[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-469-g7a7736a
Tue Aug 31 16:24:00 PDT 2021
the project "PostGIS".
       via  7a7736ae6526e574bc4e9048c69895260511d93d (commit)
      from  86bbb10fe1bc294d65991755c0bde9aa43c39fe3 (commit)
revisions in full, below.
commit 7a7736ae6526e574bc4e9048c69895260511d93d
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Wed Sep 1 02:23:49 2021 +0300
    ST_ClusterKMeans @ 32bit: maybe there is a difference between float and float8?
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 303d10d..18dc2ee 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4123,7 +4123,7 @@ CREATE AGGREGATE ST_MakeLine (geometry) (
 -- Availability: 2.3.0
 -- Changed: 3.2.0 added max_radius parameter
-CREATE OR REPLACE FUNCTION ST_ClusterKMeans(geom geometry, k integer, max_radius float default null)
+CREATE OR REPLACE FUNCTION ST_ClusterKMeans(geom geometry, k integer, max_radius float8 default null)
 	RETURNS integer
 	AS 'MODULE_PATHNAME', 'ST_ClusterKMeans'
 	LANGUAGE 'c' VOLATILE STRICT WINDOW
Summary of changes:
 postgis/postgis.sql.in | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
