[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-294-g7b2bc9a
Fri Jul 9 05:48:29 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  7b2bc9a07b5bbcc422231fa6bd526c7e4ad4ea54 (commit)
      from  c6d0af446c1c88ca369b03eab461b6267a7496f5 (commit)
revisions in full, below.
commit 7b2bc9a07b5bbcc422231fa6bd526c7e4ad4ea54
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 8 23:49:27 2021 +0200
    ValidateTopology check for faces with multiple shells
    Closes #4945
    Includes regress test
diff --git a/NEWS b/NEWS
index e15db67..3de871f 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,7 @@ PostGIS 3.2.0
   - #4933, topology.GetFaceByPoint will not work with topologies having invalid edge linking.
  * Enhancements *
+  - #4945, Multi-shell face check in ValidateTopology (Sandro Santilli)
   - #4944, Side-location conflict check in ValidateTopology (Sandro Santilli)
   - #3042, ValidateTopology check for edge linking (Sandro Santilli)
   - #3276, ValidateTopology check for face's mbr (Sandro Santilli)
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index 9c813e8..4592159 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -211,7 +211,7 @@ LANGUAGE 'plpgsql' VOLATILE;
 -- NOTE: assumes search_path was set before calling this function
-CREATE OR REPLACE FUNCTION topology._ValidateTopologySideLabeling(bbox geometry DEFAULT NULL)
+CREATE OR REPLACE FUNCTION topology._ValidateTopologyRings(bbox geometry DEFAULT NULL)
 RETURNS SETOF topology.ValidateTopology_ReturnType
 AS --{
 $BODY$
@@ -220,13 +220,11 @@ DECLARE
   nextEdge INT;
   rec RECORD;
   affected_rows integer;
+  ring_poly GEOMETRY;
+  is_shell BOOLEAN;
 BEGIN
   RAISE DEBUG 'Gathering edges for side faces labeling';
-  -- NOTE: this check relies on correct edge linking,
-  --       if those are not correct the results
-  --       of this check do not make much sense.
   -- Pick all edges ending on any node in the bbox
   -- Those are the only edges we want to consider
   CREATE TEMP TABLE side_label_check_edge AS
@@ -249,7 +247,14 @@ BEGIN
   CREATE INDEX ON side_label_check_edge (edge_id);
-  RAISE DEBUG 'Checking edge side faces labeling';
+  CREATE TEMP TABLE ring_check (
+    ring_id int,
+    ring_geom geometry, -- polygon for shell, line for hole
+    is_shell boolean,
+    bound_face int
+  RAISE DEBUG 'Checking edge rings';
   -- Find all rings that can be formed on both sides
   -- of selected edges
@@ -258,6 +263,8 @@ BEGIN
     -- Fetch next unvisited edge
     SELECT edge_id
     FROM pg_temp.side_label_check_edge
+    -- TODO: order by <-> from -inf/-inf to ensure catching
+    --       shells before holes
     ORDER BY edge_id
     LIMIT 1
     INTO nextEdge;
@@ -268,66 +275,72 @@ BEGIN
     affected_rows := affected_rows + 1;
+    -- Build ring formed on nextEdge
     -- Gather side faces for the ring formed on nextEdge
-    -- NOTE: if edge linking is bogus the following query
-    --       won't make much sense
-    BEGIN
-      WITH RECURSIVE
-      edgering AS (
-        SELECT
-          nextEdge as signed_edge_id,
-          edge_id,
-          next_left_edge,
-          next_right_edge,
-          CASE WHEN nextEdge > 0 THEN
-            left_face
-          ELSE
-            right_face
-          END as side_face
-        FROM edge_data
-        WHERE edge_id = abs(nextEdge)
-          UNION
-        SELECT
-          CASE WHEN p.signed_edge_id < 0
+    WITH RECURSIVE
+    edgering AS (
+      SELECT
+        nextEdge as signed_edge_id,
+        edge_id,
+        geom,
+        next_left_edge,
+        next_right_edge,
+        CASE WHEN nextEdge > 0 THEN
+          left_face
+        ELSE
+          right_face
+        END as side_face
+      FROM edge_data
