT(ST_ShortestLine(poly, mline)) As shl2d
diff --git a/doc/reference_operator.xml b/doc/reference_operator.xml
index 1e51d40..1d29387 100644
--- a/doc/reference_operator.xml
+++ b/doc/reference_operator.xml
@@ -2042,7 +2042,7 @@ Returns the distance between A and B trajectories at their closest point of appr
The <varname>|=|</varname> operator returns the 3D distance between
two trajectories (See <xref linkend="ST_IsValidTrajectory" />).
This is the same as <xref linkend="ST_DistanceCPA" /> but as an operator
-it can be used for doing nearest neightbor searches using an N-dimensional
+it can be used for doing nearest neighbor searches using an N-dimensional
index (requires PostgreSQL 9.5.0 or higher).
</para>
diff --git a/doc/reference_overlay.xml b/doc/reference_overlay.xml
index 85f4b2d..9d51f65 100644
--- a/doc/reference_overlay.xml
+++ b/doc/reference_overlay.xml
@@ -258,7 +258,7 @@ SELECT ST_AsText(ST_Intersection('POINT(0 0)'::geometry, 'LINESTRING ( 0 0, 0 2
POINT(0 0)</programlisting>
<para>
-Clip all lines (trails) by country. Hhere we assume country geom are POLYGON or MULTIPOLYGONS.
+Clip all lines (trails) by country. Here we assume country geom are POLYGON or MULTIPOLYGONS.
NOTE: we are only keeping intersections that result in a LINESTRING or MULTILINESTRING because we don't
care about trails that just share a point. The dump is needed to expand a geometry collection into individual single MULT* parts.
The below is fairly generic and will work for polys, etc. by just changing the where clause.</para>
@@ -398,7 +398,7 @@ The resulting linework is dissolved (duplicate lines are removed).
<para>
Changed: 2.4.0 this function uses GEOSNode internally instead of GEOSUnaryUnion.
-This may cause the resulting linestrings to have a different order and direction compared to Postgis < 2.4.
+This may cause the resulting linestrings to have a different order and direction compared to PostGIS < 2.4.
</para>
</refsection>
<refsection>
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index ab5eb59..6a942f0 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -501,7 +501,7 @@ FROM (SELECT
If an empty geometry is supplied, an empty <varname>GEOMETRYCOLLECTION</varname> is returned.
If <varname>NULL</varname> is supplied, <varname>NULL</varname> is returned.
If <varname>CIRCULARSTRING</varname> or <varname>COMPOUNDCURVE</varname>
- are supplied, they are converted to linestring wtih CurveToLine first,
+ are supplied, they are converted to linestring with CurveToLine first,
then same than for <varname>LINESTRING</varname>
</para>
<para>For mixed-dimension input, the result is equal to the centroid of the component
@@ -1311,7 +1311,7 @@ FROM test;
Lines are not joined across intersections of 3-way or greater degree.
</para>
- <note><para>Only use with MultiLineString/LineStrings. If you pass a Plygon or GeometryCollection into this function, it
+ <note><para>Only use with MultiLineString/LineStrings. If you pass a Polygon or GeometryCollection into this function, it
returns an empty GeometryCollection</para></note>
<para>Performed by the GEOS module.</para>
@@ -1550,7 +1550,7 @@ POLYGON((135.59714732062 115,134.384753327498 102.690357210921,130.79416296937 9
<refsection>
<para>
- Returns the mimimum-area rotated rectangle enclosing a geometry.
+ Returns the minimum-area rotated rectangle enclosing a geometry.
Note that more than one such rectangle may exist.
May return a Point or LineString in the case of degenerate inputs.
</para>
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index efef1ed..b845fa5 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -1067,7 +1067,7 @@ SELECT ST_Equals(ST_Reverse(ST_GeomFromText('LINESTRING(0 0, 10 10)')),
<note><para>&index_aware;</para></note>
- <para>Changed: 3.0.0 SFCGAL version removed and native suppport for 2D TINS added.</para>
+ <para>Changed: 3.0.0 SFCGAL version removed and native support for 2D TINS added.</para>
<para>Enhanced: 2.5.0 Supports GEOMETRYCOLLECTION.</para>
<para>Enhanced: 2.3.0 Enhancement to PIP short-circuit extended to support MultiPoints with few points. Prior versions only supported point in polygon.</para>
<para>Performed by the GEOS module (for geometry), geography is native</para>
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index f4e5557..b4a0afd 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -900,7 +900,7 @@ FROM ( SELECT ST_Extrude(ST_Buffer(ST_GeomFromText('POINT(100 90)'),
<refsection>
- <para>Takes as input a surface such a MULTI(POLYGON) or POLYHEDRALSURFACE and returns a TIN representation via the process of tesselation using triangles.</para>
+ <para>Takes as input a surface such a MULTI(POLYGON) or POLYHEDRALSURFACE and returns a TIN representation via the process of tessellation using triangles.</para>
<para>Availability: 2.1.0</para>
<para>&sfcgal_required;</para>
diff --git a/doc/reference_srs.xml b/doc/reference_srs.xml
index 15122ed..01adc73 100644
--- a/doc/reference_srs.xml
+++ b/doc/reference_srs.xml
@@ -172,7 +172,7 @@ SRID=3785;POINT(-13732990.8753491 6178458.96425423)
the geometry.</para>
<note>
- <para>Requires PostGIS be compiled with Proj support. Use <xref linkend="PostGIS_Full_Version" /> to confirm you have proj support compiled in.</para>
+ <para>Requires PostGIS be compiled with PROJ support. Use <xref linkend="PostGIS_Full_Version" /> to confirm you have PROJ support compiled in.</para>
</note>
<note>
Summary of changes:
doc/reference_measure.xml | 14 +++++++-------
doc/reference_operator.xml | 2 +-
doc/reference_overlay.xml | 4 ++--
doc/reference_processing.xml | 6 +++---
doc/reference_relationship.xml | 2 +-
doc/reference_sfcgal.xml | 2 +-
doc/reference_srs.xml | 2 +-
7 files changed, 16 insertions(+), 16 deletions(-)
hooks/post-receive
