[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-295-g419a215
git at osgeo.org
git at osgeo.org
Fri Jul 9 06:31:56 PDT 2021
the project "PostGIS".
The branch, main has been updated
via 419a215012734c49e6d5bb5575c279d62a61b4f2 (commit)
from 7b2bc9a07b5bbcc422231fa6bd526c7e4ad4ea54 (commit)
revisions in full, below.
commit 419a215012734c49e6d5bb5575c279d62a61b4f2
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Jul 9 15:26:50 2021 +0200
Protect DEBUG prints behind POSTGIS_TOPOLOGY_DEBUG macro
Also some ValidateTopology messages to NOTICE, as they are useful
to profile the code.
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index 4592159..a6eb0f5 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -33,11 +33,13 @@ BEGIN
IF prevedge_edge_id > 0
THEN -- previous was outgoing, this one should be next-right
IF prevedge_next_right_edge != curedge_edge_id THEN
+#ifdef POSTGIS_TOPOLOGY_DEBUG
RAISE DEBUG 'Edge % should be next-right of edge %, is % instead',
curedge_edge_id,
abs(prevedge_edge_id),
+#endif /* POSTGIS_TOPOLOGY_DEBUG */
retrec.error = 'invalid next_right_edge';
retrec.id1 = abs(prevedge_edge_id);
retrec.id2 = curedge_edge_id; -- we put the expected one here, for convenience
@@ -45,11 +47,13 @@ BEGIN
END IF;
ELSE -- previous was incoming, this one should be next-left
IF prevedge_next_left_edge != curedge_edge_id THEN
RAISE DEBUG 'Edge % should be next-left of edge %, is % instead',
curedge_edge_id,
retrec.error = 'invalid next_left_edge';
@@ -84,7 +88,7 @@ DECLARE
last_node_first_edge RECORD;
last_node_prev_edge RECORD;
BEGIN
- RAISE DEBUG 'Checking edge linking';
+ RAISE NOTICE 'Checking edge linking';
-- NOTE: this check relies on correct start_node and end_node
-- for edges, if those are not correct the results
-- of this check do not make much sense.
@@ -155,9 +159,13 @@ BEGIN
THEN
RETURN NEXT retrec;
END IF;
- --RAISE DEBUG 'Finished analisys of edge star around node %', last_node_id;
+ RAISE DEBUG 'Finished analisys of edge star around node %', last_node_id;
END IF;
- --RAISE DEBUG 'Analyzing edge star around node %', rec.node_id;
+ RAISE DEBUG 'Analyzing edge star around node %', rec.node_id;
last_node_id = rec.node_id;
last_node_first_edge = rec;
ELSE --}{
@@ -176,10 +184,12 @@ BEGIN
last_node_prev_edge = rec;
END LOOP; --}
IF last_node_id IS NOT NULL THEN --{
- --RAISE DEBUG 'Out of loop: last_node_id: %', last_node_id;
- --RAISE DEBUG 'Out of loop: last_node_first_edge edge_id:% next_left_edge:%', last_node_first_edge.edge_id, last_node_first_edge.next_left_edge;
- --RAISE DEBUG 'Out of loop: last_node_prev_edge edge_id:% next_left_edge:%', last_node_prev_edge.edge_id, last_node_prev_edge.next_left_edge;
- --RAISE DEBUG 'Out of loop: last_node_first_edge: %', last_node_first_edge;
+ RAISE DEBUG 'Out of loop: last_node_id: %', last_node_id;
+ RAISE DEBUG 'Out of loop: last_node_first_edge edge_id:% next_left_edge:%', last_node_first_edge.edge_id, last_node_first_edge.next_left_edge;
+ RAISE DEBUG 'Out of loop: last_node_prev_edge edge_id:% next_left_edge:%', last_node_prev_edge.edge_id, last_node_prev_edge.next_left_edge;
