[postgis-tickets] [PostGIS] #4939: Add possibility to merge lines without changing order of points.
PostGIS trac at osgeo.org
Fri Jul 30 11:18:50 PDT 2021
  Reporter:  evgen        |      Owner:  pramsey
      Type:  enhancement  |     Status:  closed
  Priority:  medium       |  Milestone:  PostGIS 3.1.4
 Component:  postgis      |    Version:  2.5.x
Resolution:  wontfix      |   Keywords:
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 This seems unlikely to happen (when directions of merged lines disagree
 then...?) It's also something that can be reported upstream in the JTS
 repository. If there's interest there, or it's easy, it will eventually
 flow downstream to here.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4939#comment:2>
