[postgis-tickets] [PostGIS] #1224: Provide a topology.ST_ValidateTopoGeo as per ISO specs (was: Provide a topology.ST_ValidateTopology as per ISO specs)
PostGIS trac at osgeo.org
Thu Jul 1 16:14:30 PDT 2021
  Reporter:  strk         |      Owner:  strk
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS Fund Me
 Component:  topology     |    Version:  main
Resolution:               |   Keywords:
Description changed by strk:
Old description:
> The sql/mm specs require an ST_ValidateTopology function.
> We have a ValidateTopology (w/out the ST_ prefix) because we do something
> more than the prescribed checks.
> This ticket is for reviewing the SQL/MM prescriptions and make sure
> there's nothing missing + adding the standard entrypoint.
New description:
 The sql/mm specs require an ST_ValidateTopoGeo function.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1224#comment:11>