+ RAISE DEBUG 'Out of loop: last_node_first_edge: %', last_node_first_edge;
-- Check that last edge (CW from prev one) is correctly linked
retrec := topology._CheckEdgeLinking(
@@ -191,7 +201,9 @@ BEGIN
THEN
RETURN NEXT retrec;
END IF;
- --RAISE DEBUG 'Finished analisys of edge star around node % (out of loop)', last_node_id;
+ RAISE DEBUG 'Finished analisys of edge star around node % (out of loop)', last_node_id;
END IF; --}
@@ -223,7 +235,7 @@ DECLARE
ring_poly GEOMETRY;
is_shell BOOLEAN;
BEGIN
- RAISE DEBUG 'Gathering edges for side faces labeling';
+ RAISE NOTICE 'Gathering edges for side faces labeling';
-- Pick all edges ending on any node in the bbox
-- Those are the only edges we want to consider
@@ -254,7 +266,7 @@ BEGIN
bound_face int
- RAISE DEBUG 'Checking edge rings';
+ RAISE NOTICE 'Checking edge rings';
-- Find all rings that can be formed on both sides
-- of selected edges
@@ -342,17 +354,21 @@ BEGIN
FROM edgering
INTO rec;
--- RAISE DEBUG 'Ring % - edges:[%], faces:[%]',
--- nextEdge,
--- array_to_string(rec.edges, ','),
--- array_to_string(rec.side_faces, ',')
+ RAISE DEBUG 'Ring % - edges:[%], faces:[%]',
+ nextEdge,
+ array_to_string(rec.edges, ','),
+ array_to_string(rec.side_faces, ',')
-- Check that there's a single face advertised
IF array_upper(rec.side_faces,1) != 1
THEN --{
RAISE DEBUG 'Side faces found on ring %: %', nextEdge, rec.side_faces;
retrec.error = 'mixed face labeling in ring';
retrec.id1 = nextEdge;
retrec.id2 = NULL;
@@ -404,7 +420,7 @@ BEGIN
END LOOP; --}
-- Check if any face has multiple shells
- RAISE DEBUG 'Checking multi-shell faces';
+ RAISE NOTICE 'Checking multi-shell faces';
FOR rec IN
SELECT
rc.bound_face,
@@ -425,7 +441,7 @@ BEGIN
-- shell belonging to the most external holes, so for
-- those we would need to
- RAISE DEBUG 'Completed checking % rings', affected_rows;
+ RAISE NOTICE 'Completed checking % rings', affected_rows;
DROP TABLE pg_temp.side_label_check_edge;
DROP TABLE pg_temp.ring_check;
@@ -481,12 +497,12 @@ BEGIN
|| search_path_backup;
IF bbox IS NOT NULL THEN
- RAISE DEBUG 'Limiting topology checking to bbox %', ST_AsEWKT(ST_Envelope(bbox));
+ RAISE NOTICE 'Limiting topology checking to bbox %', ST_AsEWKT(ST_Envelope(bbox));
END IF;
-- Check for coincident nodes
- RAISE DEBUG 'Checking for coincident nodes';
+ RAISE NOTICE 'Checking for coincident nodes';
FOR rec IN
SELECT a.node_id as id1, b.node_id as id2
FROM
@@ -511,7 +527,7 @@ BEGIN
-- Check for edge crossed nodes
-- TODO: do this in the single edge loop
- RAISE DEBUG 'Checking for edges crossing nodes';
+ RAISE NOTICE 'Checking for edges crossing nodes';
FOR rec IN
SELECT n.node_id as nid, e.edge_id as eid
FROM
@@ -536,7 +552,7 @@ BEGIN
END LOOP;
-- Scan all edges
- RAISE DEBUG 'Checking for invalid or not-simple edges';
+ RAISE NOTICE 'Checking for invalid or not-simple edges';
FOR rec IN
SELECT e.geom, e.edge_id as id1, e.left_face, e.right_face
FROM edge e
@@ -582,7 +598,7 @@ BEGIN
END LOOP; --}
-- Check for edge crossing
- RAISE DEBUG 'Checking for crossing edges';
+ RAISE NOTICE 'Checking for crossing edges';
FOR rec IN
SELECT
e1.edge_id as id1,
@@ -668,7 +684,7 @@ BEGIN
