[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.1-43-g008d2db
git at osgeo.org
git at osgeo.org
Fri Jul 2 14:50:03 PDT 2021
the project "PostGIS".
The branch, stable-3.1 has been updated
via 008d2db632b1ae420ee16c8fc7d0e6dec3c2d9b5 (commit)
from fd0cef4ac6a88d4257e73793cc3416cacdfe1a69 (commit)
revisions in full, below.
commit 008d2db632b1ae420ee16c8fc7d0e6dec3c2d9b5
Author: Regina Obe <lr at pcorp.us>
Date: Fri Jul 2 17:49:54 2021 -0400
Add 3.1.2 and 3.1.3 notes to release notes, and prep for 3.1.3 release
diff --git a/NEWS b/NEWS
index 3ab70f3..4add24c 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
PostGIS 3.1.3
-2021/xx/xx
+2021/07/02
* Bug Fixes
- #4929, Fix missing error from GetRingEdges when invoked with
diff --git a/README.postgis b/README.postgis
index c8b531a..1369452 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.1.1
-:Date: 2021-01-28
+:Version: 3.1.3
+:Date: 2021-07-02
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 3361ca2..1d4fc95 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=1
-POSTGIS_MICRO_VERSION=3dev
+POSTGIS_MICRO_VERSION=3
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index f57aa73..4b8c448 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,6 +2,42 @@
<appendix id="release_notes">
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
+ <sect1>
+ <title>Release 3.1.3</title>
+ <para>Release date: 2021/07/02</para>
+ <simplesect>
+ <title>Bug Fixes</title>
+ <para>#4929, Fix missing error from GetRingEdges when invoked with
+ unexistent topology or edge (Sandro Santilli)</para>
+ <para>#4927, Fix PostgreSQL 14 compile FuncnameGetCandidates changes
+ (Regina Obe, Julien Rouhaud)</para>
+ </simplesect>
+ </sect1>
+ <sect1>
+ <title>Release 3.1.2</title>
+ <para>Release date: 2021/05/21</para>
+ <simplesect>
+ <para>#4871, TopoGeometry::geometry cast returns NULL for empty
+ TopoGeometry objects (Sandro Santilli)</para>
+ <para>#4826, postgis_tiger_geocoder Better answers when no zip is provided
+ (Regina Obe)</para>
+ <para>#4817, handle more complex compound coordinate dystems (Paul Ramsey)</para>
+ <para>#4842, Only do axis flips on CRS that have a "Lat" as the first column (Paul Ramsey)
+ - Support recent Proj versions that have removed pj_get_release (Paul Ramsey)</para>
+ <para>#4835, Adjust tolerance for geodetic calculations (Paul Ramsey)</para>
+ <para>#4840, Improper conversion of negative geographic azimuth to positive (Paul Ramsey)</para>
+ <para>#4853, DBSCAN cluster not formed when recordset length equal to minPoints (Dan Baston)</para>
+ <para>#4863, Update bboxes after scale/affine coordinate changes (Paul Ramsey)</para>
+ <para>#4876, Fix raster issues related to PostgreSQL 14 tablefunc changes
+ (Paul Ramsey, Regina Obe)</para>
+ <para>#4877, mingw64 PostGIS / PostgreSQL 14 compile (Regina Obe, Tom Lane)</para>
+ <para>#4838, Update to support Tiger 2020 (Regina Obe)</para>
+ <para>#4890, Change Proj cache lifetime to last as long as connection (Paul Ramsey)</para>
+ <para>#4845, Add Pg14 build support (Paul Ramsey)</para>
+ </simplesect>
+ </sect1>
<sect1>
<title>Release 3.1.1</title>
Summary of changes:
NEWS | 2 +-
README.postgis | 4 ++--
Version.config | 2 +-
doc/release_notes.xml | 36 ++++++++++++++++++++++++++++++++++++
4 files changed, 40 insertions(+), 4 deletions(-)
hooks/post-receive
