[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-340-g1ea1cb6
git at osgeo.org
git at osgeo.org
Wed Jul 14 14:00:20 PDT 2021
the project "PostGIS".
The branch, main has been updated
via 1ea1cb69940be217f3a98412b1621c5b887c566e (commit)
from a4fc3247a71f192231088987eda2f556e9f27ee2 (commit)
revisions in full, below.
commit 1ea1cb69940be217f3a98412b1621c5b887c566e
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Jul 14 22:41:32 2021 +0200
Prevent healing edges if connecting node is used in a TopoGeometry
Closes #3239 in main branch (3.2.0dev)
diff --git a/NEWS b/NEWS
index b45bd41..d100a21 100644
--- a/NEWS
+++ b/NEWS
@@ -6,8 +6,10 @@ PostGIS 3.2.0
- #4933, topology.GetFaceByPoint will not work with topologies having invalid edge linking.
* Enhancements *
+ - #3239, Prevent headling topology edges if the connecting node is
+ used in the definition of a TopoGeometry (Sandro Santilli)
- #4950, Speed up checking containing_face for nodes in ValidateTopology
- (Sandro Santilli)
+ (Sandro Santilli)
- #4945, Multi-shell face check in ValidateTopology (Sandro Santilli)
- #4944, Side-location conflict check in ValidateTopology (Sandro Santilli)
- #3042, ValidateTopology check for edge linking (Sandro Santilli)
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 9480bf8..1874b23 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -2565,6 +2565,9 @@ cb_checkTopoGeomRemNode ( const LWT_BE_TOPOLOGY* topo,
TupleDesc tdesc;
initStringInfo(sql);
+ /* 1: check for lineal TopoGeometry objects being defined by
+ * only one of the edges to be merged */
appendStringInfo( sql, "SELECT t.* FROM ( SELECT r.topogeo_id, "
"r.layer_id, l.schema_name, l.table_name, l.feature_column, "
"array_agg(abs(r.element_id)) as elems FROM topology.layer l "
@@ -2574,7 +2577,7 @@ cb_checkTopoGeomRemNode ( const LWT_BE_TOPOLOGY* topo,
" AND abs(r.element_id) = ANY (ARRAY[%" LWTFMT_ELEMID ",%" LWTFMT_ELEMID
"]::int4[]) group by r.topogeo_id, r.layer_id, l.schema_name, "
"l.table_name, l.feature_column ) t WHERE NOT t.elems @> ARRAY[%"
- LWTFMT_ELEMID ",%" LWTFMT_ELEMID "]::int4[]",
+ LWTFMT_ELEMID ",%" LWTFMT_ELEMID "]::int4[] LIMIT 1",
topo->name, topo->id,
edge1, edge2, edge1, edge2 );
@@ -2612,8 +2615,54 @@ cb_checkTopoGeomRemNode ( const LWT_BE_TOPOLOGY* topo,
return 0;
- /* TODO: check for TopoGeometry objects being defined by the common
+ /* 2: check for puntual TopoGeometry objects being defined by the common
* node, see https://trac.osgeo.org/postgis/ticket/3239 */
+ resetStringInfo(sql);
+ appendStringInfo( sql, "SELECT t.* FROM ( SELECT r.topogeo_id, "
+ "r.layer_id, l.schema_name, l.table_name, l.feature_column, "
+ "array_agg(abs(r.element_id)) as elems FROM topology.layer l "
+ " INNER JOIN \"%s\".relation r ON (l.layer_id = r.layer_id) "
+ "WHERE l.level = 0 and l.feature_type = 1 "
+ "AND l.topology_id = %d"
+ " AND r.element_id = %" LWTFMT_ELEMID
+ " group by r.topogeo_id, r.layer_id, l.schema_name, "
+ "l.table_name, l.feature_column ) t LIMIT 1",
+ topo->name, topo->id,
+ rem_node );
+ POSTGIS_DEBUGF(1, "cb_checkTopoGeomRemNode query 2: %s", sql->data);
+ spi_result = SPI_execute(sql->data, !topo->be_data->data_changed, 0);
+ MemoryContextSwitchTo( oldcontext ); /* switch back */
+ if ( spi_result != SPI_OK_SELECT )
+ cberror(topo->be_data, "unexpected return (%d) from query execution: %s",
+ spi_result, sql->data);
+ pfree(sqldata.data);
+ return 0;
+ if ( SPI_processed )
+ row = SPI_tuptable->vals[0];
