[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-341-g168f3f4
Wed Jul 14 14:51:32 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  168f3f431a9349d83728e7623f9388362eb6e169 (commit)
      from  1ea1cb69940be217f3a98412b1621c5b887c566e (commit)
revisions in full, below.
commit 168f3f431a9349d83728e7623f9388362eb6e169
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 14 23:32:04 2021 +0200
    Prevent removing isolated node used in TopoGeometry definition
    Closes #3239 in main branch (3.2.0dev)
diff --git a/NEWS b/NEWS
index d100a21..0412f35 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,8 @@ PostGIS 3.2.0
   - #4933, topology.GetFaceByPoint will not work with topologies having invalid edge linking.
  * Enhancements *
+  - #3231, Prevent removing isolated nodes if used in a TopoGeometry
+           (Sandro Santilli)
   - #3239, Prevent headling topology edges if the connecting node is
            used in the definition of a TopoGeometry (Sandro Santilli)
   - #4950, Speed up checking containing_face for nodes in ValidateTopology
diff --git a/liblwgeom/liblwgeom_topo.h b/liblwgeom/liblwgeom_topo.h
index 901b778..cb56f12 100644
--- a/liblwgeom/liblwgeom_topo.h
+++ b/liblwgeom/liblwgeom_topo.h
@@ -755,7 +755,7 @@ typedef struct LWT_BE_CALLBACKS_T {
    * The operation should also be forbidden if the removed node
    * takes part in the definition of a TopoGeometry, although
-   * this wasn't the case yet as of PostGIS version 2.1.8:
+   * this wasn't the case yet as of PostGIS version 3.1:
    * https://trac.osgeo.org/postgis/ticket/3239
    * @return 1 to allow, 0 to forbid the operation
@@ -814,6 +814,24 @@ typedef struct LWT_BE_CALLBACKS_T {
 				      int fields,
 				      int limit);
+   * Check TopoGeometry objects before an isolated node removal event
+   * @param topo the topology to act upon
+   * @param rem_node identifier of the isolated node that's been removed
+   * The operation should be forbidden if the removed node
+   * takes part in the definition of a TopoGeometry.
+   * @return 1 to allow, 0 to forbid the operation
+   *         (reporting reason via lastErrorMessage)
+  int (*checkTopoGeomRemIsoNode) (
+      const LWT_BE_TOPOLOGY* topo,
+      LWT_ELEMID rem_node
 } LWT_BE_CALLBACKS;
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 3c21d1c..60df671 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -18,7 +18,7 @@
- * Copyright (C) 2015-2020 Sandro Santilli <strk at kbt.io>
+ * Copyright (C) 2015-2021 Sandro Santilli <strk at kbt.io>
@@ -354,6 +354,12 @@ lwt_be_checkTopoGeomRemNode(LWT_TOPOLOGY* topo, LWT_ELEMID node_id,
 static int
+lwt_be_checkTopoGeomRemIsoNode(LWT_TOPOLOGY* topo, LWT_ELEMID node_id)
+  CBT1(topo, checkTopoGeomRemIsoNode, node_id);
+static int
 lwt_be_updateTopoGeomFaceHeal(LWT_TOPOLOGY* topo,
                              LWT_ELEMID face1, LWT_ELEMID face2,
                              LWT_ELEMID newface)
@@ -3658,9 +3664,12 @@ lwt_RemoveIsoNode(LWT_TOPOLOGY* topo, LWT_ELEMID nid)
     return -1;
-  /* TODO: notify to caller about node being removed ?
