[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-354-g92b06f1
git at osgeo.org
git at osgeo.org
Thu Jul 15 07:00:00 PDT 2021
the project "PostGIS".
The branch, main has been updated
via 92b06f13feb21f1b903c2b7f713c39ca5fd1cc8a (commit)
from fb3bb49a00a12e45f127f259a76229f5c976eae2 (commit)
revisions in full, below.
commit 92b06f13feb21f1b903c2b7f713c39ca5fd1cc8a
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jul 15 15:44:39 2021 +0200
Add info about new enforcement in ST_MoveIsoNode
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 1a1d587..b74f48b 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -1815,12 +1815,20 @@ Updates all existing joined edges and relationships accordingly.
<title>Description</title>
<para>Moves an isolated node in a topology from one point to another. If new <varname>apoint</varname> geometry exists as a node an error is thrown.</para>
- <para>If any arguments are null, the <varname>apoint</varname> is not a point, the existing node is not isolated (is a start or end point of an existing edge), new node location intersects an existing edge (even at the end points) then an exception is thrown.</para>
+ <para>If any arguments are null, the
+<varname>apoint</varname> is not a point, the existing node is not
+isolated (is a start or end point of an existing edge), new node
+location intersects an existing edge (even at the end points) or the
+new location is in a different face (since 3.2.0) then an exception is thrown.
+ </para>
<para>If the spatial reference system (srid) of the point geometry is not the same as the topology an exception is thrown.</para>
<!-- use this format if new function -->
- <para>Availability: 1.? </para>
+ <para>Availability: 2.0.0 </para>
+ <para>
+ Enhanced: 3.2.0 ensures the nod cannot be moved in a different face
+ </para>
<para>&sqlmm_compliant; SQL-MM: Topo-Net Routines: X.3.2</para>
</refsection>
Summary of changes:
doc/extras_topology.xml | 12 ++++++++++--
1 file changed, 10 insertions(+), 2 deletions(-)
hooks/post-receive
