[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-329-gb564e09
Tue Jul 13 14:51:21 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  b564e095f367dc76d05c933da7a5d4a29f92822c (commit)
      from  406ecaab3296aa7630e9a887b0d736979f077c49 (commit)
revisions in full, below.
commit b564e095f367dc76d05c933da7a5d4a29f92822c
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Jul 13 23:50:48 2021 +0200
    Avoid rebuilding exterior ring of faces already built
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index 3b8cc6e..4c14df4 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -268,6 +268,7 @@ LANGUAGE 'plpgsql' VOLATILE;
 -- NOTE: assumes search_path was set before calling this function
 -- Creates a pg_temp.hole_check table
+-- Creates a pg_temp.shell_check table
 CREATE OR REPLACE FUNCTION topology._ValidateTopologyRings(bbox geometry DEFAULT NULL)
 RETURNS SETOF topology.ValidateTopology_ReturnType
@@ -486,10 +487,6 @@ BEGIN
   END LOOP;
 #endif /* POSTGIS_TOPOLOGY_DEBUG */
-  DROP TABLE pg_temp.shell_check;
 END;
 $BODY$ --}
@@ -824,17 +821,33 @@ BEGIN
   CREATE TEMP TABLE face_check ON COMMIT DROP AS
   SELECT
-    face_id,
-    ST_MakePolygon(
-      ST_ExteriorRing(
-        topology.ST_GetFaceGeometry(toponame, face_id)
-    ) AS shell,
-    mbr
+    sc.face_id,
+    sc.ring_geom AS shell,
+    f.mbr
   FROM
-    face
+    pg_temp.shell_check sc, face f
   WHERE
-    face_id > 0
+    f.face_id = sc.face_id
+  DROP TABLE pg_temp.shell_check;
+  IF bbox IS NOT NULL
+  THEN --{
+    INSERT INTO pg_temp.face_check
+    SELECT face_id,
+      ST_MakePolygon(
+        ST_ExteriorRing(
+          topology.ST_GetFaceGeometry(
+            toponame,
+            face_id
+      mbr
+    FROM face
+    WHERE mbr && bbox
     AND (
       CASE WHEN invalid_faces IS NOT NULL THEN
         NOT face_id = ANY(invalid_faces)
@@ -842,11 +855,11 @@ BEGIN
         TRUE
       END
-    AND (
-      bbox IS NULL
-      OR mbr && bbox
+    AND face_id NOT IN (
+      SELECT face_id FROM pg_temp.face_check
+  END IF; --}
   -- Build a gist index on geom
   CREATE INDEX ON face_check USING gist (shell);
Summary of changes:
 topology/sql/manage/ValidateTopology.sql.in | 47 ++++++++++++++++++-----------
 1 file changed, 30 insertions(+), 17 deletions(-)
hooks/post-receive
