[postgis-tickets] [PostGIS] #4985: 32-bit crashers on cluster regress
trac at osgeo.org
Tue Aug 31 12:45:43 PDT 2021
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Keywords: |
bessie32 and berrie have been crashing after commit
[45e49124/git]
From berrie (32-bit raspberry pi)
22:23:25 PATH is
/home/jenkins/workspace/pg/label/berrie/rel/pg12w32/bin:/home/jenkins/workspace/pg/label/berrie/rel/pg12w32/lib:/usr/local/bin:/usr/bin:/bin:/usr/games
22:23:25 Checking for shp2pgsql ... found
22:23:25 Checking for pgsql2shp ... found
22:23:25 Checking for raster2pgsql ... found
22:23:25 TMPDIR is /tmp/pgis_reg
22:23:25 Database postgis_reg already exists, dropping.
22:23:25 Creating database 'postgis_reg'
22:23:25 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis SCHEMA
public
22:23:28 Preparing db 'postgis_reg' using: CREATE EXTENSION
postgis_topology
22:23:28 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis_raster
SCHEMA public
22:23:29 PostgreSQL 12.6 on aarch64-unknown-linux-gnu, compiled by gcc
(Raspbian 8.3.0-6+rpi1) 8.3.0, 32-bit
22:23:29 Postgis 3.2.0dev - (5f4b44e) - 2021-08-31 02:17:48
22:23:29 scripts 3.2.0dev 5f4b44e
22:23:29 raster scripts 3.2.0dev 5f4b44e
22:23:29 GEOS: 3.7.1-CAPI-1.11.1 27a5e771
22:23:29 PROJ: Rel. 5.2.0, September 15th, 2018
22:23:29 GDAL: GDAL 2.4.0, released 2018/12/14
22:23:29
22:23:29 Running tests
22:23:29
22:23:29
22:23:29 after-create-script
/home/jenkins/workspace/PostGIS_Worker_Run/label/berrie/5f4b44edb30c8609d3f812d1f0bc6fd07d750f0f/regress/hooks
/hook-after-create.sql .. ok
22:23:29 ./regress/core/affine .. ok in 81 ms
22:23:29 ./regress/core/bestsrid .. ok in 47 ms
22:23:29 ./regress/core/binary .. ok in 119 ms
22:23:29 ./regress/core/boundary .. ok in 49 ms
22:23:29 ./regress/core/chaikin .. ok in 43 ms
22:23:29 ./regress/core/filterm .. ok in 40 ms
22:23:29 ./regress/core/cluster ..Died at
/home/jenkins/workspace/PostGIS_Worker_Run/label/berrie/5f4b44edb30c8609d3f812d1f0bc6fd07d750f0f/regress/run_test.pl
line 744.
22:23:30 failed (psql exited with an error: /tmp/pgis_reg/test_8_out)
22:23:30
22:23:30 t1|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
4),LINESTRING(0 0,-1 -1),POLYGON((0 0,4 0,4 4,0 4,0 0)))
22:23:30 t1|GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
22:23:30 t1|GEOMETRYCOLLECTION(POLYGON EMPTY)
22:23:30 t2|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
22:23:30 t2|GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
22:23:30 t2|GEOMETRYCOLLECTION(POLYGON EMPTY)
22:23:30 t3|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
22:23:30 t3|GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
22:23:30 t3|GEOMETRYCOLLECTION(POLYGON EMPTY)
22:23:30 t4|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
4),LINESTRING(0 0,-1 -1),LINESTRING(6 6,7 7),POLYGON((0 0,4 0,4 4,0 4,0
0)))
22:23:30 t4|GEOMETRYCOLLECTION(POLYGON EMPTY)
22:23:30 t101|1|0
22:23:30 t101|2|0
22:23:30 t101|3|0
22:23:30 t101|4|1
22:23:30 t101|5|1
22:23:30 t101|6|1
22:23:30 t102|1|
22:23:30 t102|2|
22:23:30 t102|3|
22:23:30 t102|4|
22:23:30 t102|5|
22:23:30 t102|6|
22:23:30 t103|1|
22:23:30 t103|2|
22:23:30 t103|3|
22:23:30 t103|4|0
22:23:30 t103|5|0
22:23:30 t103|6|0
22:23:30 #3612a|
22:23:30 #3612a|
22:23:30 #3612b|
22:23:30 psql:cluster.sql:50: server closed the connection unexpectedly
22:23:30 This probably means the server terminated abnormally
22:23:30 before or while processing the request.
22:23:30 psql:cluster.sql:50: fatal: connection to server was lost
22:23:30
22:23:30 make: *** [regress/runtest.mk:11: check-regress] Error 2
22:23:30 Build step 'Execute shell' marked build as failure
22:23:38 Finished: FAILURE
From bessie32 FreeBSD 12 32-bit
22:21:23 PostgreSQL 12.7 on i386-portbld-freebsd12.2, compiled by gcc10
(FreeBSD Ports Collection) 10.2.0, 32-bit
22:21:23 Postgis 3.2.0dev - (5f4b44e) - 2021-08-30 02:55:55
22:21:23 scripts 3.2.0dev 5f4b44e
22:21:23 raster scripts 3.2.0dev 5f4b44e
22:21:23 GEOS: 3.9.1-CAPI-1.14.2
22:21:23 PROJ: 7.2.1
22:21:23 SFCGAL: 1.3.8
22:21:23 GDAL: GDAL 3.2.1, released 2020/12/29
22:21:23
22:21:25 ./regress/core/cluster ..Died at
/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/5f4b44edb30c8609d3f812d1f0bc6fd07d750f0f/regress/run_test.pl
line 744.
22:21:29 failed (psql exited with an error:
/home/jenkins/tmp/pgis_reg_5f4b44edb30c8609d3f812d1f0bc6fd07d750f0f/test_8_out)
22:21:29
22:21:29 t1|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
22:21:29 t1|GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
22:21:29 t1|GEOMETRYCOLLECTION(POLYGON EMPTY)
22:21:29 t2|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
22:21:29 t2|GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
22:21:29 t2|GEOMETRYCOLLECTION(POLYGON EMPTY)
22:21:29 t3|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
22:21:29 t3|GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
22:21:29 t3|GEOMETRYCOLLECTION(POLYGON EMPTY)
22:21:29 t4|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4
0)))
22:21:29 t4|GEOMETRYCOLLECTION(POLYGON EMPTY)
22:21:29 t101|1|0
22:21:29 t101|2|0
22:21:29 t101|3|0
22:21:29 t101|4|1
22:21:29 t101|5|1
22:21:29 t101|6|1
22:21:29 t102|1|
22:21:29 t102|2|
22:21:29 t102|3|
22:21:29 t102|4|
22:21:29 t102|5|
22:21:29 t102|6|
22:21:29 t103|1|
22:21:29 t103|2|
22:21:29 t103|3|
22:21:29 t103|4|0
22:21:29 t103|5|0
22:21:29 t103|6|0
22:21:29 #3612a|
22:21:29 #3612a|
22:21:29 #3612b|
22:21:29 psql:cluster.sql:50: server closed the connection unexpectedly
22:21:29 This probably means the server terminated abnormally
22:21:29 before or while processing the request.
22:21:29 psql:cluster.sql:50: fatal: connection to server was lost
22:21:29
22:21:29 gmake[1]: *** [regress/runtest.mk:11: check-regress] Error 2
22:21:29 gmake[1]: Leaving directory
'/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/5f4b44edb30c8609d3f812d1f0bc6fd07d750f0f'
22:21:29 *** Error code 2
22:21:29
22:21:29 Stop.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4985>