-   * See https://trac.osgeo.org/postgis/ticket/3231
+  if ( ! lwt_be_checkTopoGeomRemIsoNode(topo, nid) )
+    lwfree(node);
+    lwerror("%s", lwt_be_lastErrorMessage(topo->be_iface));
+    return -1;
   lwfree(node);
   return 0; /* success */
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 1874b23..b5e6f5b 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -2668,6 +2668,71 @@ cb_checkTopoGeomRemNode ( const LWT_BE_TOPOLOGY* topo,
 static int
+cb_checkTopoGeomRemIsoNode ( const LWT_BE_TOPOLOGY* topo, LWT_ELEMID rem_node )
+  MemoryContext oldcontext = CurrentMemoryContext;
+  int spi_result;
+  StringInfoData sqldata;
+  StringInfo sql = &sqldata;
+  const char *tg_id, *layer_id;
+  const char *schema_name, *table_name, *col_name;
+  HeapTuple row;
+  TupleDesc tdesc;
+  initStringInfo(sql);
+  /* Check for puntual TopoGeometry objects being defined by the common
+   * node, see https://trac.osgeo.org/postgis/ticket/3231 */
+  resetStringInfo(sql);
+  appendStringInfo( sql, "SELECT t.* FROM ( SELECT r.topogeo_id, "
+                    "r.layer_id, l.schema_name, l.table_name, l.feature_column, "
+                    "array_agg(abs(r.element_id)) as elems FROM topology.layer l "
+                    " INNER JOIN \"%s\".relation r ON (l.layer_id = r.layer_id) "
+                    "WHERE l.level = 0 and l.feature_type in ( 1, 4 ) "
+                    "AND l.topology_id = %d"
+                    " AND r.element_id = %" LWTFMT_ELEMID
+                    " group by r.topogeo_id, r.layer_id, l.schema_name, "
+                    "l.table_name, l.feature_column ) t LIMIT 1",
+                    topo->name, topo->id,
+                    rem_node );
+  POSTGIS_DEBUGF(1, "cb_checkTopoGeomRemIsoNode query 2: %s", sql->data);
+  spi_result = SPI_execute(sql->data, !topo->be_data->data_changed, 0);
+  MemoryContextSwitchTo( oldcontext ); /* switch back */
+  if ( spi_result != SPI_OK_SELECT )
+    cberror(topo->be_data, "unexpected return (%d) from query execution: %s",
+            spi_result, sql->data);
+    pfree(sqldata.data);
+    return 0;
+  if ( SPI_processed )
+    row = SPI_tuptable->vals[0];
+    tdesc = SPI_tuptable->tupdesc;
+    tg_id = SPI_getvalue(row, tdesc, 1);
+    layer_id = SPI_getvalue(row, tdesc, 2);
+    schema_name = SPI_getvalue(row, tdesc, 3);
+    table_name = SPI_getvalue(row, tdesc, 4);
+    col_name = SPI_getvalue(row, tdesc, 5);
+    SPI_freetuptable(SPI_tuptable);
+    cberror(topo->be_data, "TopoGeom %s in layer %s "
+            "(%s.%s.%s) cannot be represented "
+            "removing node %" LWTFMT_ELEMID,
+            tg_id, layer_id, schema_name, table_name,
+            col_name, rem_node);
+    return 0;
+  return 1;
+static int
 cb_updateTopoGeomFaceHeal ( const LWT_BE_TOPOLOGY* topo,
                             LWT_ELEMID face1, LWT_ELEMID face2, LWT_ELEMID newface )
@@ -3269,7 +3334,8 @@ static LWT_BE_CALLBACKS be_callbacks =
   cb_updateTopoGeomFaceHeal,
   cb_checkTopoGeomRemNode,
   cb_updateTopoGeomEdgeHeal,
-  cb_getFaceWithinBox2D
+  cb_getFaceWithinBox2D,
+  cb_checkTopoGeomRemIsoNode
 static void
diff --git a/topology/test/regress/sqlmm.sql b/topology/test/regress/sqlmm.sql
index 9ef25b5..ec2881a 100644
--- a/topology/test/regress/sqlmm.sql
+++ b/topology/test/regress/sqlmm.sql
@@ -96,17 +96,6 @@ SELECT '-- ST_AddIsoNode(2) ------------------------';
 -- ST_AddIsoNode edge-crossing node
 SELECT topology.ST_AddIsoNode('sqlmm_topology', NULL, 'POINT(5 9.5)');
--- ST_RemoveIsoNode
-SELECT '-- ST_RemoveIsoNode  ------------------------';
--- Isolated node
-SELECT topology.ST_RemoveIsoNode('sqlmm_topology', 3);
--- Non isolated node (is used by an edge);
-SELECT topology.ST_RemoveIsoNode('sqlmm_topology', 4);
 -- ST_MoveIsoNode
diff --git a/topology/test/regress/sqlmm_expected b/topology/test/regress/sqlmm_expected
index ea665fe..0b22ddc 100644
--- a/topology/test/regress/sqlmm_expected
+++ b/topology/test/regress/sqlmm_expected
@@ -36,9 +36,6 @@ ERROR:  SQL/MM Spatial exception - not isolated node
 ERROR:  SQL/MM Spatial exception - edge crosses node.
