[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-276-g098c52a
Tue Jul 6 13:22:25 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  098c52a9c998b8d0b520c5b934f0389ea2acad6b (commit)
      from  96cb70a4803f5d9856c811a4684bf801751648da (commit)
revisions in full, below.
commit 098c52a9c998b8d0b520c5b934f0389ea2acad6b
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jul 6 22:20:35 2021 +0200
    Use format() to write GetNodeEdges query
diff --git a/topology/sql/query/GetNodeEdges.sql.in b/topology/sql/query/GetNodeEdges.sql.in
index 9d2deda..56665cf 100644
--- a/topology/sql/query/GetNodeEdges.sql.in
+++ b/topology/sql/query/GetNodeEdges.sql.in
@@ -22,7 +22,7 @@
 CREATE OR REPLACE FUNCTION topology.GetNodeEdges(atopology varchar, anode int)
 	RETURNS SETOF topology.GetFaceEdges_ReturnType
 AS
+$BODY$
 DECLARE
   curedge int;
   nextedge int;
@@ -33,19 +33,38 @@ DECLARE
 BEGIN
   n := 0;
-  sql :=
-    'WITH incident_edges AS ( SELECT edge_id, start_node, end_node, ST_RemoveRepeatedPoints(geom) as geom FROM '
-    || quote_ident(atopology)
-    || '.edge_data WHERE start_node = ' || anode
-    || ' or end_node = ' || anode
-    || ') SELECT edge_id, ST_Azimuth(ST_StartPoint(geom), ST_PointN(geom, 2)) as az FROM  incident_edges WHERE start_node = ' || anode
-    || ' UNION ALL SELECT -edge_id, ST_Azimuth(ST_EndPoint(geom), ST_PointN(geom, ST_NumPoints(geom)-1)) FROM incident_edges WHERE end_node = ' || anode
-    || ' ORDER BY az';
+  sql := format(
+      WITH incident_edges AS (
+        SELECT
+          edge_id,
+          start_node,
+          end_node,
+          ST_RemoveRepeatedPoints(geom) as geom
+        FROM %1$I.edge_data
+        WHERE start_node = $1
+        or end_node = $1
+      SELECT
+        edge_id,
+        ST_Azimuth(ST_StartPoint(geom), ST_PointN(geom, 2)) as az
+      FROM incident_edges
+        UNION ALL
+      SELECT
+        -edge_id,
+        ST_Azimuth(ST_EndPoint(geom), ST_PointN(geom, ST_NumPoints(geom)-1))
+      WHERE end_node = $1
+      ORDER BY az
+    atopology
 #ifdef POSTGIS_TOPOLOGY_DEBUG
   RAISE DEBUG 'sql: %', sql;
 #endif
-  FOR rec IN EXECUTE sql
+  FOR rec IN EXECUTE sql USING anode
   LOOP -- incident edges {
@@ -58,6 +77,6 @@ BEGIN
   END LOOP; -- incident edges }
 END
+$BODY$
 LANGUAGE 'plpgsql' STABLE;
 --} GetNodeEdges
Summary of changes:
 topology/sql/query/GetNodeEdges.sql.in | 41 +++++++++++++++++++++++++---------
 1 file changed, 30 insertions(+), 11 deletions(-)
hooks/post-receive