+      WHERE edge_id = abs(nextEdge)
+        UNION
+      SELECT
+        CASE WHEN p.signed_edge_id < 0
+        THEN
+          p.next_right_edge
+        ELSE
+          p.next_left_edge
+        END, -- signed_edge_id
+        e.edge_id,
+        e.geom,
+        e.next_left_edge,
+        e.next_right_edge,
+        THEN
+          CASE WHEN p.next_right_edge > 0
           THEN
-            p.next_right_edge
+            e.left_face
           ELSE
-            p.next_left_edge
-          END, -- signed_edge_id
-          e.edge_id,
-          e.next_left_edge,
-          e.next_right_edge,
+            e.right_face
+          END
+        ELSE
+          CASE WHEN p.next_left_edge > 0
           THEN
-            CASE WHEN p.next_right_edge > 0
-            THEN
-              e.left_face
-            ELSE
-              e.right_face
-            END
+            e.left_face
           ELSE
-            CASE WHEN p.next_left_edge > 0
-            THEN
-              e.left_face
-            ELSE
-              e.right_face
-            END
-          END -- side_face
-        FROM edge_data e, edgering p
-        WHERE
-          e.edge_id = CASE
-            WHEN p.signed_edge_id < 0 THEN
-              abs(p.next_right_edge)
-            ELSE
-              abs(p.next_left_edge)
-            END
-      SELECT
-        array_agg(signed_edge_id) edges,
-        array_agg(DISTINCT side_face) side_faces
-      FROM edgering
-      INTO rec;
+            e.right_face
+          END
+        END -- side_face
+      FROM edge_data e, edgering p
+      WHERE
+        e.edge_id = CASE
+          WHEN p.signed_edge_id < 0 THEN
+            abs(p.next_right_edge)
+          ELSE
+            abs(p.next_left_edge)
+          END
+    SELECT
+      ST_MakeLine(
+        CASE WHEN signed_edge_id > 0 THEN
+          geom
+        ELSE
+          ST_Reverse(geom)
+        END
+      ) ring_geom,
+      array_agg(signed_edge_id) edges,
+      array_agg(DISTINCT side_face) side_faces
+    FROM edgering
+    INTO rec;
 --      RAISE DEBUG 'Ring % - edges:[%], faces:[%]',
 --        nextEdge,
@@ -335,36 +348,87 @@ BEGIN
 --        array_to_string(rec.side_faces, ',')
-      -- Check that there's a single face advertised
-      IF array_upper(rec.side_faces,1) != 1
-      THEN
-        RAISE DEBUG 'Side faces found on ring %: %', nextEdge, rec.side_faces;
-        retrec.error = 'mixed face labeling in ring';
-        retrec.id1 = nextEdge;
-        retrec.id2 = NULL;
-        RETURN NEXT retrec;
-      END IF;
-    EXCEPTION WHEN OTHERS THEN
-        retrec.error = SQLERRM;
-        -- Make sure this edge will be marked as visited
-        SELECT ARRAY[nextEdge] as edges INTO rec;
-    END;
+    -- Check that there's a single face advertised
+    IF array_upper(rec.side_faces,1) != 1
+    THEN --{
+      RAISE DEBUG 'Side faces found on ring %: %', nextEdge, rec.side_faces;
+      retrec.error = 'mixed face labeling in ring';
+      retrec.id1 = nextEdge;
+      retrec.id2 = NULL;
+      RETURN NEXT retrec;
+    ELSE --}{
+      -- Save ring that a single face is ever used
+      --       for each distinct CCW ring (shell)
+      -- NOTE: multiple CW rings (holes) can exist for a given face
+      --RAISE DEBUG 'Ring geom: %', ST_AsTexT(rec.ring_geom);
+      IF NOT ST_Equals(
+        ST_StartPoint(rec.ring_geom),
+        ST_EndPoint(rec.ring_geom)
+      THEN --{
+--        -- This should have been reported before,
+--        -- on the edge linking check
+--        retrec.error = 'non-closed ring';
+--        retrec.id1 = nextEdge;
+--        retrec.id2 = NULL;
+--        RETURN NEXT retrec;
+      ELSE --}{
+        is_shell := false;
+        IF ST_NPoints(rec.ring_geom) > 3 THEN