+ tdesc = SPI_tuptable->tupdesc;
+ tg_id = SPI_getvalue(row, tdesc, 1);
+ layer_id = SPI_getvalue(row, tdesc, 2);
+ schema_name = SPI_getvalue(row, tdesc, 3);
+ table_name = SPI_getvalue(row, tdesc, 4);
+ col_name = SPI_getvalue(row, tdesc, 5);
+ SPI_freetuptable(SPI_tuptable);
+ cberror(topo->be_data, "TopoGeom %s in layer %s "
+ "(%s.%s.%s) cannot be represented "
+ "healing edges %" LWTFMT_ELEMID
+ " and %" LWTFMT_ELEMID,
+ tg_id, layer_id, schema_name, table_name,
+ col_name, edge1, edge2);
+ return 0;
return 1;
diff --git a/topology/test/regress/st_modedgeheal.sql b/topology/test/regress/st_modedgeheal.sql
index 8322992..782737f 100644
--- a/topology/test/regress/st_modedgeheal.sql
+++ b/topology/test/regress/st_modedgeheal.sql
@@ -63,11 +63,27 @@ SELECT topology.DropTopology('city_data');
SELECT topology.CreateTopology('t') > 1;
CREATE TABLE t.f(id varchar);
-SELECT topology.AddTopoGeometryColumn('t', 't', 'f','g', 'LINE');
+SELECT 'line_layer', topology.AddTopoGeometryColumn('t', 't', 'f','g', 'LINE');
+CREATE TABLE t.p(id varchar);
+SELECT 'point_layer', topology.AddTopoGeometryColumn('t', 't', 'p','g', 'POINT');
+SELECT 'N'||topology.TopoGeo_AddPoint('t', 'POINT(2 8)'); -- 1
SELECT 'E'||topology.AddEdge('t', 'LINESTRING(2 2, 2 8)'); -- 1
SELECT 'E'||topology.AddEdge('t', 'LINESTRING(2 8, 8 8)'); -- 2
+INSERT INTO t.p VALUES ('F+N1',
+ topology.CreateTopoGeom('t', 1, 2, '{{1,1}}'));
+-- This should be forbidden, as F+N1 above could not be
+-- defined w/out the joining node
+-- See https://trac.osgeo.org/postgis/ticket/3239
+SELECT 'unexpected-success-with-orphaned-point-topogeom-1',
+ topology.ST_ModEdgeHeal('t', 1, 2);
+SELECT 'unexpected-success-with-orphaned-point-topogeom-2',
+ topology.ST_ModEdgeHeal('t', 2, 1);
+DELETE FROM t.p;
INSERT INTO t.f VALUES ('F+E1',
topology.CreateTopoGeom('t', 2, 1, '{{1,2}}'));
diff --git a/topology/test/regress/st_modedgeheal_expected b/topology/test/regress/st_modedgeheal_expected
index 115c6ae..cab772a 100644
--- a/topology/test/regress/st_modedgeheal_expected
+++ b/topology/test/regress/st_modedgeheal_expected
@@ -96,9 +96,13 @@ N21
N22
Topology 'city_data' dropped
t
-1
+line_layer|1
+point_layer|2
+N1
E1
E2
+ERROR: TopoGeom 1 in layer 2 (t.p.g) cannot be represented healing edges 1 and 2
+ERROR: TopoGeom 1 in layer 2 (t.p.g) cannot be represented healing edges 2 and 1
ERROR: TopoGeom 1 in layer 1 (t.f.g) cannot be represented healing edges 1 and 2
ERROR: TopoGeom 1 in layer 1 (t.f.g) cannot be represented healing edges 2 and 1
ERROR: SQL/MM Spatial exception - non-existent edge 200
diff --git a/topology/test/regress/st_newedgeheal.sql b/topology/test/regress/st_newedgeheal.sql
index e49979f..de4c218 100644
--- a/topology/test/regress/st_newedgeheal.sql
+++ b/topology/test/regress/st_newedgeheal.sql
+DELETE FROM t.p;
diff --git a/topology/test/regress/st_newedgeheal_expected b/topology/test/regress/st_newedgeheal_expected
index 07579f1..a41313a 100644
--- a/topology/test/regress/st_newedgeheal_expected
+++ b/topology/test/regress/st_newedgeheal_expected
N22
t
-1
+line_layer|1
+point_layer|2
+N1
E1
E2
Summary of changes:
NEWS | 4 +-
topology/postgis_topology.c | 53 ++++++++++++++++++++++++++-
topology/test/regress/st_modedgeheal.sql | 18 ++++++++-
topology/test/regress/st_modedgeheal_expected | 6 ++-
topology/test/regress/st_newedgeheal.sql | 18 ++++++++-
topology/test/regress/st_newedgeheal_expected | 6 ++-
6 files changed, 98 insertions(+), 7 deletions(-)
hooks/post-receive
