[postgis-tickets] [PostGIS] #4939: Add possibility to merge lines without changing order of points.
trac at osgeo.org
Fri Jul 2 01:04:05 PDT 2021
Reporter: evgen | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.1.3
Component: postgis | Version: 2.5.x
Keywords: |
There is a great function ST_LineMerge. But it could reverse lines in
multiline to connect them. E.g.
SELECT ST_AsText(ST_LineMerge(
ST_GeomFromText('MULTILINESTRING((-29 -27,1 2),(-29 -27,-45 -33),(-45
-33,-46 -32))'))
returns `LINESTRING(1 2,-29 -27,-45 -33,-46 -32)` but it could be
`MULTILINESTRING((-29 -27,1 2),(-29 -27,-45 -33,-46 -32))'`.
I process one way roads. When I merge them I'd like to keep point order to
know original direction of that segments.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4939>
