[postgis-tickets] [PostGIS] #4953: Small fix to function edge_distance_to_point
trac at osgeo.org
Thu Jul 15 03:13:24 PDT 2021
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.3
Component: postgis | Version: 2.5.x
Keywords: geodetic |
The third parameter closest can be NULL. This is tested at the end of the
function but not at the beginning. The code below is extracted from
PostGIS 3.1.2.
double edge_distance_to_point(const GEOGRAPHIC_EDGE *e, const
GEOGRAPHIC_POINT *gp, GEOGRAPHIC_POINT *closest)
double d1 = 1000000000.0, d2, d3, d_nearest;
POINT3D n, p, k;
GEOGRAPHIC_POINT gk, g_nearest;
/* Zero length edge, */
if ( geographic_point_equals(&(e->start), &(e->end)) )
if (closest) <----------------- Missing test
*closest = e->start;
return sphere_distance(&(e->start), gp);
if (closest)
*closest = g_nearest;
return d_nearest;
Regards
Esteban
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4953>