-- Check for edge start_node geometry mis-match
-- TODO: move this in the first edge table scan
- RAISE DEBUG 'Checking for edges start_node mismatch';
+ RAISE NOTICE 'Checking for edges start_node mismatch';
FOR rec IN
SELECT e.edge_id as id1, n.node_id as id2
FROM
@@ -689,7 +705,7 @@ BEGIN
-- Check for edge end_node geometry mis-match
- RAISE DEBUG 'Checking for edges end_node mismatch';
+ RAISE NOTICE 'Checking for edges end_node mismatch';
FOR rec IN
FROM
@@ -709,7 +725,7 @@ BEGIN
END LOOP; --}
-- Check for faces w/out edges
- RAISE DEBUG 'Checking for faces without edges';
+ RAISE NOTICE 'Checking for faces without edges';
FOR rec IN
SELECT face_id as id1
FROM face
@@ -740,7 +756,7 @@ BEGIN
-- Now create a temporary table to construct all face geometries
-- for checking their consistency
- RAISE DEBUG 'Constructing geometry of all faces';
+ RAISE NOTICE 'Constructing geometry of all faces';
CREATE TEMP TABLE face_check ON COMMIT DROP AS
SELECT
@@ -772,7 +788,7 @@ BEGIN
-- Scan the table looking for NULL geometries
-- or geometries with wrong MBR consistency
- RAISE DEBUG 'Checking faces';
+ RAISE NOTICE 'Checking faces';
affected_rows := 0;
FOR rec IN
SELECT * FROM face_check
@@ -791,7 +807,9 @@ BEGIN
IF NOT ST_Equals(rec.mbr, ST_Envelope(rec.geom))
THEN
RAISE DEBUG 'MBR expected:% obtained:%', ST_AsEWKT(ST_Envelope(rec.geom)), ST_AsEWKT(ST_Envelope(rec.mbr));
-- Inconsistent MBR!
retrec.error := 'face has wrong mbr';
retrec.id1 := rec.face_id;
@@ -838,10 +856,10 @@ BEGIN
END LOOP; --}
- RAISE DEBUG 'Checked % faces', affected_rows;
+ RAISE NOTICE 'Checked % faces', affected_rows;
-- Check nodes have correct containing_face (#3233)
- RAISE DEBUG 'Checking for node containing_face correctness';
+ RAISE NOTICE 'Checking for node containing_face correctness';
FOR rec IN
SELECT
n.node_id,
@@ -880,7 +898,7 @@ BEGIN
END LOOP; --}
-- Check edges are covered by their left-right faces (#4830)
- RAISE DEBUG 'Checking for edges coverage';
+ RAISE NOTICE 'Checking for edges coverage';
FOR rec IN --{
WITH
face_coverage AS (
diff --git a/topology/sql/query/GetFaceContainingPoint.sql.in b/topology/sql/query/GetFaceContainingPoint.sql.in
index 5538477..505d0c2 100644
--- a/topology/sql/query/GetFaceContainingPoint.sql.in
+++ b/topology/sql/query/GetFaceContainingPoint.sql.in
@@ -64,8 +64,10 @@ BEGIN
atopology
RAISE DEBUG 'Query: %', sql;
RAISE DEBUG 'Point: %', ST_AsEWKT(apoint);
+#endif
EXECUTE sql
USING apoint
INTO closestEdge;
@@ -87,11 +89,13 @@ BEGIN
closestNode := closestEdge.end_node;
END IF;
RAISE DEBUG 'Closest edge is %, shortest line is % (length %)',
closestEdge.edge_id,
ST_AsEWKT(closestEdge.shortestLine),
closestEdge.dist
+#endif
IF closestNode IS NOT NULL
THEN --{ Closest point is a node
@@ -127,7 +131,9 @@ BEGIN
atopology
RAISE DEBUG 'SQL: %', sql;
+#endif
EXECUTE sql USING closestNode INTO rec;
IF array_upper(rec.sideFaces, 1) > 1
THEN
Summary of changes:
topology/sql/manage/ValidateTopology.sql.in | 78 +++++++++++++++---------
topology/sql/query/GetFaceContainingPoint.sql.in | 6 ++
2 files changed, 54 insertions(+), 30 deletions(-)
hooks/post-receive