+          ring_poly := ST_MakePolygon(rec.ring_geom);
+          IF ST_IsPolygonCCW(ring_poly) THEN
+            is_shell := true;
+          END IF;
+        END IF;
+        INSERT INTO ring_check VALUES (
+          nextEdge,
+          CASE WHEN is_shell THEN
+            ring_poly
+          ELSE
+            rec.ring_geom
+          END,
+          is_shell,
+          rec.side_faces[1]
+      END IF; --}
+    END IF; --}
-    -- TODO: Check that a single face is ever used
-    --       for each distinct CCW ring (shell)
-    -- NOTE: multiple CW rings (holes) can exist for a given face
     DELETE FROM pg_temp.side_label_check_edge
     WHERE edge_id = ANY (rec.edges);
   END LOOP; --}
-  RAISE DEBUG 'Completed checking % rings for side faces labeling', affected_rows;
+  -- Check if any face has multiple shells
+  RAISE DEBUG 'Checking multi-shell faces';
+  FOR rec IN
+    SELECT
+      rc.bound_face,
+      count(rc.ring_id)
+    FROM ring_check rc
+    WHERE rc.is_shell
+    GROUP BY rc.bound_face
+    HAVING count(rc.ring_id) > 1
+  LOOP
+    retrec.error = 'face has multiple shells';
+    retrec.id1 = rec.bound_face;
+  END LOOP;
+  -- TODO: Check that holes really belong to the advertised shell
+  -- NOTE: when limited by bounding box we might be missing the
+  --       shell belonging to the most external holes, so for
+  --       those we would need to
+  RAISE DEBUG 'Completed checking % rings', affected_rows;
   DROP TABLE pg_temp.side_label_check_edge;
+  DROP TABLE pg_temp.ring_check;
 END;
@@ -669,8 +733,8 @@ BEGIN
   --- Validate edge linking
   RETURN QUERY SELECT * FROM topology._ValidateTopologyEdgeLinking(bbox);
-  --- Validate side-labeling
-  RETURN QUERY SELECT * FROM topology._ValidateTopologySideLabeling(bbox);
+  --- Validate edge rings
+  RETURN QUERY SELECT * FROM topology._ValidateTopologyRings(bbox);
   -- Now create a temporary table to construct all face geometries
diff --git a/topology/test/regress/validatetopology.sql b/topology/test/regress/validatetopology.sql
index b51b3c5..7c1c824 100644
--- a/topology/test/regress/validatetopology.sql
+++ b/topology/test/regress/validatetopology.sql
@@ -159,5 +159,25 @@ SELECT '#4944', '---', null, null
 ORDER BY 1,2,3,4;
 ROLLBACK;
+-- Test face with multiple shells is caught
+-- See https://trac.osgeo.org/postgis/ticket/4945
+BEGIN;
+UPDATE city_data.edge_data SET right_face = 3 WHERE edge_id IN (8, 17);
+UPDATE city_data.edge_data SET left_face = 3 WHERE edge_id IN (11, 15);
+-- To reduce the noise,
+-- set face 3 mbr to include the mbr of face 5
+-- and delete face 5
+UPDATE city_data.face SET mbr = (
+  SELECT ST_Envelope(ST_Collect(mbr))
+  FROM city_data.face
+  WHERE face_id IN ( 3, 5 )
+) WHERE face_id = 3;
+DELETE FROM city_data.face WHERE face_id = 5;
+SELECT '#4945', * FROM ValidateTopology('city_data')
+UNION
+SELECT '#4945', '---', null, null
+ORDER BY 1,2,3,4;
+ROLLBACK;
 SELECT NULL FROM topology.DropTopology('city_data');
diff --git a/topology/test/regress/validatetopology_expected b/topology/test/regress/validatetopology_expected
index 340796f..e2e9256 100644
--- a/topology/test/regress/validatetopology_expected
+++ b/topology/test/regress/validatetopology_expected
@@ -46,3 +46,5 @@
 #4944|---||
 #4944|mixed face labeling in ring|-21|
 #4944|mixed face labeling in ring|-19|
+#4945|---||
+#4945|face has multiple shells|3|
Summary of changes:
 NEWS                                            |   1 +
 topology/sql/manage/ValidateTopology.sql.in     | 232 +++++++++++++++---------
 topology/test/regress/validatetopology.sql      |  20 ++
 topology/test/regress/validatetopology_expected |   2 +
 4 files changed, 171 insertions(+), 84 deletions(-)
hooks/post-receive