--- ST_RemoveIsoNode  ------------------------
-Isolated node 3 removed
-ERROR:  SQL/MM Spatial exception - not isolated node
 -- ST_MoveIsoNode  ------------------------
 ERROR:  SQL/MM Spatial exception - coincident node
diff --git a/topology/test/regress/st_removeisonode.sql b/topology/test/regress/st_removeisonode.sql
new file mode 100644
index 0000000..ea25c67
--- /dev/null
+++ b/topology/test/regress/st_removeisonode.sql
@@ -0,0 +1,59 @@
+\set VERBOSITY terse
+set client_min_messages to ERROR;
+-- Import city_data
+\i ../load_topology.sql
+-- Non isolated node (is used by an edge);
+SELECT 'non-iso', topology.ST_RemoveIsoNode('city_data', 1);
+-- Isolated node
+SELECT 'iso', topology.ST_RemoveIsoNode('city_data',
+  topology.TopoGeo_addPoint('city_data', 'POINT(100 100)')
+-- See https://trac.osgeo.org/postgis/ticket/3231
+CREATE TABLE city_data.poi(id serial primary key);
+SELECT NULL FROM AddTopoGeometryColumn('city_data', 'city_data', 'poi', 'tg', 'POINT');
+CREATE TABLE city_data.mix(id serial primary key);
+SELECT NULL FROM AddTopoGeometryColumn('city_data', 'city_data', 'mix', 'tg', 'COLLECTION');
+BEGIN;
+INSERT INTO city_data.poi(tg) VALUES(
+  topology.CreateTopoGeom(
+    'city_data', -- Topology name
+    1, -- Topology geometry type (point)
+    1, -- TG_LAYER_ID for this topology (from topology.layer)
+    ARRAY[
+      ARRAY[
+        topology.TopoGeo_addPoint('city_data', 'POINT(100 100)'),
+        1 -- node
+SELECT '#3231.point', 'remove', ST_RemoveIsoNode('city_data',
+ROLLBACK;
+BEGIN;
+INSERT INTO city_data.mix(tg) VALUES(
+    4, -- Topology geometry type (point)
+    2, -- TG_LAYER_ID for this topology (from topology.layer)
+    ARRAY[
+      ARRAY[
+        1 -- node
+SELECT '#3231.collection', 'remove', ST_RemoveIsoNode('city_data',
+ROLLBACK;
+SELECT NULL FROM DropTopology('city_data');
diff --git a/topology/test/regress/st_removeisonode_expected b/topology/test/regress/st_removeisonode_expected
index 0000000..5adf4e9
--- /dev/null
+++ b/topology/test/regress/st_removeisonode_expected
@@ -0,0 +1,4 @@
+ERROR:  SQL/MM Spatial exception - not isolated node
+iso|Isolated node 23 removed
+ERROR:  TopoGeom 1 in layer 1 (city_data.poi.tg) cannot be represented removing node 24
+ERROR:  TopoGeom 1 in layer 2 (city_data.mix.tg) cannot be represented removing node 25
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 8a7566e..f98afe4 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -59,6 +59,7 @@ TESTS += \
 	$(topsrcdir)/topology/test/regress/st_newedgessplit.sql \
 	$(topsrcdir)/topology/test/regress/st_remedgemodface.sql \
 	$(topsrcdir)/topology/test/regress/st_remedgenewface.sql \
+	$(topsrcdir)/topology/test/regress/st_removeisonode.sql \
 	$(topsrcdir)/topology/test/regress/st_simplify.sql \
 	$(topsrcdir)/topology/test/regress/topo2.5d.sql \
 	$(topsrcdir)/topology/test/regress/topoelementarray_agg.sql \
Summary of changes:
 NEWS                                            |  2 +
 liblwgeom/liblwgeom_topo.h                      | 20 +++++++-
 liblwgeom/lwgeom_topo.c                         | 17 +++++--
 topology/postgis_topology.c                     | 68 ++++++++++++++++++++++++-
 topology/test/regress/sqlmm.sql                 | 11 ----
 topology/test/regress/sqlmm_expected            |  3 --
 topology/test/regress/st_removeisonode.sql      | 59 +++++++++++++++++++++
 topology/test/regress/st_removeisonode_expected |  4 ++
 topology/test/tests.mk                          |  1 +
 9 files changed, 165 insertions(+), 20 deletions(-)
 create mode 100644 topology/test/regress/st_removeisonode.sql
 create mode 100644 topology/test/regress/st_removeisonode_expected
hooks/post-receive
