[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-349-g40b8e63
git at osgeo.org
git at osgeo.org
Wed Jul 14 16:51:58 PDT 2021
the project "PostGIS".
The branch, main has been updated
via 40b8e63bdb055547d695727bc5c5df57f41c7d4d (commit)
via 8a7069abdce03f0d17d276bd70036fb07c77dc72 (commit)
from 48c9573e074d982f2afa85471ca38ddda307cd10 (commit)
revisions in full, below.
commit 40b8e63bdb055547d695727bc5c5df57f41c7d4d
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jul 15 01:48:09 2021 +0200
More consideration of collection TopoGeometries in callbacks
diff --git a/NEWS b/NEWS
index df0063e..3d22927 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,8 @@ PostGIS 3.2.0
- #4933, topology.GetFaceByPoint will not work with topologies having invalid edge linking.
* Enhancements *
+ - Consider collection TopoGeometries while editing topology primitives.
+ (Sandro Santilli)
- #3248, Prevent removing isolated edges if used in a TopoGeometry
(Sandro Santilli)
- #3231, Prevent removing isolated nodes if used in a TopoGeometry
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index fc181e7..6b7fe3f 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -2812,8 +2812,10 @@ cb_updateTopoGeomFaceHeal ( const LWT_BE_TOPOLOGY* topo,
initStringInfo(sql);
/* this query can be optimized */
appendStringInfo( sql, "DELETE FROM \"%s\".relation r "
- "USING topology.layer l WHERE l.level = 0 AND l.feature_type = 3"
+ "USING topology.layer l WHERE l.level = 0"
+ " AND l.feature_type IN (3,4)"
" AND l.topology_id = %d AND l.layer_id = r.layer_id "
+ " AND r.element_type = 3"
" AND abs(r.element_id) IN ( %" LWTFMT_ELEMID ",%" LWTFMT_ELEMID ")"
" AND abs(r.element_id) != %" LWTFMT_ELEMID,
topo->name, topo->id, face1, face2, newface );
@@ -2835,8 +2837,10 @@ cb_updateTopoGeomFaceHeal ( const LWT_BE_TOPOLOGY* topo,
/* delete face1 */
" AND abs(r.element_id) = %" LWTFMT_ELEMID,
topo->name, topo->id, face1 );
POSTGIS_DEBUGF(1, "cb_updateTopoGeomFaceHeal query 1: %s", sql->data);
@@ -2856,8 +2860,11 @@ cb_updateTopoGeomFaceHeal ( const LWT_BE_TOPOLOGY* topo,
/* update face2 to newface */
appendStringInfo( sql, "UPDATE \"%s\".relation r "
"SET element_id = %" LWTFMT_ELEMID " FROM topology.layer l "
- "WHERE l.level = 0 AND l.feature_type = 3 AND l.topology_id = %d"
- " AND l.layer_id = r.layer_id AND r.element_id = %" LWTFMT_ELEMID,
+ "WHERE l.level = 0 AND l.feature_type IN (3,4)"
+ " AND l.topology_id = %d"
+ " AND l.layer_id = r.layer_id"
+ " AND r.element_id = %" LWTFMT_ELEMID,
topo->name, newface, topo->id, face2 );
POSTGIS_DEBUGF(1, "cb_updateTopoGeomFaceHeal query 2: %s", sql->data);
@@ -2893,8 +2900,10 @@ cb_updateTopoGeomEdgeHeal ( const LWT_BE_TOPOLOGY* topo,
- "USING topology.layer l WHERE l.level = 0 AND l.feature_type = 2"
+ " AND l.feature_type IN (2,4)"
+ " AND r.element_type = 2"
topo->name, topo->id, edge1, edge2, newedge );
@@ -2916,8 +2925,10 @@ cb_updateTopoGeomEdgeHeal ( const LWT_BE_TOPOLOGY* topo,
/* delete edge1 */
+ " AND l.feature_type IN ( 2, 4 )"
topo->name, topo->id, edge2 );
POSTGIS_DEBUGF(1, "cb_updateTopoGeomEdgeHeal query 1: %s", sql->data);
@@ -2936,10 +2947,13 @@ cb_updateTopoGeomEdgeHeal ( const LWT_BE_TOPOLOGY* topo,
/* update edge2 to newedge */
- "SET element_id = %" LWTFMT_ELEMID " *(element_id/%" LWTFMT_ELEMID
+ "SET element_id = %" LWTFMT_ELEMID
+ " *(element_id/%" LWTFMT_ELEMID
") FROM topology.layer l "
- "WHERE l.level = 0 AND l.feature_type = 2 AND l.topology_id = %d"
- " AND l.layer_id = r.layer_id AND abs(r.element_id) = %" LWTFMT_ELEMID,
+ "WHERE l.level = 0 AND l.feature_type IN (2,4)"
+ " AND l.topology_id = %d AND l.layer_id = r.layer_id"
+ " AND abs(r.element_id) = %" LWTFMT_ELEMID,
topo->name, newedge, edge1, topo->id, edge1 );
POSTGIS_DEBUGF(1, "cb_updateTopoGeomEdgeHeal query 2: %s", sql->data);
commit 8a7069abdce03f0d17d276bd70036fb07c77dc72
Date: Thu Jul 15 01:33:59 2021 +0200
