[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-269-g1766890
Mon Jul 5 14:24:34 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  176689092ee63b221992ce888f318c1f3c7cf84a (commit)
      from  f21c1d835286d980d31b5e4eb1caf1102a2b8903 (commit)
revisions in full, below.
commit 176689092ee63b221992ce888f318c1f3c7cf84a
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jul 5 23:23:13 2021 +0200
    Have ValidateTopology debug-print limiting bbox and count of checked faces
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index bb9e884..a53d7c0 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1454,7 +1454,7 @@ DECLARE
   retrec topology.ValidateTopology_ReturnType;
   rec RECORD;
   rec2 RECORD;
-  i integer;
+  affected_rows integer;
   invalid_edges integer[];
   invalid_faces integer[];
   search_path_backup text;
@@ -1482,6 +1482,10 @@ BEGIN
   EXECUTE 'SET search_PATH TO ' || quote_ident(toponame) || ','
                                 || search_path_backup;
+  IF bbox IS NOT NULL THEN
+    RAISE DEBUG 'Limiting topology checking to bbox %', ST_AsEWKT(ST_Envelope(bbox));
+  END IF;
   -- Check for coincident nodes
   RAISE DEBUG 'Checking for coincident nodes';
@@ -1764,10 +1768,13 @@ BEGIN
   -- Scan the table looking for NULL geometries
   -- or geometries with wrong MBR consistency
   RAISE DEBUG 'Checking faces';
+  affected_rows := 0;
   FOR rec IN
     SELECT * FROM face_check
   LOOP --{
+    affected_rows := affected_rows + 1;
     IF rec.geom IS NULL OR ST_IsEmpty(rec.geom)
     THEN
       -- Face missing !
@@ -1826,6 +1833,8 @@ BEGIN
   END LOOP; --}
+  RAISE DEBUG 'Checked % faces', affected_rows;
   -- Check nodes have correct containing_face (#3233)
   RAISE DEBUG 'Checking for node containing_face correctness';
   FOR rec IN
Summary of changes:
 topology/topology.sql.in | 11 ++++++++++-
 1 file changed, 10 insertions(+), 1 deletion(-)
hooks/post-receive
