[postgis-tickets] [PostGIS] #4938: regress failure on PostGIS 3.1 geos 3.10 head
trac at osgeo.org
Thu Jul 1 16:30:14 PDT 2021
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.3
Component: postgis | Version: 3.1.x
Keywords: |
PostgreSQL 14beta1 (very close to beta2) on x86_64-w64-mingw32, compiled
by gcc.exe (x86_64-posix-seh-rev0, Built by MinGW-W64 project) 8.1.0,
64-bit
Postgis 3.1.3dev - (3.1.1-39-g70df06bdf) - 2021-07-01 23:16:37
scripts 3.1.3dev 3.1.1-39-g70df06bdf
raster scripts 3.1.3dev 3.1.1-39-g70df06bdf
GEOS: 3.10.0dev-CAPI-1.15.0
PROJ: 7.1.1
SFCGAL: 1.3.8
GDAL: GDAL 3.2.3, released 2021/04/27
--- ./regress/core/tickets_expected 2021-07-01 18:12:50.435346900
-0400
+++ /projects/postgis/tmp/3.1.3dev_pg14_geos3.10_gdal3.2.0w64/test_75_out
2021-07-01 19:24:22.244759900 -0400
@@ -30,7 +30,7 @@
#157|ST_Polygon|POLYGON
#157|ST_CurvePolygon|CURVEPOLYGON
#157|ST_CircularString|CIRCULARSTRING
-#168|3|MULTIPOLYGON ZM (((4275341.969778511 259186.96699306098
1323.762958283311 -1.797693134862316e+308,4275341.969778511
259186.96699306098 1323.762958283311
-1.797693134862316e+308,4275341.969778511 259186.96699306098
1323.762958283311 -1.797693134862316e+308)))|IllegalArgumentException:
Invalid number of points in LinearRing found 3 - must be 0 or >= 4
+#168|3|MULTIPOLYGON ZM (((4275341.969778511 259186.96699306098
1323.762958283311 -1.797693134862316e+308)))|Too few points in geometry
component[4275341.96977851 259186.966993061 1323.76295828331]
#175|SRID=26915;POINT(482020 4984378)
#178a|0
#178b|5
I suspect this is a GEOS 3.10 issue
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4938>