Improve readability of edge heal tests
diff --git a/topology/test/regress/st_modedgeheal.sql b/topology/test/regress/st_modedgeheal.sql
index d827951..b00c87e 100644
--- a/topology/test/regress/st_modedgeheal.sql
+++ b/topology/test/regress/st_modedgeheal.sql
@@ -123,15 +123,17 @@ SELECT topology.ST_ModEdgeHeal('t', 100, 2);
-- Now see how signed edges are updated
-SELECT 'E'||topology.AddEdge('t', 'LINESTRING(0 0, 5 0)'); -- 3
-SELECT 'E'||topology.AddEdge('t', 'LINESTRING(10 0, 5 0)'); -- 4
+SELECT 'tg-update', 'E'||topology.AddEdge('t', 'LINESTRING(0 0, 5 0)'); -- 3
+SELECT 'tg-update', 'E'||topology.AddEdge('t', 'LINESTRING(10 0, 5 0)'); -- 4
INSERT INTO t.f_lin VALUES ('F+E3-E4',
topology.CreateTopoGeom('t', 2, 1, '{{3,2},{-4,2}}'));
INSERT INTO t.f_lin VALUES ('F-E3+E4',
topology.CreateTopoGeom('t', 2, 1, '{{-3,2},{4,2}}'));
-SELECT r.topogeo_id, r.element_id
+SELECT
+ 'tg-update', 'before',
+ r.topogeo_id, r.element_id
FROM t.relation r, t.f_lin f WHERE
r.layer_id = layer_id(f.g) AND r.topogeo_id = id(f.g)
AND r.topogeo_id in (2,3)
@@ -139,17 +141,20 @@ SELECT r.topogeo_id, r.element_id
-- This is fine, but will have to tweak definition of
-- 'F+E3-E4' and 'F-E3+E4'
-SELECT 'MH(3,4)', topology.ST_ModEdgeHeal('t', 3, 4);
+SELECT 'tg-update', 'MH(3,4)', topology.ST_ModEdgeHeal('t', 3, 4);
--- This is for ticket #942
-SELECT topology.ST_ModEdgeHeal('t', 1, 3);
+SELECT
+ 'tg-update', 'after',
ORDER BY r.layer_id, r.topogeo_id, r.element_id;
+-- This is for ticket #942 (non-connected edges)
+SELECT '#942', topology.ST_ModEdgeHeal('t', 1, 3);
SELECT topology.DropTopology('t');
diff --git a/topology/test/regress/st_modedgeheal_expected b/topology/test/regress/st_modedgeheal_expected
index e13eb8e..9dd640b 100644
--- a/topology/test/regress/st_modedgeheal_expected
+++ b/topology/test/regress/st_modedgeheal_expected
@@ -112,16 +112,16 @@ ERROR: TopoGeom 2 in layer 3 (t.f_mix.g) cannot be represented healing edges 1
ERROR: TopoGeom 2 in layer 3 (t.f_mix.g) cannot be represented healing edges 2 and 1
ERROR: SQL/MM Spatial exception - non-existent edge 200
ERROR: SQL/MM Spatial exception - non-existent edge 100
-E3
-E4
-2|-4
-2|3
-3|-3
-3|4
-MH(3,4)|5
+tg-update|E3
+tg-update|E4
+tg-update|before|2|-4
+tg-update|before|2|3
+tg-update|before|3|-3
+tg-update|before|3|4
+tg-update|MH(3,4)|5
+tg-update|after|2|3
+tg-update|after|3|-3
ERROR: SQL/MM Spatial exception - non-connected edges
-2|3
-3|-3
Topology 't' dropped
#1955|t
#1955.1|E1
diff --git a/topology/test/regress/st_newedgeheal.sql b/topology/test/regress/st_newedgeheal.sql
index e162b78..51bf315 100644
--- a/topology/test/regress/st_newedgeheal.sql
+++ b/topology/test/regress/st_newedgeheal.sql
@@ -124,15 +124,17 @@ SELECT topology.ST_NewEdgeHeal('t', 100, 2);
+SELECT
@@ -140,17 +142,21 @@ SELECT r.topogeo_id, r.element_id
-SELECT 'MH(3,4)', topology.ST_NewEdgeHeal('t', 3, 4);
+SELECT 'tg-update', 'MH(3,4)', topology.ST_NewEdgeHeal('t', 3, 4);
-SELECT topology.ST_NewEdgeHeal('t', 1, 5);
+SELECT
+SELECT '#942', topology.ST_NewEdgeHeal('t', 1, 5);
diff --git a/topology/test/regress/st_newedgeheal_expected b/topology/test/regress/st_newedgeheal_expected
index 973f00f..ebec20b 100644
--- a/topology/test/regress/st_newedgeheal_expected
+++ b/topology/test/regress/st_newedgeheal_expected
-E3
-E4
-2|-4
-2|3
-3|-3
-3|4
-MH(3,4)|5
+tg-update|E3
+tg-update|E4
+tg-update|after|2|5
+tg-update|after|3|-5
-2|5
-3|-5
#1955|t
#1955.1|E1
Summary of changes:
NEWS | 2 ++
topology/postgis_topology.c | 32 +++++++++++++++++++--------
topology/test/regress/st_modedgeheal.sql | 21 +++++++++++-------
topology/test/regress/st_modedgeheal_expected | 18 +++++++--------
topology/test/regress/st_newedgeheal.sql | 22 +++++++++++-------
topology/test/regress/st_newedgeheal_expected | 18 +++++++--------
6 files changed, 70 insertions(+), 43 deletions(-)
hooks/post-receive
